Hi @darryl12123 - what I do to debug these type of issues is to use the template editor under developer tools (You should see Developer Tools
on the left hand side of Home Assistant UI). Then select Template
from the tabs. Home Assistant uses Jinja2 templating. Then copy the value_template
into the template editor
window. On the right hand side you see the result of the templating code. If there is an error it will show up in red, explaining where you went wrong.
This worked for me:
{{ states("sensor.energy_consumption_tarif_1") |float + states("sensor.energy_consumption_tarif_2") | float }}
…it displayed 0.0
- as obviously I dont have those sensors.
sensors:
energie_verbruik_totaal:
friendly_name: "Energie Verbruik (totaal)"
unit_of_measurement: 'kWh'
value_template: '{{ states("sensor.energy_consumption_tarif_1") |float + states("sensor.energy_consumption_tarif_2") | float }}'
HTH
