Calculating average from a forecast
Here’s how to do an hourly cheapest-rate finder:
{% set fclist = state_attr('sensor.zonneplan_current_electricity_tariff','forcast') %}
{% set plist = fclist|map(attribute='price')|list %}
{% set ns = namespace(fc2=[]) %}
{%- for fc in fclist[:-1] -%}
{%- set ns.fc2 = ns.fc2 + [{'datetime':fc['datetime'],'price':(plist[loop.index0] + plist[loop.index0+1])/2}] -%}
{%- endfor -%}
{% set pmin = ns.fc2|map(attribute='price')|list|min %}
{{ (ns.fc2|selectattr('price','eq',pmin)|first)['datetime'] }}
It reads through the forecast up to the penultimate item (that’s what fclist[:-1] means) and builds a list of dictionaries with the datetime copied from the original sensor, and the price calculated as the mean of that slot and the next one.
We then do the same process of finding the minimum price in the new list and find the matching datetime.
You can expand this to any size of time period — just add subsequent items and adjust the total divisor in the mean calculation, and adjust the end point of the list so that your “looking forward” doesn’t go past the end.
I guess you are in a different timezone or looked at the wrong date (the price you mention is from 15/01)?
The ‘NOW’ in the screenshot was the 8-9am slot on the 16/01 (@ a price of 36.11) then at 22:00 (in attribute data and graph) the price is 30.06
OK — this is nothing to do with timezones, but is the problem of you blindly copying the code we suggest without understanding what it does. I’d missed the fact that your sensor also includes past data — my code finds the datetime of the cheapest price in the data regardless of when it is.
Try this for the single-slot forecast, which starts out by restricting the data to future entries:
        {% set dtnow = now().isoformat()[0:26]~"Z" %}
                        |selectattr('datetime','>=',dtnow)|list %}
        {% set pmin = fclist|map(attribute='price')|list|min %}
        {{ (fclist|selectattr('price','eq',pmin)|first)['datetime'] }}
The first line builds a datetime string that matches the format in your data; the second part of the second line uses that as a “filter” on the sensor data. Strongly recommend you play around in Developer Tools / Templates to see what’s going on.
You can work out how to translate that into the hourly calculator I posted above.
Thanks again. Will study this (and the one above). And you right, I only understand max 70% of your template but quite a steep learning curve as these are quite advanced compared to the ones I’m able to make.
No problem at all. As I say, play with the template editor. Paste in this and make changes to see what happens:
{{ now().isoformat() }}
{{ now().isoformat()[0:26] }}
{{ now().isoformat()[0:26]~"Z" }}
{{ state_attr('sensor.zonneplan_current_electricity_tariff','forcast') }}
@Troon I have been playing around with your template and starting to understand the logic (that is at least something) .
Few questions:
  1. I understand what the [Z] does at the end of the datetime but not sure about the [0:26] when testing. Could also not find it by Googling. Could you explain?
  2. on the template mentioned in this post;
  • Checking: To increase the consecutive hours at lowest price you mean adding another loop.index0-1 (for instance) the 5th line and then for each addition making sure I divide by the correct total divisor (to get the avg of those values & compare them with others). I’ve played around with it and this seems the logic but not 100% sure. Is my assumption Correct?
  • Half way the day, new data is added (another 24hours) to the attributes . This can create a situation where the lowest price is more than a day away (after this addition). This is still valuable info, but is it also possible to limit the list it creates and/or looks in to find the lowest price? With the objective to find -for example- the lowest price after ‘now’ but not further away then 12 hours?
Your sensor contains datetimes that look like this:
  datetime: '2023-01-15T07:00:00.000000Z'
so I manipulate the output of now().isoformat() to match that format: first 26 characters and stick a Z on the end. Once that’s done, it’s possible to compare correctly-ordered date/time strings “alphabetically” as a later time string will always evaluate as “greater” than an earlier time string. See the first general principle of ISO8601.
Nearly, but not loop.index0-1 as that would be looking backwards. The idea is to look forward n slots (hours) and take the average. My example above was for two hours; for three, you’d do:
{% set ns = namespace(fc3=[]) %}
{%- for fc in fclist[:-2] -%}
{%- set ns.fc3 = ns.fc3 + [{'datetime':fc['datetime'],
                                     plist[loop.index0+1] +
                                     plist[loop.index0+2]) / 3}] -%}
{%- endfor -%}
{% set pmin = ns.fc3|map(attribute='price')|list|min %}
{{ (ns.fc3|selectattr('price','eq',pmin)|first)['datetime'] }}
The set ns.fc3 line now gets the mean of the following three hours starting at each time. The previous (fourth) line fclist[:-2] restricts the starting point of the search to only go up to the third-last item of the list, because you can’t look two steps forward from later items.
Yes. Have a play in the template editor: see if you can filter fclist to exclude too-far-out elements from the start of the template. Here’s how to generate a correctly-formatted timestamp that is 12 hours away:
{% set dtend = (now()+timedelta(hours=12)).isoformat()[0:26]~"Z" %}
Just add a |selectattr('datetime','<=',dtend) onto your fclist definition and you should be good to go.
Your a star @Troon !
Ah! That was the part I did not get at first. I was assuming your approach, but was reaching the end of the list so that was I was going down. I just needed to adjust the starting point to compensate which makes total sense.
Your suggestions on limiting the fclist search also works!
On the datatime: I played around with that (the ones below tested in the in the template test part of HA) and I get different outputs (obviously), but I’m a bit surprised that the total template does not create another output if I modify the date part. All works independent of isoformat so I should not be concerned but was just trying to understand why that is.
{{ now().isoformat() }}   gives 2023-01-18T10:09:00.101813+01:00
{{ now().isoformat()[0:26] }} gives 2023-01-18T10:09:00.102033
{{ now().isoformat()[0:26]~"Z" }} gives 2023-01-18T10:09:00.102180Z (which is the format the sensor we are looking into uses)
I don’t understand what you mean by this. Example?
now() generates a datetime object, whereas you need a string for comparison (the way we’re doing it here) (see the time section of the template docs).
isoformat() (docs: I hadn’t realised this wasn’t directly in the HA docs but only referred to under “other datetime functions”) converts that datetime object to a string in a consistent format that we can pull about to match what we need.
The way I’ve approached this is not the only way it could be done: there are many different ways to work with date/time comparisons.
Can you tell what the outcome is and how it looks like now with showing the code from the apexchart and sensor code maby? Would be nice, thanks!
Below is the final code that gives you the time of the cheapest 2 hour upcoming.
You see a section that mentions ‘hours=6’ ; so this now looks 6 hours in the future eg cheapest 2 hours within 6 hours. Change that to 12, it looks to the next 12 hours cheapest slot.
This sensor has no direct link with apex-chart. Or am I misunderstanding your question?
  sensors:
    price_low_coming_short:
      friendly_name: Price lowest coming short
      unique_id: price_low_coming_short
      device_class: monetary
      value_template: >
        {% set dtend = (now()+timedelta(hours=6)).isoformat()[0:26]~"Z" %}
                        |selectattr('datetime','>=',dtnow)|selectattr('datetime','<=',dtend)|list %}
        {%- endfor -%}
        {{ int((ns.fc2|selectattr('price','eq',pmin)|first)['price'])/100000 }}
Tyfoon,
How can I make this template to load every 24:00 hours?
So that the cheapest hour does not shift throughout the day or it is possible to make this in an automation?
Thank you in advance
Make the sensor trigger based
Check out Hellis81’s solution. Would expect that to work although I have never tried this.
I’m curious to here your use case for a sensor like you mention as in your case (if I understand you correctly) you will get prices from the past.
Also not that most energy integrations will get new info from their supplier around mid day. At that moment in time, there is new data to evaluate and a new lowest price can come out. You have to think how you deal with that. That is the reason why I have 3 versions of this sensor; cheapest in next 3 hours (when I’m in a hurry), cheapest in 6 and 12 hours. I then created sensors that show the saving vs now in % so I can decide how long I want to postpone my ‘consumption’.
Beside Hellis81 suggestion you could adapt above. You will need to play with the template in template editor. The first line in the code is where it starts searching from. In this sensor is ‘now’ so it will only look for cheapest in the future (after now). You can also set this to any time you like, and it will start searching in the attributes from that time. You will have to play around with that.
Last thing; note that the ‘zonneplan’ integration has changed and ‘forcast’ was changed to ‘forecast’
thanks Tyfoon and Hellis81
I was thinking of making it like this:
current price - lowest price = difference.
This difference must not exceed the set value.
It’s for my water heater and washing machine.
Sure, that can work. I have below for my floorheating.
- alias: Bathroom heat on cheap_2h
    platform: time
    at: "05:02:00"
  condition:
    condition: and
    conditions:
      - condition: state
        entity_id: input_select.occupancy
        state: "Home"
      - condition: numeric_state
        entity_id: sensor.buienradar_temperature
        below: 10
      - condition: template
        value_template: "{{ states('input_number.floorheatingprice') | int  >  states('sensor.price_next_3_hours') | int }}"
    - service: climate.turn_on
      data: {}
        entity_id: climate.thermofloor_as_heatit_thermostat_tf_021_mode
    - service: climate.set_temperature
        temperature: 22
the input number:
floorheatingprice:
  name: Floor heating price
  initial: 20
  min: 0
  max: 50
  step: 1
price next 2 hours:
  sensors:
    price_next_2_hours:
      friendly_name: Price next 2 hours
      unique_id: price_next_2_hours
      value_template: >
        {% set dtnow = (((now() - timedelta(hours=2)).strftime('%Y-%m-%d %T')|as_datetime).isoformat())~"Z" %}
        {% set l=state_attr('sensor.zonneplan_current_electricity_tariff', 'forecast')|selectattr('datetime','>=',dtnow)|list %}
        {{ ((l[0].price + l[1].price)/2)/100000}}
hi i am fairly new to programming the solution i am after is very similar to the original solution for average of energy forecast however it doesn’t seem to want to play ball with my sensor attributes.
the attributes are given as
results:
  • value_exc_vat: 16.76
    value_inc_vat: 17.598
    valid_from: ‘2023-06-11T21:30:00Z’
    valid_to: ‘2023-06-11T22:00:00Z’
    payment_method: null
  • value_exc_vat: 21.21
    value_inc_vat: 22.2705
    valid_from: ‘2023-06-11T21:00:00Z’
    valid_to: ‘2023-06-11T21:30:00Z’
i’m sure i’m missing something really silly
thank you Jason
