Looks like this updates every 15 min and will display the events of that day. It currently does not show All Day events (which has a bug report) or the next event if it’s not today.
How did you fix this?
Hey folks,
therefore i just struggled with getting my Synology Diskstation calendar to work, i want to confirm what is working for me:
calendar:
- platform: caldav
username: mysecretuser
password: mysecretpass
url: https://<url>:5001/caldav.php/mysecretuser
calendars:
- 'Gemeinsam'
- 'Abfallkalender'
Just note that it is only working with caldav.php
(as mentioned before). In my case i also had to connect via https (+https-port).
Hope that helps
That’s awesome! It work!
Thanks for your help!
Is anyone having issues with the Caldav component? I had mine working for a long time and then recently I started getting an error.
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 40, in real_ip_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 136, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 123, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/calendar/__init__.py", line 193, in get
request.app["hass"], start_date, end_date
File "/usr/src/homeassistant/homeassistant/components/caldav/calendar.py", line 141, in async_get_events
return await self.data.async_get_events(hass, start_date, end_date)
File "/usr/src/homeassistant/homeassistant/components/caldav/calendar.py", line 173, in async_get_events
vevent = event.instance.vevent
File "/usr/local/lib/python3.7/site-packages/caldav/objects.py", line 995, in _get_vobject_instance
self._vobject_instance = vobject.readOne(to_unicode(self._data))
File "/usr/local/lib/python3.7/site-packages/vobject/base.py", line 1156, in readOne
allowQP))
File "/usr/local/lib/python3.7/site-packages/vobject/base.py", line 1101, in readComponents
vline = textLineToContentLine(line, n)
File "/usr/local/lib/python3.7/site-packages/vobject/base.py", line 925, in textLineToContentLine
return ContentLine(*parseLine(text, n), **{'encoded': True,
File "/usr/local/lib/python3.7/site-packages/vobject/base.py", line 813, in parseLine
raise ParseError("Failed to parse line: {0!s}".format(line), lineNumber)
Does it still work for you? I cannot find proper URL it’s either refused or wrong.
This is what I’ve been using for a while now and it works
- platform: caldav
username: !secret calendar_username
password: !secret calendar_password
url: https://URL/caldav.php/calendarname
