In the yaml file define the id like this:
api:
api:
Thanks, but I think I’m still misunderstanding. I have this in my ESPHome device code, and it will not compile:
# Enable Home Assistant API
api:
encryption:
key: !secret api_encryption_key
Which error message do you have when compiling?
Could you please share that and also your whole yaml, please?
Please remove any sensitive information before sharing.
Wow - it must have been a temporary thing – I compiled again today, and it worked and installed. And, it does what I want it to do: I can control my house lights using the buttons on the m5stack.
Topic kick i tried updating to the latest ESPhome, and getting exact the same error. My ESPhome config looks like:
api:
services:
- service: meterstand_water
variables:
meter_value: float
then:
- globals.set:
id: initial_water_usageid: totalWaterUsage
value: !lambda "return ( meter_value ) ;"
ota:
dallas:
- pin: GPIO14
wifi:
ssid: !secret SSID
password: !secret WiFi_Password
fast_connect: trueuse_address: watermeter.local
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Watermeter Fallback Hotspot”
password: “4Ejkhjkhuixa4M”
captive_portal:
script:
- id: reset_main_counter
then:
- lambda: |-
id(main_counter_pulses) = 0;
id(water_main_consumption).publish_state(id(main_counter_pulses));- id: reset_secondary_counter
then:
- lambda: |-
id(secondary_counter_pulses) = 0;
id(water_secondary_consumption).publish_state(id(secondary_counter_pulses));- id: publish_states
then:
- lambda: |-
id(water_daily_consumption).publish_state(id(daily_counter_pulses));
id(water_weekly_consumption).publish_state(id(weekly_counter_pulses));
id(water_monthly_consumption).publish_state(id(monthly_counter_pulses));
id(water_yearly_consumption).publish_state(id(yearly_counter_pulses));
id(current_water_consumption).publish_state(id(event_quantity));time:
- platform: sntp
on_time:
- seconds: 0
minutes: 0
hours: 0
then:
- globals.set:
value: ‘0’- lambda: id(water_daily_consumption).publish_state(id(daily_counter_pulses));
- seconds: 0
minutes: 0
hours: 0
days_of_week: MON
then:
- globals.set:
value: ‘0’- lambda: id(water_weekly_consumption).publish_state(id(weekly_counter_pulses));
- seconds: 0
minutes: 0
hours: 0
days_of_month: 1
then:
- globals.set:
value: ‘0’- lambda: id(water_monthly_consumption).publish_state(id(monthly_counter_pulses));
- seconds: 0
minutes: 0
hours: 0
days_of_month: 1
months: JAN
then:
- globals.set:
value: ‘0’- lambda: id(water_yearly_consumption).publish_state(id(yearly_counter_pulses))
So can anybody help me what’s “wrong”?
