Camera, Frigate: Intelligent AI-powered notifications
when is the Release? sorry so excited
Trying to get it out this week. There are some big changes though and still some open issues I want to fix first.
But if you need more reasons to be excited about v1.3:
LLM Vision will soon be able to remember events so you can ask about them later!
Very cool!
Here’s some screenshots of what i’m seeing.
Yes i have a local IP address for frigate, so i know there is a natural limit. Sounds very promising with the overview! Looking forward to it.
Yes, i can also confirm that the sensor is always recording, so i’ll try with the binary sensor instead.
You seem to get a lot of notifications! I strongly recommend using cooldown to reduce the number of requests as this will burn through tokens quickly. You can also use important to only get notifications when an important event is detected.
Glad you find this useful though!
Yes i know :slight_smile:
Have you thought about adding the option of time limitations in the blueprint? For example, i would love for this to be enabled at night and when im away, but it’s not necessary when im at home and all day long.
That’s great thank you :slight_smile:
same request as strux and in addition is it possible to send a notification to two people?
THANKS :slight_smile:
I am not a big fan of Frigate and use Blue Iris. Will this still work?
I’m loving this blueprint so far. Very good work, thank you.
Will there be an option to only get notified, when not home or in a zone? When I’m home I don’t want to be notified, mostly because I’m triggering the cameras myself.
Also I get the same errors regarding not being able to fetch the image. I’m accessing the HA instance with nabucasa when I’m not home. So my iPhone is never able to reach the local IP of HA.
Got it. I’ll add time and zone conditions as well as notifications to multiple devices soon!
As long as you have camera entities in home assistant that change their state or some binary_sensor entities that get triggered when something happens, this will still work.
Thank you so much for your response. So something like binary_sensor.XXXXX_nvr_driveway_motion would work?
Yes exactly. The automation will be triggered by the on state of a binary sensor. You can add multiple cameras and each camera can have its own binary sensor. Just add them in the same order.
Thank you. I will give this a whirl.
v1.3 of LLM Vision is out now and with it an updated blueprint.
Most notably frigate_url is no longer required. Instead previews are now fetched internally through the Frigate Integration.
For ‘Camera’ mode you can now also choose between a live preview and a snapshot of the actual event.
The biggest update to the integration is the new option to remember events. This adds a calendar entity, so you can easily see what’s been happening at a glance. It also enables asking about past events. You can read more about that here:
https://llm-vision.gitbook.io/getting-started/asking-about-events
This is step two of making your cameras smarter and more useful and follows last release, which rethought how camera notifications should work. The next step is to integrate LLM Vision even more into your dashboard. Stay tuned!
An issue with the new blueprint. When I select snapshot, I get no picture in the notification. But the image is processed and I do get an AI response.
One final issue. Is it possible to send the notification to multiple recipients? Now I can only choose my phone.
Hmm the new blueprint doesn’t fire when on Frigate mode. I have it on Frigate mode and set the frigate entities, but it doesn’t fire
Did you update the integration as well? There are some changes that enable including the snapshot in the notification. You also need to have the Frigate Integration istalled.
You can verify the snapshot was created by checking if the image is in /www/llmvision.
Sending the notification to multiple devices is something I’m working on right now!
I assume by Frigate entities you mean the cameras.
Have you renamed them or changed their ids? They need to have the same entity_id as in Frigate.
If no, could you check the traces of your automation? Are there any errors?
I wasn’t getting any errors and the entity IDs were the same. I got it working by using Camera mode. However, now I get duplicate notifications. The initial notification that has a picture and a motion detected caption, and then a second layer I get a notification with the LLM vision description
