For those that has a raspberry pi camera, I will show how to use HA web server to serve full rate great quality stream with HLS, with absolute no encoding (CPU<3%).
This is for ‘env’ install under homeassistant user:
- Let homeassistant user open video camera:
sudo usermod -a -G video homeassistant
- Create a directory to static access for HA (www)
cd /home/homeassistant/.homeassistant
mkdir www
Restart HA (needed to read new www dir)
Install a HLS player plugin on your favorite browser I.e for firefox: https://addons.mozilla.org/es/firefox/addon/native_hls_playback/ or for chrome: https://chrome.google.com/webstore/detail/native-hls-playback/emnphkkblegpebimobpbekeedfgemhof
run the camera at /home/homeassistant/.homeassistant/www
ffmpeg -y -f video4linux2 -input_format h264 -video_size 1280x720 -framerate 15 -i /dev/video0 -vcodec copy -an -f hls -hls_flags delete_segments stream.m3u8
This will create (and update) a m3u8 file and some .ts parts of h264 captured video. (Control-c or ‘q’ to stop it)
With ffmpeg runnig, open your browser and navigate to
http://your.homeasistant.baseurl/local/stream.m38u
(changing your.homeasistant.baseurl)
…et voilà !
You can see the pi camera 720p@15fps on your HA browser, with almost zero CPU!!! on your RPI (and a minimum delay of 5 secs for how HLS works)
Please, take into accout that this is only a proof-of-concept, with no security considerations,etc.
Now, if you like it, follow this post, to see if anybody can help in how to integrate this in lovelace HA (so you can start-stop camera stream automatically when open the camera (to not waste your sdcard), not depend in HLS plugin, etc.)
HLS is a standard for video-stream prior to webm stuff, supported by all browsers with javascript, even Safari (builtin).
