I would like to be able to manually trigger my camera to take a snapshot but not sure of the easiest way to configure this.
I thought I had solved this by creating an automation with an “always true” trigger, then whenever I wanted a snapshot, I simply enabled the automation for a brief moment, then disabled it again.
The always true trigger I used was:
platform: template
value_template: "{% if 1 %}true{% endif %}"
The trouble with this trigger is that the automation comes back online (after rebooting Hass.io) as enabled and immediately takes a snapshot (and as part of my desired automation, sends the snaphot to me by Pushbullet). I am now rebooting Hass.io every other night to try and solve the occasional unwanted crashes (host working, but HA unresponsive) and I do not want snapshots being sent to me by Pushbullet at 2am when this happens!
Is there an automation trigger I can use that will allow me to run this automation by clicking on a button in the HA UI?
An alternative - I may be able to use Tasker to run the automation from an api call? I already run other automations this way so perhaps this is the easiest answer!
I will post back my code if I can configure Tasker to achieve this.
Why don’t you put the action of your automation in a script and call it from the UI?
Thanks - this is what I wanted.
I did not have any scripts before and did not understand how to use them, but now have re-written my automation in script syntax and it works perfectly.
For anyone else interested, here is the original automation, usually triggered by PIR sensor movement etc.:
- alias: 'Living Room Security Camera'
platform: state
entity_id: sensor.living_room_pir
to: 'ON'
condition: and
conditions:
- condition: state
entity_id: 'device_tracker.julian_phone'
state: 'not_home'
- condition: state
entity_id: 'device_tracker.anne_phone'
state: 'not_home'
- service: camera.snapshot
entity_id: camera.minicam
filename: '/config/snapshots/MiniCamSnap.jpg'
filename: '/config/snapshots/MiniCam_{{ now().strftime("%Y%m%d-%H%M%S") }}.jpg'
- service: notify.pushfromha
file: '/config/snapshots/MiniCamSnap.jpg'
title: "Living Room Snapshot Taken"
message: "A snapshot has been taken in the Living Room"
and here is the stand-alone script which allows me to trigger a snapshot from this camera at any time, using the web UI:
living_room_snapshot:
alias: 'Living Room Snapshot'
