So I have a XAP800 mic controller I use as multiroom audio.
To use it I have this custom component (GitHub - jslove/xap_controller: Home Assistant platform to use a Gentner / Clearone XAP unit as an audio matrix) that works flawlessly, but only if the xap800 device is powered when homeassistant starts (or restarts).
I’m an exOpenHab user, and there i was able to turn the device ON with a smart plug only when needed, while if I do it in homeassistant with that custom component, entities won’t show up unless the device was ON when HA starts.
Is there any way to fix this? like loading the custom component (that has a “connect” section in it) after I turn on the device?
Any help will be very appreciated.
