The automation’s condition
will only allow the action
to be executed if device_tracker.wills_pixel_5
is not home.
Are you testing this automation while your pixel_5 is not home?
is not home.
Yes, I am away from home at the moment.
When the binary_sensor changes from off
to on
does the automation update its LastTriggered time? It’s displayed next the automation’s name in Configuration > Automations.
As I mentioned before you can use a service call to troubleshoot this. Now I am at my PC here is more information (courtesy of Tinkerer)
To test an automation there’s three stages you can follow. Testing the action, the condition and action, and the whole automation:
If they all work, and your automation didn’t run, it’s probably turned off.
