Thanks, I’ll give it a go when I get home.
I played around with indention and dashes and placing it directly under the - service but it tells me my configuration is invalid.
Configuration invalid
Error loading /config/configuration.yaml: while parsing a block collection in “/config/automations.yaml”, line 2, column 1 expected <block end>, but found ‘?’ in “/config/automations.yaml”, line 31, column 1
line 2 is the - id: and 31 is the start of the rest_command:
automations.yaml file
#automations.yaml TEST file
- id: Kitchen_light_test_on
alias: Turn on Kitchen light when door opened
- platform: state
entity_id: binary_sensor.dome_dw_sensor1_112
to: 'on'
condition:
condition: or
conditions:
- condition: sun
after: sunset
after_offset: "-01:00:00"
- condition: sun
before: sunrise
before_offset: "+01:00:00"
- service: homeassistant.turn_on
entity_id:
- light.kit_eat_light_dim_14
- light.kitchen_light_104
- service: rest_command.play_fdo_sound
- delay: '00:00:10'
- service: homeassistant.turn_off
entity_id:
rest_command:
play_fdo_sound:
url: 'http://192.168.0.201/sound.php?file=fdo&volume=100'
#automations.yaml TEST file end
I cleared my automatons.yaml and moved the code to my configuration.yaml
it works when in the configuration.yaml … I guess I need to learn these spaces and dashes rules when in a file.
can I have two automatons on 1 trigger? One in configuration.yaml and another in automatons.yaml?
automation:
- platform: state
to: 'on'
condition:
condition: or
conditions:
- condition: sun
after: sunset
- condition: sun
before: sunrise
entity_id:
- delay: '00:00:10'
entity_id:
rest_command:
play_fdo_sound:
url: "http://192.168.0.201/sound.php?file=fdo&volume=100"
Hmm that would be messy, if it could…
If you have a sequence of tasks, write them into scripts and call them by an automation.
P.S. Yes, this space and tab thing in YAML was quite new for me and irritating. I use Visual Studio Code with Jinja and YAML plugins, this make things easier
I may try Visual Studio. Yes, it seems (to me) that the syntax is different between the configuration.yaml and automations.yaml and other yaml files
I was thinking of two separate task driven by a single sensor but two different files. Like, one for the sound and one for the lights on/off
I’ve have two automation: scripts that work perfectly in the configuration.yaml but only one in the configuration.yaml file at a time
with both automations in the configuration.yaml file, they both turn_on and off the lights but only the last one listed will run play the sound.
################################################################# automation:TEST
automation test:
alias: Both Kitchen light on then off when door opened
- platform: state
to: 'on'
entity_id:
- delay: '00:00:10'
entity_id:
rest_command:
play_fdo_sound:
################################################################# automation: TEST end
## Play Kitchen Door Open
automation KDO:
- id: kitchenDoor_open
alias: Breakfast light only when Kitchen Door Open
- platform: state
entity_id: binary_sensor.kitchen_door_1_65
to: 'on'
entity_id:
- service: rest_command.play_kdo_sound
- delay: '00:00:10'
entity_id:
rest_command:
play_kdo_sound:
url: "http://192.168.0.201/sound.php?file=kdo&volume=100"
## Play Kitchen Door Open end
i will endeavor to persevere… and I have no idea why the code above looks grayed out
this is the error message in the log each time the automation is run.
WARNING (MainThread) [homeassistant.core] Unable to find service rest_command/play_fdo_sound
splitting it up is the plan. I’d just like to get 2 working in the configuration.yaml
download/installing Visual Studio Code now. I don’t see Jinja and YAML as an option. Are the plugins installed after the install? Are there dependencies?
nevermind, “the google” is my friend.
[rant]The Automation Editor documentation is seriously lacking.
To add the lights it took me a good bit of googling to figure out what it wanted between the “Service Data” {} section of the automation.
in my case it’s
“entity_id”: “binary_sensor.kitchen_door_1_65”
or
“entity_id”: “light.kitchen_light_104”
for the two lights I’m testing with.
I think the documentation examples in the official documentation should include examples that are actually useful.
[/rant]
Well, got it to work with two automaintions
I stripped the automation:s out of the configuration,yaml
started with an empty automations.yaml
used the Automation Editor under configuration\Automation
created two new automations with lights turning on /then off.
in the “actions” under “service call” I noticed that rest_command.play_kdo_sound was a choice but not rest_command.play_fdo_sound. (now I could consistently get one of them to play but not both and it depended which one came first in the configuration.yaml file.)
I hadn’t rebooted yet. I used the rest_command.play_kdo_sound option to see what it placed in the automations file.
it added this…
- alias: ''
url: http://192.168.0.201/sound.php?file=kdo&volume=100
so I modified the configuration.yaml file and added this to the end
rest_command:
play_dsa_mp3:
url: "http://192.168.0.201/sound.php?file=dsa&volume=100"
play_kdo_mp3:
and rebooted the Hass.io
At that point both rest_command: choices showed up under “actions” under “service call”
so I modified the automations.yaml to renaming the play sound options to read as follows.
- id: '1535144973178'
alias: DomeTest
- entity_id: binary_sensor.dome_dw_sensor1_112
platform: state
to: 'on'
condition: []
- data:
entity_id: light.kit_eat_light_dim_14
service: light.turn_on
- delay: 00:00:10
- data:
service: light.turn_off
- alias: ''
service: rest_command.play_dsa_mp3
url: http://192.168.0.201/sound.php?file=dsa&volume=100
- id: '1535146352770'
alias: KD Automation
- entity_id: binary_sensor.kitchen_door_1_65
platform: state
to: 'on'
condition: []
- service: light.turn_on
entity_id: light.kitchen_light_104
- delay: 00:00:10
- service: light.turn_off
- alias: ''
service: rest_command.play_kdo_mp3
so now I wonder if there’s a way to call a url in an automation without having to define rest commands in the configuration.yaml?
The documentation, like all of home-assistant, is open source. Please submit your suggested changes.
Rebooting hass sucks, I know… I have a huge configuration and it takes lots of time for that.
So, for some use cases, I create bash scripts, when I know I want test and/or change the call several times.
shell_command:
parse_phrase: "sudo /usr/sbin/parse_snips.sh '{{states('sensor.mqqt_tasker_phrase')}}'"
parse_input_text: "sudo /usr/sbin/parse_snips.sh '{{states('input_text.tasker_phrase')}}'"
If you want, I give you detailed information.
tl;tr
You only have to change the bash script without rebooting hass everytime…
I am interested. I intend to explore scripts but hadn’t gotten there yet. I’ve only had HA for a week and have only used the “Automation Editor” for a day.
I have found that rearranging the order from the "Automation Editor"s order has sped things up a bit.
alias: DomeTest
platform: state
to: 'on'
condition: []
- alias: 'play_dsa_mp3'
- delay: 00:00:10
- data:
platform: state
to: 'on'
condition: []
- alias: 'play_kdo_mp3'
- delay: 00:00:10
Where would I submit my suggested changes to the documentation, I think some real world examples that included actual lights and sensors would have sped my success up a little bit and reduced my questions on here.
Just go to the doc page and look for “edit this page on github”, open an issue with your suggestion.
Okay, I will try to make a general example easy to understand… d’oh
thanks…
I have set up automation to tell me a door, gate, or window is open @ 23:00.
I have two gates I’d like to get repeat notification that they are open until closed.
With the previous code, I get a notification that the gate is open.
With the below code, it waits 5 minutes and then notifies continuously.
I’ve tried placing - delay: '00:01:00'
, repeat: 10
and initial_state: 'off and on'
in various places but it always goes into non stop execution of the url: http://192.168.0.201/sound.php?file=test&volume=100
- id: '1535307883175'
alias: A dome test if sensor is triggered and left open
- minutes: "/5"
platform: time
condition:
- condition: state
state: 'on'
- data:
service: rest_command.play_test_mp3
I looked at Alert also… any suggestions?
so I have it working well enough that I think I’m done fiddling with it but here’s something funny.
I have my dome test sensor and two gate sensors using time trigger
seconds: 15
platform: time
and here’s what’s funny, some how seconds: 15
translates into 1 minute. I think it’s supposed to trigger @ 15 seconds past the top of each minute.
The dome test will trigger @ 30 seconds past the top of the minute, and the gate triggers @ 45 seconds from the top of the minute. regardless of when it was opened.
very odd
right now I have two automatons for them, one when it opens, and one if it’s left open. I’d like to combine them but this works for now.
- id: '1535308795832'
alias: a dome test if sensor triggered
platform: state
to: 'on'
condition: []
- id: '1535653515479'
alias: a dome test if sensor triggered left open
seconds: 15
platform: time
condition:
- condition: state
state: 'on'
- service: rest_command.play_test_mp3
I also learned that the -data
and url:
code in unnecessary in the automation.yaml.
So for all the newbies like me here’s what I’ve ended up using to tell me around 11pm if a door or window is open and if a gate was left open anytime (can’t let the dogs get out).
I haven’t removed the -data
and url:
code from the top of the file yet but have from the end of the file.
so here’s what’s in the configuration.yaml to make the rest
commands work.
configuration.yaml
rest_command:
play_ldo_mp3:
url: "http://192.168.0.201/sound.php?file=ldo&volume=100"
play_kdo_mp3:
play_ugo_mp3:
url: "http://192.168.0.201/sound.php?file=ugo&volume=100"
play_lgo_mp3:
url: "http://192.168.0.201/sound.php?file=lgo&volume=100"
play_gbdo_mp3:
url: "http://192.168.0.201/sound.php?file=gbdo&volume=100"
play_sgd_mp3:
url: "http://192.168.0.201/sound.php?file=sgd&volume=100"
play_fdo_mp3:
play_jwoje_mp3:
url: "http://192.168.0.201/sound.php?file=jwoje&volume=100"
play_egdo_mp3:
url: "http://192.168.0.201/sound.php?file=egdo&volume=100"
play_wgdo_mp3:
url: "http://192.168.0.201/sound.php?file=wgdo&volume=100"
play_basementdo_mp3:
url: "http://192.168.0.201/sound.php?file=basementdo&volume=100"
play_wugro_mp3:
url: "http://192.168.0.201/sound.php?file=wugro&volume=100"
play_wlgro_mp3:
url: "http://192.168.0.201/sound.php?file=wlgro&volume=100"
play_test_mp3:
url: "http://192.168.0.201/sound.php?file=test&volume=100"
and the automatons.yaml
alias: Laundyroom Door Open
- entity_id: binary_sensor.laundyroomdoor_113
platform: state
to: 'on'
condition: []
- alias: play_ldo_mp3
url: http://192.168.0.201/sound.php?file=ldo&volume=100
service: rest_command.play_ldo_mp3
alias: Kitchen Door Open
platform: state
to: 'on'
condition: []
- alias: play_kdo_mp3
- id: '1535247958715'
alias: Upper Gate Open
- entity_id: binary_sensor.upper_gate_119
platform: state
to: 'on'
condition: []
- data:
url: http://192.168.0.201/sound.php?file=ugo&volume=100
service: rest_command.play_ugo_mp3
- id: '1535248438903'
alias: Lower Gate open
- entity_id: binary_sensor.lower_gate_121
platform: state
to: 'on'
condition: []
- data:
url: http://192.168.0.201/sound.php?file=lgo&volume=100
service: rest_command.play_lgo_mp3
- id: '1535248542354'
alias: Garage Back Door Open
- entity_id: binary_sensor.back_door_1_69
platform: state
to: 'on'
condition: []
- data:
url: http://192.168.0.201/sound.php?file=gbdo&volume=100
service: rest_command.play_gbdo_mp3
- id: '1535248625309'
alias: Sliding Glass Door Open
- entity_id: binary_sensor.sliding_glass_door_109
platform: state
to: 'on'
condition: []
- data:
url: http://192.168.0.201/sound.php?file=sgd&volume=100
service: rest_command.play_sgd_mp3
- id: '1535248693332'
alias: Front Door Open
- entity_id: binary_sensor.front_door_1_67
platform: state
to: 'on'
condition: []
- data:
url: http://192.168.0.201/sound.php?file=fdo&volume=100
service: rest_command.play_fdo_mp3
- id: '1535248913198'
alias: Jackies Window Open
- entity_id: binary_sensor.jnorthwindow_59
platform: state
to: 'on'
- entity_id: binary_sensor.jsouthwindow_75
platform: state
to: 'on'
condition: []
- data:
url: http://192.168.0.201/sound.php?file=jwoje&volume=100
service: rest_command.play_jwoje_mp3
- id: '1535249068830'
alias: Garage Door East
- entity_id: binary_sensor.garage_door_e_1_68
platform: state
to: 'on'
condition: []
- data:
url: http://192.168.0.201/sound.php?file=egdo&volume=100
service: rest_command.play_egdo_mp3
- id: '1535249173346'
alias: Garage Door West
- entity_id: binary_sensor.garage_door_w_111
platform: state
to: 'on'
condition: []
- data:
url: http://192.168.0.201/sound.php?file=wgdo&volume=100
service: rest_command.play_wgdo_mp3
- id: '1535249320393'
alias: Basement Door Open
- entity_id: binary_sensor.basement_door_1_71
platform: state
to: 'on'
condition: []
- data:
url: http://192.168.0.201/sound.php?file=basementdo&volume=100
service: rest_command.play_basementdo_mp3
- id: '1535298612412'
alias: zCheck Garage Back Door Open
- at: '23:00:00'
platform: time
condition:
- condition: state
state: 'on'
- data:
- id: '1535298954391'
alias: zCheck for Basement Door Open
- at: '23:00:10'
platform: time
condition:
- condition: state
state: 'on'
- data:
- id: '1535299146090'
alias: zCheck for Front Door Open
- at: '23:00:20'
platform: time
condition:
- condition: state
state: 'on'
- data:
- id: '1535299366780'
alias: zCheck for Garage Door (East) Open
- at: '23:00:30'
platform: time
condition:
- condition: state
state: 'on'
- data:
- id: '1535299540894'
alias: zCheck for Garage Door (west) Open
- at: '23:00:40'
platform: time
condition:
- condition: state
state: 'on'
- data:
- id: '1535299677281'
alias: zCheck for Jackies North Window Open
- at: '23:00:50'
platform: time
condition:
- condition: state
state: 'on'
- data:
- id: '1535299794185'
alias: zCheck for Jackies South Window Open
- at: '23:01:00'
platform: time
condition:
- condition: state
state: 'on'
- data:
- id: '1535299926498'
alias: zCheck for Kitchen Door Open
- at: '23:01:10'
platform: time
condition:
- condition: state
state: 'on'
- data:
- id: '1535300084373'
alias: zCheck for Laundyroom Door Open
- at: '23:01:20'
platform: time
condition:
- condition: state
state: 'on'
- data:
- id: '1535300388286'
alias: zCheck for Sliding Glass Door Open
- at: '23:01:30'
platform: time
condition:
- condition: state
state: 'on'
- data:
- id: '1535300520317'
alias: zCheck for Upper Gate Open
seconds: 30
platform: time
condition:
- condition: state
state: 'on'
service: rest_command.play_wugro_mp3
- id: '1535300242557'
alias: zCheck for Lower Gate Open
seconds: 30
platform: time
condition:
- condition: state
state: 'on'
service: rest_command.play_wlgro_mp3
platform: state
to: 'on'
condition: []
seconds: 15
platform: time
condition:
- condition: state
state: 'on'
Could I have used the - platform: command_line
as seen in this thread?
command: curl -i http://192.168.0.1
as it turns out, this not unreliable enough to be “production”. I can open and close a door repeatedly and it will work. but if there’s an interval of a few hours it may or may not work.
I see the below error in the log
2018-09-30 12:09:29 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall rest_command.play_ugo_mp3 (c:b061d8b773764a35b8871a44b282734b): url=http://192.168.0.201/sound.php?file=ugo&volume=100>
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/rest_command.py", line 105, in async_service_handler
headers=headers
File "/usr/local/lib/python3.6/site-packages/aiohttp/client.py", line 370, in _request
timeout=timeout
File "/usr/local/lib/python3.6/site-packages/aiohttp/connector.py", line 445, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.6/site-packages/aiohttp/connector.py", line 757, in _create_connection
File "/usr/local/lib/python3.6/site-packages/aiohttp/connector.py", line 862, in _create_direct_connection
req=req, client_error=client_error)
File "/usr/local/lib/python3.6/site-packages/aiohttp/connector.py", line 822, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs)
File "uvloop/loop.pyx", line 1871, in create_connection
File "uvloop/loop.pyx", line 1860, in uvloop.loop.Loop.create_connection
concurrent.futures._base.CancelledError
headers=headers
File "/usr/local/lib/python3.6/site-packages/async_timeout/__init__.py", line 45, in __exit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.6/site-packages/async_timeout/__init__.py", line 92, in _do_exit
raise asyncio.TimeoutError
concurrent.futures._base.TimeoutError
File "/usr/local/lib/python3.6/site-packages/homeassistant/core.py", line 1177, in _event_to_service_call
await service_handler.func(service_call)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/rest_command.py", line 115, in async_service_handler
_LOGGER.warning("Timeout call %s.", request.url)
UnboundLocalError: local variable 'request' referenced before assignment
