Is that a zero or the letter O before 5?
@petro I am sure that there is a number 0 in front of 5, but, in any case, I tried to copy it from the output to my template and it did not help.
@Mariusthvdb, I will try it, thank you.
Send me more suggestions if you have any, but I am leaving on the business trip shortly and will not be back until Friday. I will try it all when I come back.
And guys, thank you very much for your help!!
In the dev tool template editor type in the following and see what the result is:
{{ states.sensor.alarm_panel_display.state }}
{{ is_state(‘sensor.alarm_panel_display’, ‘FAULT 05’) }}
The first line of the template editor will show you the actual status of the sensor and the second line will show you the result of the ‘is_state’ test. when you get a ‘FAULT 05’ for the status of ‘sensor.alarm_panel_display’ the result of the test in the template editor should show as True. Otherwise, for all other values of ‘sensor.alarm_panel_display’ you should get a response of False.
Open and then close the door that should give you a ‘FAULT 05’. you should see things changing in the template editor result area.
I am not home, but I found that my zone 3 was opened, so I tested it with Zone 3. Interesting result.
First, I tried this:
{{ is_state('sensor.alarm_panel_display', 'FAULT 03') }}
The output was FAULT 03 and False.
After that, I notices that it looks like there are some spaces in the end of FALSE 3. I copied the full line with FAULT 3 and pasted it as is:
{{ is_state('sensor.alarm_panel_display', 'FAULT 03 ') }}
This gave me
FAULT 03 and True.
I guess, I have to find exact number of spaces after FAULT numbers and use them.
Thank you for your help.
just do this:
{{ states('sensor.alarm_panel_display').strip() == 'FAULT 03' }}
It will remove leading and trailing whitespace. Personally, I’d write a bug against the component. You shouldn’t have to strip whitespace.
It worked. Thank you for your help.
