I use OctoPrint and, as I turn off the 3D printer when it is not in use, a lot of entities get stuck “unavailable”.
I found this topic when I was searching to write an automation to reload the integration.
While I did not find one to reload the integration, the solution to OctoPrint for me was using service HOMEASSISTANT.RELOAD_CONFIG_ENTRY, Home Assistant Core Integration - Home Assistant (home-assistant.io)
One entity of Octoprint responds even with power cycling the printer, the status of the printer, so I used that as a trigger and reloaded the entire entity using the homeassistant.reload_config_entry option.
It works for a per device and reloads all entities of that device.
I certainly would not want to muck around doing this for ZigBee though given I have over 40 ZigBee devices.
A reload Integration service would definitely be helpful.
Never use Early Access in a prod environment, or an environment where a partner may be involved.
Anyway, that is a bit off topic and I don’t want to hijack another thread lol
Great tip.
I also turn off my printer when it is not in use ( Ender 3 ) and everytime I launch HA and my printer is OFFLINE I get error that HA could not make connection with Octoprint!
I`m using MQTT plugin within Octoprint so I think I do not need the Octoprint integration. Just deleted it.
I`m haging issues with ESPHOME and ZIGBEE they turn unavailable multiple times per day and I wonder if it is not due to the Octoprint integration. Will see, just deleted the bloody Octoprint integration.
Same Problem with Meross Mss310 (Energy Monitoring). I think it’s because of calling too much for information. I experienced same thing when I wanted to make a script flash the lights (switch), it just made the Plugin stop working, probably because of overload.
Don’t know how to fix the request problem right now (limitation of request probably) so I thought of the easy way… Reload the Plugin
I will play with the rate and burst limits a bit and see if that helps.
I will report, maybe that helps others too.
Some of my integrations also need reloading from time to time (Wiser, IKEA) and I’m really interested in a solution to this. Am thinking a button to reload a specific integration and an automation to “press” that button.
I frequently need to restart the Home Connect integration. I’m using the Reload Config Entry service twice a day now, and I’ve not needed to restart the integration itself since implementing this. You might be able to use Reload Config Entry in a similar way - it’s worth a try.
I had troubles with my tuya integration. Somehow the temperatures shown only were correct in the first moments after a restart or reloading the config. After that the temps were way off so scripts to set the temp on my floor heating were firing at the wrong temps. Since I couldnt get a fix on the temps and it wasn’t a fixed offset that needed to be applied I now use a reload script like mention above by @arrows and it looks like this:
Looks like I’m not the only one affected by Tuya stalling. Same issue brought me here, thanks a lot for the tip. Mine is with doors sensors stopping to report statuses though.
I’m afraid I have that problem as well. It seems to be a seperate problem from the Tuya issue, since my door sensors (aqara) connect to a Conbee II dongle, and I use a couple of IKEA range extenders to increase the range. Works most of the time, but one of the least used doors sometimes just goes unavailable. So annoying.
