These errors came up in my log and my device tracker is not working anymore. How can I get the asuswrt working again?
Home Assistant is installed on VM with Ubuntu but this was working with no problems before,
see below my log.
2019-01-24 20:19:18 ERROR (MainThread) [homeassistant.setup] Error during setup of component asuswrt
File “/usr/local/lib/python3.6/site-packages/homeassistant/setup.py”, line 145, in _async_setup_component
hass, processed_config)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/asuswrt.py”, line 61, in async_setup
await api.connection.async_connect()
File “/usr/local/lib/python3.6/site-packages/aioasuswrt/connection.py”, line 66, in async_connect
self._client = await asyncssh.connect(self._host, **kwargs)
File “/usr/local/lib/python3.6/site-packages/asyncssh/misc.py”, line 182, in await
return (yield from self._coro)
File “/usr/local/lib/python3.6/site-packages/asyncssh/connection.py”, line 5454, in connect
conn, _ = yield from create_connection(None, host, port, **kwargs)
File “/usr/local/lib/python3.6/site-packages/asyncssh/connection.py”, line 5110, in create_connection
yield from auth_waiter
File “/usr/local/lib/python3.6/site-packages/asyncssh/connection.py”, line 627, in data_received
while self._inpbuf and self._recv_handler():
File “/usr/local/lib/python3.6/site-packages/asyncssh/connection.py”, line 847, in _recv_packet
processed = handler.process_packet(pkttype, seq, packet)
File “/usr/local/lib/python3.6/site-packages/asyncssh/packet.py”, line 215, in process_packet
self._packet_handlers[pkttype](self, pkttype, pktid, packet)
File “/usr/local/lib/python3.6/site-packages/asyncssh/connection.py”, line 1414, in _process_kexinit
self._kex = get_kex(self, kex_alg)
File “/usr/local/lib/python3.6/site-packages/asyncssh/kex.py”, line 122, in get_kex
return handler(alg, conn, hash_alg, *args)
File “/usr/local/lib/python3.6/site-packages/asyncssh/kex_ecdh.py”, line 47, in init
self._priv = ecdh_class(args)
File “/usr/local/lib/python3.6/site-packages/asyncssh/crypto/curve25519.py”, line 31, in init
self._priv_key = x25519.X25519PrivateKey.generate()
File “/usr/local/lib/python3.6/site-packages/cryptography/hazmat/primitives/asymmetric/x25519.py”, line 39, in generate
_Reasons.UNSUPPORTED_EXCHANGE_ALGORITHM
cryptography.exceptions.UnsupportedAlgorithm: X25519 is not supported by this version of OpenSSL.
2019-01-24 20:19:23 WARNING (MainThread) [homeassistant.components.device_tracker] Duplicate device MAC addresses detected C8:60:00:70:1F:E9
2019-01-24 20:19:23 WARNING (MainThread) [homeassistant.components.device_tracker] Duplicate device MAC addresses detected 9C:AD:EF:21:86:9F
2019-01-24 20:19:23 WARNING (MainThread) [homeassistant.components.device_tracker] Duplicate device MAC addresses detected 00:0E:58:C2:04:6C
2019-01-24 20:19:23 WARNING (MainThread) [homeassistant.components.device_tracker] Duplicate device MAC addresses detected 5C:AA:FD:24:0D:EC
2019-01-24 20:19:23 WARNING (MainThread) [homeassistant.components.device_tracker] Duplicate device MAC addresses detected 08:00:27:2B:11:F7
2019-01-24 20:19:23 WARNING (MainThread) [homeassistant.components.device_tracker] Duplicate device MAC addresses detected 00:0E:58:89:74:0A
2019-01-24 20:19:23 WARNING (MainThread) [homeassistant.components.device_tracker] Duplicate device MAC addresses detected 48:5D:60:39:6C:C6
2019-01-24 20:19:23 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of device_tracker.asuswrt. Setup failed for dependencies: asuswrt
2019-01-24 20:19:23 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform device_tracker.asuswrt: Could not set up all dependencies.
2019-01-24 20:19:27 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform darksky is taking over 10 seconds.
2019-01-24 20:19:28 WARNING (MainThread) [homeassistant.components.scene] Setup of platform vera is taking over 10 seconds.
2019-01-24 20:19:49 WARNING (SyncWorker_2) [plexapi] BadRequest (401) unauthorized http://192.168.1.153:32400/; Unauthorized
