HScholing
(Hendry Scholing)
October 30, 2018, 7:21pm
1
Newbie here trying to start automating my home. I own a Hue motion sensor placed in my hallway. I made an entry in my automations.yaml with the help of this cookbook: https://www.home-assistant.io/cookbook/turn_on_light_for_10_minutes_when_motion_detected/
When the motion sensor detects motion I now see in my logging
Error updating Hue sensors
20:12 custom_components/sensor/hue.py (ERROR)
I’m using the custom component: https://github.com/robmarkcole/Hue-sensors-HASS
Can somebody tell me where to find out why my sensor is not working? I can operate the Hue bulbs and the state of the sensor is also shown in my dashboard. Maybe you guys have a better component I have to use?
m0wlheld
(Christoph Dahlen)
October 31, 2018, 6:22am
2
Don’t know about the custom component, but I use the generic REST sensor and it works perfectly with the Hue motion sensor.
I’ve been having problems with the custom component for the last couple of weeks, suddenly stops updating from the sensors for no apparent reason.
HScholing
(Hendry Scholing)
October 31, 2018, 11:39am
4
Can you share your configuration?
m0wlheld
(Christoph Dahlen)
October 31, 2018, 7:51pm
5
The configuration is easy, but it is required to do some things in advance: Tutorial adding HUE Motion sensor (Lux,Temp and Motion)
HScholing
(Hendry Scholing)
November 5, 2018, 6:32pm
6
Thanks m0wlheld, this solution is now working for me, only had to add some modification for the LUX calculation. Thank you!
