Cannot connect Xiaomi Gateway (lumi.gateway.v3) to HA
Ah sorry, that link used to take you directly to the post I was referring to, it must’ve changed. I found it and just copied the text, but all the credit goes to the guy at the end of it.
well, tried to set param network.open_pf to 3 - it helped me!
Can see gateway in openhab, iobroker and 9898 port is opened.
FAQ:
  1. Find specific screw bit like fork to open gateway case.
  2. Find UART cable/board.
  3. Solder 3 wires GND and RX / TX like here (Image .
  4. Disconnect RX wire from UART module.
  5. Dont connect Vcc (power) from UART to gateway.
  6. Turn on gateway (220V).
  7. Open putty application, connect to serial port (COM1-30) -select yours one0.
  8. Wait for fully load of gateway, connect RX wire to UART.
  9. You will see all messages of gateway.
  10. Send command psm-set network.open_pf 3 , send it few time in case it was spammed by gateway and it can be lost in msgs…
  11. Check your param by command psm-get network.open_pf to be sure its OK.
  12. Turn off gateway.
  13. Turn it ON.
  14. Check your port.
  15. Say thx to this guy - ds2003
