Well from what I’ve read on here, mine is a IBBQ-4T V2 which merges all temps into one DP (DP107). The info derived from my unit seems to match that claim. The yaml I am talking about comes from Tuya-Local. If you go into custom_components\tuya_local\devices folder it’s in there. That is the yaml file Tuya_Local uses to define my device. What I can’t figure out is why it manages to perfectly show Probe2 and Probe4 but messes up on Probe1 and Probe3 even though the code is exactly the same.
you need to “devide” this into 4 sensors type-input, read above ( sensor 1 , 2 , 3 , 4 )
I pretty sure one can not do that in YAML, most likely a .js or jinja
Anyway i have no such Device, and wouldn’t need HA to be a part of my cooking, specially not if i had a device already, in hand , with probes connected, and with Alarm etc
I just popped in here (again !, saw it last year also i think) as it seemed like someone needed to know where to find DP’s etc.
(Id better Mute this Topic … someone should change the Topic Header to ( Setup IBBC-4T )
Hey @kbrown01 could you share your meatmaptemp situation here as far as setting the doneness temperatures? You must have done some logic with the currently selected dropdown option.
