claudiosala80: It’s your TV’s mac address
(so that the the network card in TV knows the packet is for it)
Thanks! Solved!
I have the same problem. but the first 2 characters of the mac adress are blue. can that be an isseu?
removed the broadcast_address and port and started to work for me…
Are all of you running this in HASS OS? I am running this in Docker, and even if I enable to wake_on_lan in the configuration.yaml, it still doesn’t work when the TV is off. I am connected via ethernet…
I have this same problem. If I use the remote and turn the tv on, then HA can control the TV, but if its off there is no way to turn it on.
Same problem here. LGwebOS tv is added by the UI integration. Can’t turn the TV on from HA
This may be of use: Reddit - Dive into anything
TLDR: Check if Quick Start+ is enabled, if so this stops WOL from working properly, I was having issues and turned off quick start and voila, it started working with HA the way it should.
In case anyone is still looking this up, please go to this link.
This blueprint released in 2022 for WebOS Smart TV - Turn on for HA solved it for me. make sure to configure the Blueprint after its imported.
