Ok, I have done as advised and now the file has been flashed to the board while I held the boot button down. Then I pressed the RST button on the board and the ESPHomer-Flasher started to do a scan. That finished and now it has stopped at :Using noise encryption: YES.
The led on the board is not flashing anymore
I take it it hasn’t finished yet then
thanks
no, it should say home in the yaml, but the code use that name and adds .local to it to make up the device’s mDNS address.
That home.local should be pingable from the HA installation.
How are you powering the board during the flash?
The serial port devices do usually not have enough power to do the erase part, so you need to power it from a USB port on the same device as your serial port device is connected to and make sure that the power (3V3 or 5V) is not connected on the serial port device.
@WallyR
The board is powered by a USB cable plugged into my laptop.
I thought that it stopped the process but it has suddenly restarted , but it seems to be just logs which is going up the screen.
The actual flashing was Done! flashing is complete! at around 16.43
Then it says:
Showing logs.
And now , again, it has stopped at:
17.07 esp32.preferences:142: Saving 1 preference to flash
I don’t what you mean here:
‘make sure that the power (3V3 or 5V) is not connected on the serial port device.’
USB ports normally put out no more than 5v. Now this USB port would be known as a serial port , for purposes of the esp32 board. There is actually 5.08v getting to the esp32, and if there wasn’t, I doubt it power up.
Anyway, it now looks like it is going round in a loop for some reason, and is back to the point it was earlier: showing the logs.
1- Have you configured the integration after it was discovered? During configuring, it will ask you to type the API key, only then it is added
2- Work around, just comment out the whole API: section.
# Enable Home Assistant API
api:
password: ThisIsMyAPIkey123123!#
I have my key in my secrets file, (using !secret api_password) but for now, just type one here.
This will be the key you have to type in when you add the integration in HA
Well it only repeating what it said an hour ago
[19.22.23][D] [esp32.preferences:142]: Saving 1 preferences to flash
Oh, about 45 minutes ago it said:
Results from I2C bus scan.
that there is an unknown error at address 0x08 etc etc.
My I2C GPIO numbers are pin 21 GPIO21, and pin 22 GPIO22.
I got those from here: ESP32 Pinout and ESP-WROOM-32 Pinout | ESP32 DevKit
I have just found that the GPIO numbers I used are for the Arduino
there are that many different versions of my board and it seems that they all use different GPIO pin numbers. My board has 38 pins in total.
That’s actually only the (“old”) plain password method you are using which doesn’t offer any encryption.
If you want to have a transport encryption you need to provide a key (32-byte base64 encoded string) like described in the docs:
password (Optional, Deprecated, string): The password to protect the API Server with. Defaults to no password. It is recommended to use the encryption → key above instead of the the password.
My esp32-wroom-32 board used to work fine with HA for 2 years until I changed my router, so this why I had to start again. I realised after I said the GPIO pins were for the arduino, that I hav ealways used those same pins on the board.
I have just re installed the yaml file to the boar by the ESPHome Web page and AFAIK it was successful , but it still can’t be added to HA, as it says to make sure there is an API line. Apart from the one with encryption and key, what else .
Ok, try to add it manually then by simply finding ESPHome in the integration list and the type in the IP address and then the API password from your YAMl file.
We can disagree about the “expert” level here. The encryption is not only the default if you create a new esphome node with the dashboard but also is the direct successor of the password which is already deprecated as to the docs.
In any way the problem of @Rob_Heselwood doesn’t actually look be related to the api at this point. Problems are more likely the auto discovery via mDNS or other network related configurations.
That’s already something. You might want to add the web server component to cross check if you can access the esp from your browser to then troubleshoot further.
@aceindy
thanks for that, but it now makes me ask if I should use actual pin numbers as in the link like sda 21 and scl 22, instead of GPIO21 and GPIO21
