Can't connect to ESP. Please make sure your YAML file contains an 'api:' line
I’m beginning to despair. I have been running a Raspberry PI 4 with HassOS for 6 months (actual version 9.5 and HA version “2023.3.5”.
Since the beginning I use the ESPHpme integration, which also ran without problems.
Until about 3 months ago. Since then I can no longer register new devices.
Versions:
Home Assistant 2023.3.5
Supervisor 2023.03.1
Operating System 9.5
Frontend 20230309.1 - latest
ESPHome-Integration: 2023.3.0
ESP appears in the integration menu
I get an error at config the ESP in HA.
Input in HA (Config Device)
Host: 192.168.1.221
Port: 6053
Error: “Can’t connect to ESP. Please make sure your YAML file contains an ‘api:’ line.”
The ESP (Wemos D1 Mini or ESP8266-01) are flashable, accessable, controllable and working problerly via IP.
Two older devives are working problerly
Config-File: ESP-001.yaml
esphome:
friendly_name: esp-001
esp8266:
board: d1_mini
Enable logging
logger:
level: DEBUG
Enable Home Assistant API
api:
encryption:
key: !secret API_Key
Debug-Log - ESPHome (Wemos D1 Mini)
[I][app:102]: ESPHome version 2023.2.4 compiled on Mar 12 2023, 22:54:23
[C][wifi:504]: WiFi:
[C][wifi:362]: Local MAC: 24:A1:60:3A:4A:01
[C][wifi:363]: SSID: ‘FB1204’
[C][wifi:364]: IP Address: 192.168.1.221
[C][wifi:365]: BSSID: 12:16:16:89:0D:3E
[C][wifi:367]: Hostname: ‘ESP-001’
[C][wifi:369]: Signal strength: -63 dB ▂▄▆█
[C][wifi:373]: Channel: 1
[C][wifi:374]: Subnet: 255.255.255.0
[C][wifi:375]: Gateway: 192.168.1.4
[C][wifi:376]: DNS1: 0.0.0.0
[C][wifi:377]: DNS2: 0.0.0.0
[C][logger:293]: Logger:
[C][logger:294]: Level: DEBUG
[C][logger:295]: Log Baud Rate: 115200
[C][logger:296]: Hardware UART: UART0
[C][switch.gpio:076]: GPIO Switch ‘Light1’
[C][switch.gpio:078]: Icon: ‘mdi:key-variant’
[C][switch.gpio:098]: Restore Mode: restore defaults to OFF
[C][switch.gpio:031]: Pin: GPIO3
[C][switch.gpio:076]: GPIO Switch ‘Light2’
[C][switch.gpio:078]: Icon: ‘mdi:door-closed-lock’
[C][switch.gpio:031]: Pin: GPIO0
[C][captive_portal:088]: Captive Portal:
[C][web_server:151]: Web Server:
[C][web_server:152]: Address: 192.168.1.221:80
[C][mdns:108]: mDNS:
[C][mdns:109]: Hostname: ESP-001
[C][ota:093]: Over-The-Air Updates:
[C][ota:094]: Address: 192.168.1.221:8266
[C][ota:097]: Using Password.
[C][api:138]: API Server:
[C][api:139]: Address: 192.168.1.221:6053
[C][api:141]: Using noise encryption: YES
[C][sntp:053]: SNTP Time:
[C][sntp:054]: Server 1: ‘0.pool.ntp.org
[C][sntp:055]: Server 2: ‘1.pool.ntp.org
[C][sntp:056]: Server 3: ‘2.pool.ntp.org
[C][sntp:057]: Timezone: ‘CET-1CEST,M3.5.0,M10.5.0/3’
[D][api:102]: Accepted 192.168.1.130
[W][api.connection:071]: 192.168.1.130: Socket operation failed: BAD_INDICATOR errno=11
[I][ota:113]: Boot seems successful, resetting boot loop counter.
Someone experienced the same behaviour?
Thank you for support!
Roland
