Hi, I have the same problem. Did you find out what was wrong?
I tried to use the software serial on the ESP8266 itself, could not get it to work.
Orderd a RS485 TTL converter an now it works
Hi All,
I having trouble to compile (validate) the Growatt implementation. I get the following error:
INFO Reading configuration /config/esphome/growatt.yaml...
Failed config
sensor.growatt_solar: [source /config/esphome/growatt.yaml:52]
platform: growatt_solar
update_interval: 5s
[protocol_version] is an invalid option for [sensor.growatt_solar]. Please check the indentation.
protocol_version: RTU2 [source /config/esphome/growatt.yaml:54]
My relevant config looks like this:
uart:
- id: uart1
baud_rate: 9600 #9600 8N1
tx_pin: D6 #software Serial
rx_pin: D7 #software Serial
modbus:
uart_id: uart1
- platform: growatt_solar
update_interval: 5s
inverter_status:
name: "Growatt Status Code"
To me the indentation looks OK.
Can anyone please help me to find out what the problem is?
Thanks a lot in advance
Bart
are you by any chance using a bit old esphome version that does not yet have protocol version as an attribute? If so, try updating the esphome addon to the latest version, that might just solve the problem.
Hi Pieter,
Thanks for your reply. In the mean time I went for another route which works fine for me at the moment.
Thanks again
Trying to get data from my Growatt and have problem with no values.
I use Growatt 12KTL3-XL 3-phase Inverter (https://www.martom.no/wp-content/uploads/2020/09/Growatt-MID-6_12KTL3-XL-User-Manual-002-7920599-1.pdf)
FireBeetle ESP32-Wroom-32D (https://www.dfrobot.com/product-1590.html):
And this TTL (https://www.aliexpress.com/item/1005004447451769.html?spm=a2g0o.order_list.order_list_main.17.71ba18027LIKyD):
[20:55:09][C][logger:301]: Logger:
[20:55:09][C][logger:302]: Level: DEBUG
[20:55:09][C][logger:303]: Log Baud Rate: 115200
[20:55:09][C][logger:305]: Hardware UART: UART0
[20:55:09][C][uart.arduino_esp32:124]: UART Bus 1:
[20:55:09][C][uart.arduino_esp32:125]: TX Pin: GPIO17
[20:55:09][C][uart.arduino_esp32:126]: RX Pin: GPIO16
[20:55:09][C][uart.arduino_esp32:128]: RX Buffer Size: 256
[20:55:09][C][uart.arduino_esp32:130]: Baud Rate: 9600 baud
[20:55:09][C][uart.arduino_esp32:131]: Data Bits: 8
[20:55:09][C][uart.arduino_esp32:132]: Parity: NONE
[20:55:09][C][uart.arduino_esp32:133]: Stop bits: 1
[20:55:09][C][modbus:143]: Modbus:
[20:55:09][C][modbus:145]: Send Wait Time: 250 ms
[20:55:09][C][modbus:146]: CRC Disabled: NO
[20:55:09][C][homeassistant.time:010]: Home Assistant Time:
[20:55:09][C][homeassistant.time:011]: Timezone: 'CET-1CEST,M3.5.0,M10.5.0/3'
[20:55:09][C][growatt_solar:136]: GROWATT Solar:
[20:55:09][C][growatt_solar:137]: Address: 0x01
This is my code:
captive_portal:
time:
- platform: homeassistant
# Example configuration entry
uart:
- id: gw_uart
baud_rate: 9600
tx_pin: GPIO17
rx_pin: GPIO16
modbus:
uart_id: gw_uart
# flow_control_pin: GPIO4
update_interval: 5s
inverter_status:
phase_a:
voltage:
name: "Growatt Voltage Phase A"
current:
name: "Growatt Current Phase A"
active_power:
name: "Growatt Power Phase A"
phase_b:
voltage:
name: "Growatt Voltage Phase B"
current:
name: "Growatt Current Phase B"
active_power:
name: "Growatt Power Phase B"
phase_c:
voltage:
name: "Growatt Voltage Phase C"
current:
name: "Growatt Current Phase C"
active_power:
name: "Growatt Power Phase C"
pv1:
voltage:
name: "Growatt PV1 Voltage"
current:
name: "Growatt PV1 Current"
active_power:
name: "Growatt PV1 Active Power"
pv2:
voltage:
name: "Growatt PV2 Voltage"
current:
name: "Growatt PV2 Current"
active_power:
name: "Growatt PV2 Active Power"
active_power:
name: "Growatt Grid Active Power"
pv_active_power:
name: "Growatt PV Active Power"
frequency:
name: "Growatt Frequency"
energy_production_day:
name: "Growatt Today's Generation"
total_energy_production:
name: "Growatt Total Energy Production"
inverter_module_temp:
name: "Growatt Inverter Module Temp"
# Device Internal Temperature
- platform: internal_temperature
name: "Growatt Solar Internal Temperature"
# WiFi RSSI
- platform: wifi_signal
name: "Growatt Solar RSSI"
update_interval: 60s
Any one can help?
I figured out the issue.
There is a but inside ESPHome and you need to use older Arduino frame version. Version 2.0.6
esp32:
board: esp32dev
framework:
type: arduino
version: 2.0.6
Now everything works perfectly:
Can I ask you, if your have logger enabled, and what logs are you getting?
I am struggling to get MOD6000TL3-X inverter over RS485, with ESP32.
I tried Arduino 2.0.6 framework, switching RX/TX, using other RX/TX (1&3) pins, using software serial, tried ESP8266, another modbus module, double checked wiring. Modbus address is as per default 1.
esphome:
friendly_name: garage_tavle
esp32:
board: esp32dev
framework:
type: arduino
version: 2.0.6
# Enable logging
logger:
baud_rate: 0
level: VERBOSE
switch:
- platform: gpio
pin: 32
inverted: true
- platform: gpio
pin: 33
inverted: true
uart:
- id: gw_uart
baud_rate: 9600
tx_pin: GPIO17
rx_pin: GPIO16
modbus:
uart_id: gw_uart
update_interval: 5s
inverter_status:
phase_a:
voltage:
current:
active_power:
phase_b:
voltage:
current:
active_power:
phase_c:
voltage:
current:
active_power:
pv1:
voltage:
current:
active_power:
pv2:
voltage:
current:
active_power:
active_power:
pv_active_power:
frequency:
Using unshielded cat5e 2 meters cable. Ground not connected. Yet to try shielded one…
However I am suspecting software issue, as nothing, like nothing like CRC errors or similar are coming through in logs. LED’s on TTL converter light up briefly on update interval, else not. Only this:
[22:36:55][V][modbus:199]: Modbus write: 01.04.00.00.00.5F.B0.32 (8)
[22:37:00][V][modbus:199]: Modbus write: 01.04.00.00.00.5F.B0.32 (8)
[22:37:05][V][modbus:199]: Modbus write: 01.04.00.00.00.5F.B0.32 (8)
[22:37:10][V][modbus:199]: Modbus write: 01.04.00.00.00.5F.B0.32 (8)
[22:37:15][V][modbus:199]: Modbus write: 01.04.00.00.00.5F.B0.32 (8)
[22:37:20][V][modbus:199]: Modbus write: 01.04.00.00.00.5F.B0.32 (8)
I’m curious, for people using a Growatt MODxxxxTL3-X, do you get any data at night?
I’m currently using grott integration, but when the inverter goes offline at night, I’m not getting anything on the Shinewifi-X and I want to know if the 485 route is better.
My only problem is that everything that I import from grid during the night gets posted all at once in the morning:
