It should be …
to: ‘on’
Your indentation looks wrong to me to, everything under the t of trigger should be under the i of trigger
It should be …
to: ‘on’
Hmm noticed that the automation started even though i had input_boolean.coffeornot off
- alias: 'Kaffe på morgonen under helgen'
initial_state: true
value_template: '{{ states.sensor.time.state == states.input_select.coffemaker.state }}'
- platform: time
at: 08:30:00
- platform: state
entity_id: input_boolean.coffeornot
to: 'on'
condition:
- condition: state
entity_id: input_select.status_hemma
state: Hemma
# - condition: time
# weekday:
# - sat
# - sun
- service: homeassistant.turn_on
entity_id: switch.net_perkulator
Yes because the triggers are not AND they are any change in state of a trigger will trigger it so in your case if the time is correct for either of your time triggers will trigger it even if the input_bool is off.
Is it possible to have the input_boolean as a condition then?
yep you can use the state of the input_boolean as a normal state condiditon.
Example from my alarm clock…
- alias: 'Wake Me Up'
initial_state: 'on'
- platform: time
minutes: '/1'
seconds: '0'
condition:
- condition: or
conditions:
- condition: and
conditions:
- condition: state
entity_id: input_boolean.alarmstatus
state: 'on'
- condition: state
entity_id: input_boolean.alarmweekday
state: 'on'
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- condition: template
value_template: '{{ now().time().strftime("%R") == states.sensor.alarm_time.state }}'
- condition: and
conditions:
- condition: state
state: 'on'
- condition: state
state: 'off'
The automation didnt go on this morning
- alias: 'God morgon'
initial_state: true
- platform: time
minutes: '/1'
seconds: '0'
- platform: state
entity_id: group.all_devices
to: home
condition:
- condition: or
conditions:
- condition: and
conditions:
- condition: state
state: 'on'
- condition: state
state: 'on'
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- condition: and
conditions:
- condition: state
state: 'on'
- condition: state
state: 'off'
- condition: state
state: 'Hemma'
Please forgive me
I copied the example without changing the name of the input_select in value_template
@keithh666 i still cant get it to work
initial_state: true
- platform: time
minutes: '/1'
seconds: '0'
condition:
- condition: and
conditions:
- condition: state
state: 'on'
value_template: '{{ now().time().strftime("%R") == states.sensor.wake_up_time.state }}'
- condition: state
state: 'Hemma'
What does the above look like now?
I assume this is the state:
#alarm / soluppgång
wake_up_time:
name: 'Alarm soluppgång'
icon: mdi:alarm-multiple
options:
- "00:00"
Can you show it all please? All of that sensor that is.
#alarm / soluppgång
wake_up_time:
options:
- "00:00"
- "00:15"
- "00:30"
- "00:45"
- "01:00"
- "01:15"
- "01:30"
- "01:45"
- "02:00"
- "02:15"
- "02:30"
- "02:45"
- "03:00"
- "03:15"
- "03:30"
- "03:45"
- "04:00"
- "04:15"
- "04:30"
- "04:45"
- "05:00"
- "05:15"
- "05:30"
- "05:45"
- "06:00"
- "06:15"
- "06:30"
- "06:45"
- "07:00"
- "07:15"
- "07:30"
- "07:45"
- "08:00"
- "08:15"
- "08:30"
- "08:45"
- "09:00"
- "09:15"
- "09:30"
- "09:45"
- "10:00"
- "10:15"
- "10:30"
- "10:45"
- "11:00"
- "11:15"
- "11:30"
- "11:45"
- "12:00"
- "12:15"
- "12:30"
- "12:45"
- "13:00"
- "13:15"
- "13:30"
- "13:45"
- "14:00"
- "14:15"
- "14:30"
- "14:45"
- "15:00"
- "15:15"
- "15:30"
- "15:45"
- "16:00"
- "16:15"
- "16:30"
- "16:45"
- "17:00"
- "17:15"
- "17:30"
- "17:45"
- "18:00"
- "18:15"
- "18:30"
- "18:45"
- "19:00"
- "19:15"
- "19:30"
- "19:45"
- "20:00"
- "20:15"
- "20:30"
- "20:45"
- "21:00"
- "21:15"
- "21:30"
- "21:45"
- "22:00"
- "22:15"
- "22:30"
- "22:45"
- "23:00"
- "23:15"
- "23:30"
- "23:45"
# lägg till följande för att få en dropdown list med val
status_hemma:
name: 'Om vi är hemma'
icon: mdi:panda
options:
- 'Semester'
- 'Hemma'
# time
- platform: time_date
display_options:
- 'time'
- 'date'
- 'date_time'
- 'time_date'
- 'time_utc'
- 'beat'
scan_interval: 30
These are all input_selects are they not?
alarmstatus:
# initial: off
icon: mdi:alarm-check
Yes it is input_selects input_booleans and sensors
What’s happened here is that you’ve copied part of my alarm which uses a slightly different way of doing it as I calculate my times from an input slider hence my comparison is with sensors not input_selects, you need to change the wakeup sensor to an input_select…
value_template: '{{ now().time().strftime("%R") == states.input_select.wake_up_time.state }}'
