Can't get the new IMAP template to work to check my email
I got it. Thanks
Where are you putting the template and sensor setup?
is it in the configuration.yaml file?
I have followed the imap example, but not getting any new sensors except the imap count of unread emails.
any working examples with specific places to put them would be really helpful.
something simple like the subject in a sensor or text regex to populate another sensor.
The trigger-based template sensor used to get the content of incoming emails can go directly in configuration.yaml or any properly split file that uses template as it’s top-level configuration key.
One easy and flexible method for splitting the config is to use a Packages folder. Here is a screenshot of the basic “subject” sensor.
For reference, my Packages folder is split in configuration.yaml as follows:
homeassistant:
  packages: !include_dir_named packages
Hi, thanks for the pointers on the IMAP integration;
just one issue here and couldn’t find an answer so far
Everything works as expected, I can trigger on subject but not on body (“text”)
  - trigger:
      - platform: event
        event_type: "imap_content"
    binary_sensor:
      - name: gmail_hydro_test
        auto_off: "00:02:00"
        state: >
          {% if trigger.event.data['text'] is match
          "test|Test|Zzz|zzz"
            true
          {% endif %}
To troubleshoot I’ve added a sensor to extract all data and the “text” is in the wrong format;
(the body of the message here is simply “test” but here’s the result)
  - trigger:
      - platform: event
      - name: imap_content
        unique_id: 2604a5fa-d31e-4ab1-bced-084b0cfe81a2
        state: "{{ trigger.event.data['subject'] }}"
        attributes:
          Message: "{{ trigger.event.data['text'] }}"
          Server: "{{ trigger.event.data['server'] }}"
          Username: "{{ trigger.event.data['username'] }}"
          Search: "{{ trigger.event.data['search'] }}"
          Folder: "{{ trigger.event.data['folder'] }}"
          Sender: "{{ trigger.event.data['sender'] }}"
          Date: "{{ trigger.event.data['date'] }}"
          Subject: "{{ trigger.event.data['subject'] }}"
          To: "{{ trigger.event.data['headers']['Delivered-To'][0] }}"
          Return_Path: "{{ trigger.event.data['headers']['Return-Path'][0] }}"
          Received-first: "{{ trigger.event.data['headers']['Received'][0] }}"
          Received-last: "{{ trigger.event.data['headers']['Received'][-1] }}"
I’ve tried changing the charset to US-ASCII instead of utf-8 but still doesn’t work
Any idea what could be wrong ?
It’s base64 encoded.
- trigger:
      - platform: event
    binary_sensor:
        state: >
          {{ trigger.event.data['text'] | base64_decode  is match("test|Test|Zzz|zzz") }}
FWIW, match() will only match the find expression at the beginning of the string. If the criteria could be anywhere other than the beginning you’ll need to use search().
ok will test and report back;
what’s odd though is the fact that using the integration template does work
Every single one of my dozen tests now working … :sunglasses:
Thank you :+1:
Does the base64 text comes from Gmail or the sender ?
surprised this hasn’t surfaced elsewhere on the forum if it is Gmail related…
As I understand it, the actual search is performed by the email provider/server so they must decode it at some point… I don’t know why they don’t forward the decoded version.
The sender.
There have been a couple questions about it in the past month or two.
For future reference, here’s a tested version to ensure it handles both decodes.
First Sensor is simply to get a clear text version of status/attributes (including base64 message)
Second one to be adapted vs use case.
Thanks for your assistance @Didgeridrew
- trigger:
  - platform: event
    #event_data:
    #  sender: "xxxxxxxxxxxx@xxxxxxxxx"
  - name: gmail_imap_sensor_data
    attributes:
      Message-Base64: "{{ trigger.event.data['text'] | base64_decode }}"
      To: "{{ trigger.event.data['headers'].get('Delivered-To', ['n/a'])[0] }}"
      Return-Path: "{{ trigger.event.data['headers'].get('Return-Path',['n/a'])[0] }}"
      Received-first: "{{ trigger.event.data['headers'].get('Received',['n/a'])[0] }}"
      Received-last: "{{ trigger.event.data['headers'].get('Received',['n/a'])[-1] }}"
- trigger:
    - platform: event
      #event_data:
      #  sender: "xxxxxxxxxxxxxx@xxxxxxxxxxxxxxxx"
  binary_sensor:
  - name: gmail_imap_hydroqc_am_peak_period
    auto_off: "12:00:00"
    state: >-
      {% if 'Am' in trigger.event.data["text"] or 'Am' in trigger.event.data["text"] | base64_decode %}
        true
      {% endif %}
Hello @comet424,
Have you fix your UNKNOWN problem? IF, yes, how?
Other question, Where did you put the code that you submit previously (### Intelcom Deliveries Template ###)? (in configuration.yaml?, In automations.yaml? Or directly in the configuration of IMAP integration?).
Thanks for your help!
Richard
@rikray02 no i never i use the uknown in my esphome code but i have a double problem it seems to work but it re pops up the on my screen that delivery has a arrived even though the automation hasnt ran… so i not sure whats in the code why its doing that its either the esp device is rebooting and and it is blank and then it updates th ands why it displays multiple times thats my guess for my current issue
as for my code i did
an automation here is my code… it does different sensors as i couldnt change the template on a nextion screen right or so… so it sends it to a screen and on my cell and emails
alias: Amazon Delivery Gifts (Intelcom)
description: Intelcom Amazon Delivery Gifts
  - platform: state
    entity_id:
      - sensor.intelcom_amazon_delivery
condition: []
  - choose:
      - conditions:
          - condition: state
            entity_id: sensor.intelcom_amazon_delivery
            state: received
        sequence:
          - service: notify.text_cell_notification
              message: >-
                Gifts Have Been Recieved At Intel Drop Off Location {{
                as_timestamp(states('sensor.date_time_iso')) |
                timestamp_custom('%I:%M %p') }}
          - service: python_script.set_state
              entity_id: sensor.deliveries_alert_message
              state: >-
                now().strftime('%B %-d, %I:%M %p')  }}
      - conditions:
          - condition: state
            state: delivered
        sequence:
              message: >-
                Gifts Have Been Delivered '{{
                timestamp_custom('%I:%M %p') }}'
              state: >-
                Amazon Gifts Been Delivered                Intelcom  {{
          - delay:
              hours: 10
              minutes: 0
              seconds: 0
              milliseconds: 0
            enabled: false
              state: unknown
            enabled: false
      - conditions:
          - condition: state
            state: on_the_way
        sequence:
              message: >-
                Gifts Are On There Way '{{
              state: >-
                Amazon Gifts On   There Way              (Intelcom)  {{
mode: single
the unknown issue i still having cuz in esphome it has issue with Unknown and unknown
here is my code for the ESP device using a Nextion screen it works but its not 100% fool proof and has issue i think it reboots on me or or something that it re toggles the display on its own when the automation hasnt ran to update the sensor so the screen should not be updating
### Deliveries Alert Message Page..  Display a Warning  Information Press Screen To Get Off It ###
  - platform: homeassistant
    on_value:
      then:
        - if:
            condition:
              not:
                # Check When Home Assistant Boots Up. and prints "unknown" or "Unknow" not to send it to the screen
                - lambda: |-
                    return (id(deliveries_alert_message).state == "unknown"); // || "Unknown");
                # Prints the Red Alert Message when it doesnt equal unknown as the message
            then:
              lambda: |-
                id(nextion1).goto_page("2");
                id(nextion1).send_command_printf("title.pco=2016");
                id(nextion1).set_component_text("title","Deliveries");
                id(nextion1).set_component_text("wmessage",id(deliveries_alert_message).state.c_str());
                id(warningc) = 1;
Hi my friend, I Was with a similar issue since imap_email_content stop working in new version HA core, and I tryed rewrite only using ui to create the sensor and in the configuration.yaml using event as the documentation show in this example using regex:
template:
  • trigger:
    • platform: event
      event_type: “imap_content”
      event_data:
      sender: “[email protected]
    • name: “Previous Day Energy Use”
      unit_of_measurement: “kWh”
      state: >
      {{ trigger.event.data[“text”]
      | regex_findall_index(“*Yesterday’s Energy Use:* ([0-9]+) kWh”) }}
    • name: “Previous Day Cost”
      unit_of_measurement: “$”
      state: >
      | regex_findall_index(“*Yesterday’s estimated energy cost:* $([0-9.]+)”) }}
    • name: “Billing Cycle Total”
      state: >
      | regex_findall_index(“\ days:* $([0-9.]+)”) }}
but this doesn´t works for me i this code below:
state: >
| regex_findall_index(“Valor da corrida:\D* ([0-9,]+)”) }}
finnaly I did a little modification using state with my old template, and bellow the complete solution, in this example I save in the sensor the value that I spent in one uber travel when I receive the email, and the sensor update correctely:
template:
  • trigger:
    • platform: event
      event_data:
    • name: “valor_recibo_uber”
      unit_of_measurement: “R$”
      state: >
      {% set email_content = trigger.event.data[“text”] %}
      {% set regex_match = email_content | regex_findall(‘Valor da corrida:(\d+,\d+)’) %}
      {% if regex_match %}
      {{ regex_match[0] | regex_replace(‘,’, ‘.’) }}
      {% else %}
      0
      {% endif %}
Good to know with 2024.2.0 an annoying bug was fixed for users connection to an Microsoft IMAP mailbox. As the encoding needs to be set to us-ascii this also was used to decode the encoded mailparts. As this failed, the content wasn’t decoded correctly. The fix no ensures the correct decoding of the message parts.
Did you ever find out where to put the template code to create a sensor based on say email subject?
