Thanks @orange-assistant for the continued support. I did a bit more investigation and added the debug and restart config as suggested. Since this is a Sonoff device, it is not straightforward to connect a serial logger but I will do that as a next step if there is still not sufficient info here to diagnose the cause.
The entities show i) device info inc. restart reason ii) uptime and iii) wifi signal strength. The gaps in the graphs correlate to periods where HA is reporting that the device is unavailable. I previously assumed that these dropouts was due to poor wifi signal strength but I can now see that in this specific example the wifi signal strength was actually stronger during the instable periods than the stable. So perhaps the issue is causing the wifi dropouts rather than the other way around.
From the graphs I see a long period of stability followed by a period of instability during which the device rebooted several times. The restart reasons reported from the OTA logs are sometimes exception 28 and sometimes exception 9.
Reset Info: Fatal exception:28 flag:2 (Exception) epc1:0x40236a5b epc2:0x00000000 epc3:0x00000000 excvaddr:0x0000000e depc:0x00000000
[02:13:27][D][text_sensor:064]: 'Device Info': Sending state '2023.6.4|Flash: 1024kB Speed:40MHz Mode:DOUT|Chip: 0x00c9238b|SDK: 2.2.2-dev(38a443e)|Core: 3.0.2|Boot: 31|Mode: 1|CPU: 80|Flash: 0x00144051|Reset: Exception|Fatal exception:28 flag:2 (Exception) epc1:0x40236a5b epc2:0x00000000 epc3:0x00000000 excvaddr:0x'
[02:13:27][D][text_sensor:064]: 'Reset Reason': Sending state 'Exception'
[06:06:13][D][debug:254]: Reset Reason: Exception
[06:06:13][D][debug:255]: Reset Info: Fatal exception:9 flag:2 (Exception) epc1:0x4023b407 epc2:0x00000000 epc3:0x00000000 excvaddr:0x696817ad depc:0x00000000
[06:06:13][D][text_sensor:064]: 'Device Info': Sending state '2023.6.4|Flash: 1024kB Speed:40MHz Mode:DOUT|Chip: 0x00c9238b|SDK: 2.2.2-dev(38a443e)|Core: 3.0.2|Boot: 31|Mode: 1|CPU: 80|Flash: 0x00144051|Reset: Exception|Fatal exception:9 flag:2 (Exception) epc1:0x4023b407 epc2:0x00000000 epc3:0x00000000 excvaddr:0x6'
Does this shed any light on the issue? Or do I need to solder on some header pins to read the serial logs?
