To be fair, we don’t know that to be the case yet. The user was reporting errors with the conversation component and hasn’t reported back yet if disabling conversation solved his particular error.
This issue on github may be more applicable though:
You may want to look it over and see if you should be adding your observations.
Well, after updating to 0.36.1, errors are still here:
File "/home/homeassistant/.homeassistant/deps/aiohttp/web_server.py", line 61, in handle_request
resp = yield from self._handler(request)
File "/home/homeassistant/.homeassistant/deps/aiohttp/web.py", line 249, in _handle
resp = yield from handler(request)
File "/usr/lib/python3.4/asyncio/coroutines.py", line 143, in coro
res = yield from res
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/http/static.py", line 62, in static_middleware_handler
File "/home/homeassistant/.homeassistant/deps/aiohttp/web_urldispatcher.py", line 486, in _handle
ret = yield from self._file_sender.send(request, filepath)
File "/home/homeassistant/.homeassistant/deps/aiohttp/file_sender.py", line 201, in send
yield from self._sendfile(request, resp, f, count)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/http/static.py", line 30, in sendfile
yield from orig_sendfile(request, resp, fobj, count)
File "/home/homeassistant/.homeassistant/deps/aiohttp/file_sender.py", line 60, in _sendfile_system
yield from self._sendfile_fallback(request, resp, fobj, count)
File "/home/homeassistant/.homeassistant/deps/aiohttp/file_sender.py", line 137, in _sendfile_fallback
resp.set_tcp_nodelay(True)
File "/home/homeassistant/.homeassistant/deps/aiohttp/web_reqrep.py", line 737, in set_tcp_nodelay
resp_impl.transport.set_tcp_nodelay(value)
File "/home/homeassistant/.homeassistant/deps/aiohttp/parsers.py", line 253, in set_tcp_nodelay
self._socket.setsockopt(socket.IPPROTO_TCP, CORK, False)
OSError: [Errno 9] Bad file descriptor
I don’t have a clue how to implement it though, I can’t navigate to the /home/homeassistant/components folder (doesn’t exist). It also doesn’t exist in the .homeassistant folder
