I tried several times to upgrade from 0.100.1 to 0.101.2, without any luck. First time I have issues doing upgrades with hass.io.
It looks like everything is OK (downloading packages), then after some time hass;io restarts and I’m basically back on 0.100.1.
I ran ‘hassio homeassistant check’ and the command completed without any errors being reported.
I had the same problem of not being able to upgrade. Mine was due to API password still in the config file commented out http: and the API password and upgrade went fine.
Yes ! Just tried that (found in another post) and it indeed solved the issue.
I basically did add the auth_providers key under ‘homeassistant:’ in the configuration.yaml, having one entry for homeassistant auth provider and one for the legacy API password and voilà, upgrade problem solved.
So you commented out
http:
Sorry can you show that part of configuration, that is working for you
“hassio ha check” against 0.100.3 showed my config was fine - but running the “heck Home Assistant configuration” hassio image against 0.101.2 did find some issues. Trying to solve them now and see if this fixes my issues.
Same issue here - cannot update from 0.100.3 to 0.101.2
Maybe this in the release notes explains why it is not working:
The support of configuring the auth providers for API Password and Trusted Networks via the HTTP configuration is also removed. It now needs to be configured in the auth provider section (docs).
In configuration.yaml file under http: section try commenting api_password. In my case it is:
# api_password: !secret HA_Password
Trying right now, hope that will help.
Update: after commenting api_password update worked fine
I think this maybe the issue I am struggling with… When i run the config check, I get errors for frontend_hass and found this issue on github https://github.com/home-assistant/home-assistant/issues/28361
EDIT: I posted without seeing Serg’s post 1 up. It’s the same issue.
And yes - removing api_password solved the issue for me
Sorry guys, xkcd from today reminded me of this sort of thread.
Well, I uncommented that line as first thing before upgrading. Unfortunately in my case did not solve., I am still with 0.100.3
Uncommented? Should be commented, maybe it’s better to delete it as it is no longer supported. I tried multiple times before which didn’t work, but updated fine straight after deleting that api. Just saved the config and clicked Upgrade.
My bad … I was meaning commented out … not present anymore in config.,
Yup
and api password
I’m stuck in this same place. I have removed api password from my configuration file. I’ve tried downgrading to 0.100.3 using command:
hassio homeassistant update --version=0.100.3
And I just get this immediately
Processing... Done.
Command completed successfully.
My log looks like this:
2019-11-06 18:41:54 ERROR (MainThread) [homeassistant.setup] Error during setup of component api
File "/usr/src/homeassistant/homeassistant/setup.py", line 176, in _async_setup_component
component.setup, hass, processed_config # type: ignore
concurrent.futures._base.CancelledError
2019-11-06 18:41:54 ERROR (MainThread) [homeassistant.setup] Error during setup of component homekit
File "/usr/src/homeassistant/homeassistant/setup.py", line 172, in _async_setup_component
File "/usr/src/homeassistant/homeassistant/components/homekit/__init__.py", line 135, in async_setup
await hass.async_add_executor_job(homekit.setup)
2019-11-06 18:41:54 ERROR (MainThread) [homeassistant.components.hue] Unknown error connecting with Hue bridge at 192.168.1.103
File "/usr/src/homeassistant/homeassistant/components/hue/bridge.py", line 46, in async_setup
self.api = await get_bridge(hass, host, self.config_entry.data["username"])
File "/usr/src/homeassistant/homeassistant/components/hue/bridge.py", line 171, in get_bridge
await bridge.initialize()
File "/usr/local/lib/python3.7/site-packages/aiohue/bridge.py", line 43, in initialize
result = await self.request('get', '')
File "/usr/local/lib/python3.7/site-packages/aiohue/bridge.py", line 59, in request
async with self.websession.request(method, url, json=json) as res:
File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 1012, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 483, in _request
timeout=real_timeout
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 523, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 859, in _create_connection
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 986, in _create_direct_connection
req=req, client_error=client_error)
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 936, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore # noqa
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 941, in create_connection
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.7/asyncio/selector_events.py", line 464, in sock_connect
return await fut
2019-11-06 18:41:54 ERROR (MainThread) [homeassistant.setup] Error during setup of component input_boolean
File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
return loop.run_until_complete(main)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 579, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/__main__.py", line 302, in setup_and_run_hass
log_no_color=args.log_no_color,
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 146, in async_from_config_file
config_dict, hass, enable_log=False, skip_pip=skip_pip
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 91, in async_from_config_dict
await _async_set_up_integrations(hass, config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 372, in _async_set_up_integrations
*(async_setup_component(hass, domain, config) for domain in domains_to_load)
File "/usr/src/homeassistant/homeassistant/setup.py", line 51, in async_setup_component
return await task # type: ignore
File "/usr/src/homeassistant/homeassistant/setup.py", line 147, in _async_setup_component
hass, config, integration
File "/usr/src/homeassistant/homeassistant/config.py", line 736, in async_process_component_config
p_validated = component_platform_schema(p_config)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 205, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 285, in _exec
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/src/homeassistant/homeassistant/components/scene/__init__.py", line 46, in _platform_validator
return platform.PLATFORM_SCHEMA(config)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 386, in validate_mapping
cval = cvalue(key_path, value)
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 635, in validate_sequence
cval = validate(index_path, value)
v = func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/components/homeassistant/scene.py", line 37, in _convert_states
if isinstance(states[entity_id], dict):
KeyError: 'light.porch_level'
File "/usr/src/homeassistant/homeassistant/components/input_boolean/__init__.py", line 83, in async_setup
await component.async_add_entities(entities)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 252, in async_add_entities
await asyncio.wait(tasks)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 389, in wait
return await _wait(fs, timeout, return_when, loop)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 482, in _wait
await waiter
2019-11-06 18:41:54 ERROR (MainThread) [homeassistant.setup] Error during setup of component group
v = func(path, v)
return schema(data)
v = func(path, v)
v = func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 216, in async_setup
await _async_process_config(hass, config, component)
File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 373, in _async_process_config
mode=mode,
File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 488, in async_create_group
await component.async_add_entities([group], True)
await waiter
2019-11-06 18:41:54 ERROR (MainThread) [homeassistant.setup] Error during setup of component input_number
v = func(path, v)
return schema(data)
v = func(path, v)
v = func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/components/input_number/__init__.py", line 124, in async_setup
await waiter
2019-11-06 18:41:54 ERROR (MainThread) [homeassistant.setup] Error during setup of component timer
v = func(path, v)
return schema(data)
v = func(path, v)
v = func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/components/timer/__init__.py", line 95, in async_setup
await waiter
2019-11-06 18:41:54 ERROR (MainThread) [homeassistant.setup] Error during setup of component config
v = func(path, v)
return schema(data)
v = func(path, v)
v = func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/components/config/__init__.py", line 67, in async_setup
await waiter
2019-11-06 18:41:54 ERROR (MainThread) [homeassistant.setup] Error during setup of component xiaomi_aqara
v = func(path, v)
return schema(data)
v = func(path, v)
v = func(path, v)
return schema(data)
I was able to rollback. The correct syntax for the Hassio CLI is
hassio homeassistant update --version 0.100.3
I’ll wait for 102 now
Yes me too, still have the same issues and have no idea what is causing them.
Problem is that to troubleshoot I would need 1 or 2 full days to try and make the testing, addign piece by piece
root cause of your issues appears to be a component that creates the following entity: light.porch_level. Verify that the component that creates that entity has the correct configuration.
you have to wait some times before launcing the command
This is my log of hassio ha check with 0.101.3
Error: Testing configuration at /config
INFO:homeassistant.util.package:Attempting install of meross_iot==0.3.1.7
INFO:homeassistant.util.package:Attempting install of pybluez==0.22
INFO:homeassistant.util.package:Attempting install of transitions==0.6.9
INFO:homeassistant.util.package:Attempting install of pyShelly==0.0.34
ERROR:homeassistant.scripts.check_config:BURB
File "/usr/src/homeassistant/homeassistant/scripts/check_config.py", line 206, in checking...
async_check_ha_config_file(hass)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 579, in run_until_completeing...
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 140, in async_check_ha_config_file
v = func(path, v)
return schema(data)
v = func(path, v)
v = func(path, v)
return schema(data)
KeyError: 'group.ceiling_lights'
Fatal error while loading config: 'group.ceiling_lights'
Failed config
General Errors:
- 'group.ceiling_lights'
Successful config (partial)
core-ssh:~#
core-ssh:~#
