I have Windows 10 + nuc & don’t know if your command would work for me I haven’t tested it.
I ran official command line command (modified to change “pip3” for “pip”).
py -m pip install --upgrade homeassistant
STOP your server before running this.
Put the command in a .bat file to run it faster
I don’t know why there are 2 different methods to update. Very confusing !!!
I prefer the method I posted as it’s run via python & don’t need to specify version number & is the official documented method.
Will be nice to see the system update itself in future!!
same here, im having problems to update from 108.9 to 109.x
i assume either a hacs component or hassio (supervisor) addon is causing problems. i tried to remove all .translations and even uninstalled a couple, so far no luck.
