Looks great!
I was thinking of doing something similar to let me know if it was ok to put the clothes washing out on the line - would this sensor work for that?
Looks great!
Good point thats thinking outside the box
Unfortunately, the binary sensor can show only two states - âonâ and âoffâ.
In the case of this sensor, âonâ should be interpreted as âit is worth washing the carâ, and âoffâ - as âyou should not wash the carâ.
The sensor does not change the visual display, because with different settings it may be different. For example, in HA I have this sensor through a picture entity card changing the interface pictures that visually show the situation.
My HA configs for this: HomeAssistantConfiguration/lovelace/00_home_view.yaml at master ¡ Limych/HomeAssistantConfiguration ¡ GitHub
If you want to change the color of the sensor icon, simply add this setting to the configuration:
# Example configuration.yaml entry
homeassistant:
customize:
binary_sensor.car_wash:
templates:
hs_color: "if (state === 'on') return [100,65]; else return [0, 85];"
ATTENTION!
A serious error was detected in the logic of the sensor operation. I published version 1.2.0, which fixes it.
If you do not have custom_updater configured, please update the component manually.
This sensor monitors the weather conditions under which the car on the road will quickly become dirty. I think for your task, some of them will be a bit redundant. For example, the event of passage of temperature through the melting point of ice/snow.
Not working with the latest release ⌠0.92.0
Thank you.
An update has been released taking into account the new rules for the integration of components in Home Assistant versions 0.92+.
Unfortunately, updating through the custom-updater may not work. In this case, you need to update the component manually. In the future, automatic update will work again correctly.
Need your help please!
CAR WASH install with HACS.
configuration.yaml
weather:
- platform: openweathermap
api_key: xxxxxxxxxxxxxxxxxxxxxxxxxxx my api xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
mode: daily
binary_sensor:
- platform: car_wash
weather: weather.openweathermap
days: 2
error message:
Log Details (ERROR)
Fri Sep 27 2019 00:03:18 GMT+0200 (Mitteleuropäische Sommerzeit)
Update for binary_sensor.auto_waschen fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 261, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 439, in async_device_update
await self.async_update()
File "/config/custom_components/car_wash/binary_sensor.py", line 151, in async_update
fc_date = fc.get(ATTR_FORECAST_TIME)[:10]
TypeError: 'int' object is not subscriptable
regards
johann
Fixed.
Hello.
Great plugin, Iâve been using it for a while.
I actually hadnât noticed there was a ânameâ variable and came here to ask for that.
Could you perhaps add an âiconâ variable as well? Iâm using it to check if the weather allows for doing the laundry and it would be nice to have a proper icon.
I think itâs not entirely correct to add an icon field. From my point of view, it will not add anything new useful for the main purpose of this sensor.
Nevertheless, you can always force the icon to be changed through the Home Assistant configs. Like this, as example:
homeassistant:
customize:
templates:
icon: >-
if (state == 'on') return 'mdi:weather-sunny';
return 'mdi:weather-pouring';
Forgive my likely terrible formatting, as Iâm on my phone. anyhow I wanted to do something similar but just as simply as possible so I created to quick sensors leveraging dark skyâŚ
car_wash_test:
value_template: >
{% set D0 = states('sensor.darksky_weather_precip_probability') | int %}
{% set D1 = states('sensor.darksky_weather_precip_probability_1d') | int %}
{% set D2 = states('sensor.darksky_weather_precip_probability_2d') | int %}
{% set D3 = states('sensor.darksky_weather_precip_probability_3d') | int %}
{% set D4 = states('sensor.darksky_weather_precip_probability_4d') | int %}
{% set D5 = states('sensor.darksky_weather_precip_probability_5d') | int %}
{% if D0 > 50 %} off
{% elif D1 > 50 %} off
{% elif D2 > 60 %} off
{% elif D3 > 70 %} off
{% elif D4 > 73 %} off
{% elif D5 > 76 %} off
{% elif 'rain' in states('sensor.darksky_weather_icon') %} off
{% elif states('sensor.darksky_weather_humidity') | int > 89 or states('sensor.front_porch_sensor_relative_humidity_measurement') | int > 89 %} off
{% elif (D1+D2+D3+D4+D5) > 100 %} off
{% else %} on
{% endif %}
car_wash:
value_template: >-
{% if is_state('sensor.car_wash_test','on') %}
Yes
{% else %}
No
{% endif %}
entity_picture_template: >-
{% if is_state('sensor.car_wash_test', 'on') %}
/local/custom_icons/car-wash-yellow-FDD835.png
{% else %}
/local/custom_icons/car-wash-blue-44739E.png
{% endif %}
attribute_templates:
D0: "{{states('sensor.darksky_weather_precip_probability')}}"
D1: "{{states('sensor.darksky_weather_precip_probability_1d')}}"
D2: "{{states('sensor.darksky_weather_precip_probability_2d')}}"
D3: "{{states('sensor.darksky_weather_precip_probability_3d')}}"
D4: "{{states('sensor.darksky_weather_precip_probability_4d')}}"
D5: "{{states('sensor.darksky_weather_precip_probability_5d')}}"
This is by no means perfect but seems to work fairly well for me.
This sounds pretty useful. I prefer to clean my car on my own and thatâs why I rely on forecasts. By the way, recently I decided to read more information here about the best clay bar which is pretty useful if you want to scrub your car thoroughly. What are your thoughts on it?
hay bro could post your png files
I just went to https://materialdesignicons.com/, found the one I wanted, then clicked on it, then advanced export - size 20, padding 10 and then pick whatever foreground color you want and then hit ICON button in bottom right corner.
I got this error:
The openweathermap platform for the weather integration does not support platform setup. Please remove it from your config.
weather:
api_key: !secret openweatherapi
mode: daily
binary_sensor:
days: 2
And have you removed the part from your configuration as suggested?
which recommendation do you mean? ( Process forecast time as timestamp (#1)?)
The OpenWeatherMap integration can only be configured via the UI.
So that part can be removed from the yaml:
weather:
mode: daily
