šŸ”¹ Card-mod - Add css styles to any lovelace card
Slowly but surely I am beginning to understand how to use this card. Thanks for the work you have put into it.
I am beginning to understand css selectors and how to use the debug_cardmod flag to find my away around.
What I would now like to do is be able to style a more-info card. Is this possible?
If it is, what is the starting point for building a selector path?
That can be done either by using browser_mod to replace the popup with something you choose yourself (and can style), and my more-info-card, or by something like this
Thanks Thomas, will give browser-mod a try.
Iā€™m trying to change icon color on state.
In ui-lovelace.yaml put the module:
resources:
    - url: /community_plugin/compact-custom-header/compact-custom-header.js
      type: module
    - url: /community_plugin/lovelace-card-mod/card-mod.js
      type: module
In the view (default.yaml) used a glance card and put the style in:
- type: glance
    style: |
          ha-card {
            --iron-icon-fill-color: {% if is_state(config.entity, 'on') %} yellow {% endif %};
    title: Sfeerlicht
    show_header_toggle: false
    show_name: true
    show_state: true
    entities:
      - entity: switch.tuya_ropelight
        tap_action:
          action: toggle
        icon: mdi:vanity-light
      - entity: switch.tuya_aquarium
        tap_action:
          action: toggle
        icon: mdi:fishbowl
      - entity: switch.tuya_barlicht
        tap_action:
          action: toggle
        icon: mdi:beer
      - entity: switch.tuya_blokhutlicht
        tap_action:
          action: toggle
        icon: mdi:home-flood
      - entity: light.keuken_sfeerlamp_light
        tap_action:
          action: toggle
        icon: mdi:silverware-variant
      - entity: switch.kerstverlichting
        tap_action:
          action: toggle
        icon: mdi:pine-tree
But the icons do not turn yellow. (also after HA restart and clear cache)
I inspected the div that holds the icon which has the following css:
What am I doing wrong?
Using config.entity only makes sense when youā€™re using it on a single entity, not an an entire card with several entities.
Compare to the example in the readme.
I did set it on all entities at first, will try again and post yaml and/or findings.
[edit]
After 8+ hours got it workingā€¦ thank you @thomasloven
Used :host and not ha-card, also readme says --paper-item-icon-color but I used --iron-icon-fill-color
I have a vertical stack of glance cards. Only one card will show depending on the state of an input_select.
I would like to use card-mod to style the card that shows. The following snippet does style the card correctly but it stops the glance card from changing alongside the input_select. If I manually refresh the page, it shows the appropriate glance card (that is also correctly styled).
Thoughts?
- type: custom:mod-card
    style: |
      ha-card {
        font-variant: small-caps;
        --ha-card-background: rgba(200, 0, 0, 0.5);
    card:
        type: vertical-stack
    #DEN
        cards:
          - type: conditional
            conditions:
              - entity: input_select.show_card_fp
                state: Den
            card:
              type: glance
              show_icon: false
              show_name: true
              entities:
                - entity: sensor.den_motion_temperature_1
                - entity: input_boolean.occupancy_den
                - entity: binary_sensor.patio_door
                - entity: input_select.mode_den
IĀ“m lost in translation/transition or whateverā€¦ :wink:
My code for the moment is looking like this, using ā€œcard-modderā€
cards:
  - cards:
      - card:
          entities:
            - sensor.ytterdorr_status
            - sensor.altandorrvardagsrum_status
            - sensor.altandorrhugosrum_status
            - sensor.kallardorr_status
          title: Dƶrrsensorer
          type: entities
        style:
          background-color: 'rgba(50,50,50,0.3)'
          background-image: url("/local/lovelace/cardbackK.png")
          background-repeat: no-repeat
          background-size: 100% 100%
          border: 'solid 1px rgba(100,100,100,0.3)'
          border-radius: 20px
          box-shadow: '3px 3px rgba(0,0,0,0.4)'
          color: '#999999'
        type: 'custom:card-modder'
card-modder
How should I change it so it look the same but using ā€œcard-modā€?
See the very bottom of this:
And
would become
I just started using this today so take my advice with a spoonful of salt :stuck_out_tongue_winking_eye:
No that didnt work at all. Removed all style from card.
Solution:
card:
  cards:
    - entities:
      title: Dƶrrsensorer
      type: entities
style: |
  ha-card {
    --ha-card-background: rgba(50,50,50,0.3);
    background-image: url("/local/lovelace/cardbackK.png");
    background-repeat: no-repeat;
    background-size: 100% 100%;
    border: solid 1px rgba(100,100,100,0.3);
    border-radius: 20px;
    box-shadow: 3px 3px rgba(0,0,0,0.4);
    --primary-text-color: #999999;
type: 'custom:mod-card'
I think it would be better for you to add the styles to each card individually.
In yaml mode, you can do this easily using yaml node anchors:
type: glance
title: First card
style: &my_style |
  ha-card {
    ... etc...
entities:
  ... etc...
... etc...
type: glance
title: Second card
style: *my_style
entities:
  ... etc...
... etc...
type: glance
title: Third card
style: *my_style
entities:
  ... etc...
Try the explanation of the process in the readme.
Thatā€™s pretty much exactly what I ended up doingā€¦even used anchors like you siggested (thanks for the great write-up on your website btw).
However, you did just teach me something else. I didnā€™t know I could create the anchor in line from the first instance and then reuse. I added a section at the heading of my yaml file insteadā€¦but I like your way better.
anchors:
  styles:
# Blinking Red
    alerting: &alerting
      style: |
        @keyframes blink {
          50% {
            background: red;
        ha-card {
          --ha-card-background: rgba(200, 0, 0, .5);
          animation: blink 5s linear infinite;
          border-radius: 2px;
          --primary-text-color: blue;
      card:
# Blue with white border amd samll caps
  mystyle1: &mystyle1
    style: |
      ha-card {
        --ha-card-background: var(--paper-item-icon-active-color);
        border-radius: 5px;
        border: 2px groove grey;
        box-shadow: 0px 0px 10px 3px var(--paper-item-icon-active-color);
    card:
I am trying to define the color of the icon in a custom:fold-entity-row card.
I am using something like:
- type: entities
  style:
    "#states div":
      fold-entity-row:
         #head ha-icon {
           color: .....;
  entities:
    - type: custom:fold-entity-row
but I am doing something wrong.
Is it possible to use the Card-mod to hide the state value for an entity?
I have several entities in a standard Entities Card, for one of the entities I just want display the icon (changing with state) and the friendly name.
entities:
  - entity: binary_sensor.sun_is_up # Hide the state value
  - entity: sensor.sun2_sunrise
title: Astronomy
type: entities
Probably.
Alternatively you can use this card, again by Thomas.
Iā€™ve managed to change the color of the header and item icon colors in a fold-entity-row card like this:
      - type: entities
        debug_cardmod: true
        style:
          "#states div":
            fold-entity-row:
                "#head":
                    hui-group-entity-row:
                        hui-generic-entity-row:
                            state-badge:
                                ha-icon: |
                                  :host {
                                    --paper-item-icon-color: red;
                "#items":
                            state-badge:
                                ha-icon: |
                                  :host {
        entities:
          - type: 'custom:fold-entity-row'
            head: group.downstairs_lights
            head: group.upstairs_lights
Iā€™d like to change the icon color based on the state of the ha-icon element either through a theme attribute (none of the *-active-icon ones appear to work) or via CSS magic like [data-state!=on], but I havenā€™t figured it out yet.
Does anyone have any idea how you replace the report_size option from card-modder with equivilent functionality from card-mod?
Is it possible to remove the margins around ā€œhui-horizontal-stack-cardā€?
