šŸ”¹ Card-mod - Add css styles to any lovelace card
Nope, sorry.
AFAIK that setting is not even hot-reloadable, so move config and restart is probably the best option right now.
tbh, I havent met many issues during the HA changes, in fact, I can only see 1 mod not working anymore. I have meticulously read the posts above and many come close, but just not exactly:
  - type: custom:template-entity-row
# https://community.home-assistant.io/t/card-mod-add-css-styles-to-any-lovelace-card/120744/2182?u=mariusthvdb
    entity: binary_sensor.vijverpompen
    card_mod:
      style:
        div#wrapper: |
          state-badge {
            {% if is_state(config.entity,'on') %}
            animation: rotation 2s linear infinite, colorize 5s linear forwards 1;
            {% endif %}
          @keyframes rotation {
            0% {
              transform: rotate(0deg);
            100% {
              transform: rotate(360deg);
          @keyframes colorize {
            0% {
              color: steelblue;
            100% {
              color: aquamarine;
still makes my entity icon rotate, but the colorization is goneā€¦
anyone with a hint, please come forward? thanks!
Thanks Thomas, thatā€™s worked a charm! :smiley: Iā€™m a happy chappy again!!
Thanks! I noticed a bunch of button cards I had styled with colors (representing a cheap battery powered usb lampā€™s IR-controlled colors) were all using my default theme about half the time when reloadingā€¦it was starting to drive my OCD a little crazy :slight_smile: thinking it was something wrong on my end.
Looks much better now!
Screen Shot 2021-11-12 at 10.47.13 AM
at least this works:
type: entities
entities:
    entity: binary_sensor.test_value_from_input_boolean
    secondary: some value
    state: state
    icon: mdi:fan
    card_mod:
      style:
        div#wrapper: |
          state-badge {
            animation: rotation 0.5s linear infinite, resizing 1s linear infinite alternate, coloring 8s linear infinite alternate;
            0% {
            100% {
          @keyframes resizing {
            0% {
              --mdc-icon-size: 10px;
            25% {
              --mdc-icon-size: 15px;
            50% {
              --mdc-icon-size: 20px;
            75% {
              --mdc-icon-size: 26px;
            100% {
              --mdc-icon-size: 32px;
          @keyframes coloring {
            0% {
              color: red;
            17% {
              color: orange;
            34% {
              color: yellow;
            51% {
              color: green;
            68% {
              color: lightblue;
            85% {
              color: blue;
            100% {
              color: violet;
Untitled Project
thanks Ildar. Since that is quite identical to what I am using, what do you think could be the desicive difference?
is the difference.
Should be ā€œ1 forwardsā€.
Also the first frame must be a default icon color
Ill test, thanks. It was working fine though, so youā€™re saying this is because changes in HA lately?
nope, doesnt work. btw, this same coloring does still work on a glance card:
card_mod:
  style:
    '.box div:nth-child(3)':
      'div:nth-child(1)':
        ha-icon-button:
            mwc-icon-button:
                .mdc-icon-button {
                  {% if is_state('switch.vijverpomp_links','on') %}
                  {% endif %}
                  0% {
                  100% {
                  0% {
                    color: var(--text-color-off);
                  100% {
                    color: aquamarine;
puzzling this isā€¦
copying your config above shows it doesnt workā€¦
Nov-12-2021 23-01-10
maybe my card-mod-theme interferes, Ill turn that off and see what happens.
Nope, that doesnt help eitherā€¦
Cannot tell, I have never tested this case before.
Is there a means to modify the icon sizes and spacings in the thermostat card? I currently get this:
2021-11-12 12_17_02-
And Iā€™d like to either hide the ā€œAutoā€ icon (left) or get all icons on the same line as it is in the fullsize view.
Edit: So I found that this will reduce the size of the icons, but it will not change anything about their spacing:
                entity: climate.heating_sascha
                card_mod:
                  style:
                    ha-icon-button:
                        ha-svg-icon {
                          height: 75% !important;
                          width: 75% !important;
The order of arguments is important.
https://www.w3schools.com/cssref/css3_pr_animation.asp
Are you sure you are talking about Glance card?
Rotating for Glance card is done for state-badge.
Probably you meant Picture Glance card.
Faced a new issue with the HA Editor:
  1. Create a new card via UI, copy/paste this code into Editor:
type: glance
entities:
  - entity: sun.sun
  - entity: sun.sun
    icon: mdi:fan
    card_mod:
      style: |
        state-badge {
          color: orange;
  1. The screen is:
  2. Save the code, the screen is:
  3. Open the Editor again, the screen is:
The card_mod code is not displayed.
If you press the ā€œSaveā€ button, the code will probably be saved w/o card_mod.
Curious to know if youā€™re using the new config advised by Thomas Loven.
User DrewXT reported that it fixed the similar issue that he had posted earlier in the thread.
I donā€™t use the editor myself, and havenā€™t really seen many of the issues that some people are reporting, apart from the occasional need for a CTRL+F5 page refresh, but the new config is working well for me.
Cannot understand why - but it really helped:
Now the card-mod code is visible in the Editor.
no sorry, youā€™re right, it is a picture-glance.
type: picture-glance
title: Vijverpompen
image: /local/images/vijver.png
state_filter:
  'off': grayscale(72%)
entities:
  - switch.vijverpomp_links
  - switch.vijverpomp_rechts
  - input_boolean.vijverpompen_alterneren
  - sensor.pond_buiten_sensor_calibrated_temperature
  - binary_sensor.vijverpompen
  - sensor.vijverpompen
card_mod:
  style:
      'div:nth-child(1)':
        ha-icon-button:
            mwc-icon-button:
                .mdc-icon-button {
                  {% endif %}
                  0% {
                  100% {
                  0% {
                  100% {
                    color: aquamarine;
      'div:nth-child(2)':
etc
and the colorize works perfectly. cant get the other options to work, or, rephrase, can not get the template-entity-row to colorize
another (older) card to card_mod: Waze-card.GitHub - royto/waze-card: Lovelace card for showing Waze routes data my regular header card_mod doesnā€™t do anything:
      card_mod: &header
        style: |
          .card-header {
            background-color: var(--background-color-off);
            padding-top: 0px;
            padding-bottom: 0px;
            margin: 0px 0px 16px 0px;
when use on:
  - type: custom:waze-card
    title: Rijtijden
    card_mod: *header
    entities:
I did change .card-header to .header, because thats what inspector indicates the header to be, but still no mod effective. what should I try next?
Earlier I gave an example of template-entity-row, it did not work on your side.
Cache problem? Card-mod-themes problem?
Hello @thomasloven, I officially surrender since I stopped to understand the logic of applying CSS styles (((.
Could you help me?
I am confused about using hui-element - and probably because of the same reason I started stumbling with other cards like restriction-card, fold-entity-rowā€¦
Earlier I think I followed a clear logic of using card-mod - but after a few latest updates I see some failures in my HA setup and ā€œlearning examplesā€.
Letā€™s consider row_type: section.
But first here is a usual section row, we need a red divider line:
CSS tree:
Code:
type: entities
entities:
  - type: section
    label: section 1
    card_mod:
      style: |
        .divider {
          background-color: red !important;
My logic is: we are inside shadowRoot of the hui-section-row, so we must get directly to the .divider element.
Now letā€™s consider a section implemented by hui-element:
CSS tree:
Code:
type: entities
entities:
  - type: custom:hui-element
    row_type: section
    label: section 3 (hui-element)
    card_mod:
      style:
        hui-section-row:
            .divider {
              background-color: orange !important;
My logic is: we are inside shadowRoot of the hui-element, so we must get to the .divider element via hui-section-row$.
But the style is not applied (as it shown on the picture above).
This is working:
Code:
type: entities
entities:
    row_type: section
    label: section 2 (hui-element)
    card_mod:
      style:
          .divider {
And I cannot understand - why do we have to use this construction?
And the simplest case - letā€™s style the hui-element from the entities-card level:
CSS tree:
Code:
type: entities
entities:
    row_type: section
    label: section 4
card_mod:
  style:
    .card-content hui-element:
          hui-section-row:
              .divider {
The style is not applied:
And now I am completely lost.
neitherā€¦ I am lost really. In no browser can I get this to show a coloring and resizing icon. It only spins :wink:
also without any theme, just the HA default theme loaded.
