šŸ”¹ Card-mod - Add css styles to any lovelace card
getting back to this, I have found 2 things:
my custom-ui apparently stops the coloring from happening, spinning works fine
Without custom -ui Safari doesnt do the sizing, but only coloring, Chrome does both.
this is a first, custom-ui blocking card-mod from being effectiveā€¦ and for as far as I have been able to check, only in this template-entity-row config. now how can this beā€¦
Marius, I had to limit using Custom UI in my setup because of the same reasons - mutual negative effect between Custom UI & card-modā€¦
Now I have Custom UI only for:
  • icon colorā€™s for batteries (dependingly on charge level) - and there is no any card-mod styling for these icons in my setup;
  • entity_pictures for persons (dependingly on personsā€™ names);
  • friendly_names for some similar entities (dependingly on entity_ids);
  • icons for some similar input_helpers.
could you help to understand how I can change border-radius for badge
This does not work :frowning:
   badges:
      - entity: person.alex
        card_mod:
          style: |
            :host {
              --ha-label-badge-size: 100px;
              border-radius: 20%;
If you really want it:
      - entity: sun.sun
        card_mod: &ref_card_mod
          style:
            ha-state-label-badge:
                ha-label-badge:
                    .badge-container .label-badge {
                      border-radius: 20% !important;
      - entity: sensor.cleargrass_1_co2
        card_mod: *ref_card_mod
Update 27.02.23:
This approved PR is supposed to add a possibility to use a ā€œ--ha-label-badge-border-radiusā€ variable.
Thank you Ildar.
what do this symbols mean $: $: | ?
or could you forward me to some information to read :slight_smile:
BTW Iā€™m currently testing and trying to improve the performance of my card-mod-places.
Is anyone aware or did some tests, how it is implemented and/or better from a performance perspective, if I have e.g. only one child ā€œbarā€, which I want to mod.
foo:
    bar { color: red }
foo$: |
    bar { color: red }
would of course both work.
But is the first way still better, because e.g. it is implemented that way, that more generic is faster and even if there is only one ā€˜barā€™ or option b, because it is implemented that way, that it then really selects only the first and ingest there. Could be even the other way round and b is slower, because the ā€œselect firstā€ is a whyever implemented special case and therefor perhaps more time consuming.
I fear only Thomas can aswer, but perhaps someone else was either more successfull in finding the answer in the source code than I was able or did tests or have experiences as well.
Same question (first faster, second faster, both equal) for notation/ingestion
card_mod:
  style:
vs.
card_mod:
  style: |
I thought I had the card-mod figured out but then I tried to add a vertical-stack to a modded horizontal-stack and that broke my code.
Does anybody see what I am doing wrong? Slider & ApexChart should take up 75 % and the buttons the remaining 25 %.
@Ildar_Gabdullin : I tried following your examples (amazing compilation by the way, thank you!) but I must be missing some important detail.
Working but without vertical-stack
type: vertical-stack
cards:
  - type: custom:mod-card
    style:
      hui-horizontal-stack-card$: |
        hui-entities-card {
          margin-left: 0px !important;
          margin-right: 0px !important;
          margin-bottom: 0px !important;
          width: 75%;
          flex: unset !important;
    card:
      type: horizontal-stack
      cards:
        - type: entities
          state_color: true
          entities:
            - type: custom:slider-entity-row
              entity: climate.eq_3_living_room
              min: 4.5
              max: 23
              step: 0.5
              hide_state: false
              icon: mdi:fire
            - type: divider
        - type: vertical-stack
          cards:
            - type: custom:button-card
              show_name: true
              show_icon: false
              show_state: false
              state:
                - operator: template
                  value: '[[[ return entity.attributes.temperature == 4.5; ]]]'
                  color: rgb(255, 0, 0)
              tap_action:
                action: call-service
                service: climate.set_temperature
                service_data:
                  temperature: 4.5
                  entity_id: climate.eq_3_living_room
              show_name: true
              show_icon: false
              show_state: false
              state:
                  value: '[[[ return entity.attributes.temperature == 18; ]]]'
              tap_action:
                service_data:
                  temperature: 18
              show_name: true
              show_icon: false
              show_state: false
              state:
                  value: '[[[ return entity.attributes.temperature == 20; ]]]'
              tap_action:
                service_data:
                  temperature: 20
Not working because of vertical-stack
style:
    hui-vertical-stack-card {
      width: 75%;
    hui-slider-entity-row {
      width: 75%;
    hui-apexcharts-card {
      width: 75%;
card:
  cards:
      cards:
          min: 4.5
          max: 23
          step: 0.5
          hide_state: false
          icon: mdi:fire
        - type: custom:apexcharts-card
          graph_span: 24h
          experimental:
            color_threshold: true
          update_interval: 10 s
          now:
            show: false
            color: red
            label: Now
          yaxis:
            - min: 4
          apex_config:
            grid:
              show: false
            chart:
              height: 250px
          series:
            - entity: sensor.eq_3_temperature_lr
              stroke_width: 2
              group_by:
                func: last
              fill_raw: zero
              color_threshold:
                - value: 4.5
                  color: blue
                - value: 18
                  color: yellow
                - value: 20
                  color: red
      cards:
          show_name: true
          show_icon: false
          show_state: false
          state:
          tap_action:
            service_data:
              temperature: 4.5
          show_name: true
          show_icon: false
          show_state: false
          state:
          tap_action:
            service_data:
              temperature: 18
          show_name: true
          show_icon: false
          show_state: false
          state:
          tap_action:
            service_data:
              temperature: 20
yes, I must say I am still much surprised, and this is a unique situation. I mean, most of my entities have some sort of customization, and it never has stopped the card-mods from working. I first took out my full custom-ui, so I noticed this worked, then found it was the
  customize_domain:
    automation:
      templates:
        <<: &state_color
          icon_color: >
            if (state == 'on') return 'var(--primary-color)';
            return 'steelblue';
#    binary_sensor:
#      templates:
#        <<: *state_color
template for the binary_sensor domain hindering. Ive commented that now and see the icon coloring and spinning in Safari tooā€¦ (still not resizing though)
this probably means the custom-ui is either stronger than card-mod (not are how to call it) or executed later, so sticks.
If you have other examples please let me know, so I can have a look. DM if must be.
Iā€™ve asked Thomas if he can explain why this happens.
Cards inside vertical stack are not obliged to stretch themselves vertically.
You need to try layout-card, grid card - cannot tell exactly, not used them so far (may be none of them can help, I do not know).
Also, you may try to specify heights of cards explicitly (do not like it myself since may give different results):
type: custom:layout-card
layout_type: custom:horizontal-layout
layout:
  column_widths: 70% 30%
  width: 220
cards:
    cards:
      - type: entities
        entities:
          - input_number.test_number
      - type: history-graph
        entities:
          - sensor.cleargrass_1_co2
    cards:
        entity: sun.sun
        styles:
          card:
            - height: 91px
        show_name: true
        show_icon: false
        show_state: false
        entity: sun.sun
        styles:
          card:
            - height: 91px
        show_name: true
        show_icon: false
        show_state: false
        entity: sun.sun
        styles:
          card:
            - height: 91px
        show_name: true
        show_icon: false
        show_state: false
Some time ago I experienced some problems, used these medicals. May be it will help you, I do not know)))
haha, no Ive tried that before for another reason (users reported slow loading of the custom-ui some time ago), but I couldnā€™t find any advantage tbh. So move away from that again, using the advised method for installing custom cards again.
The current issue must be in the way both customizers do their job, where custom-ui touches the backend more (hence the customized icons on more-info panels too), and card_mod is solely in the frontend. I thinkā€¦
Everything is changed - HA, custom cards - every new version may hide new surprises.
Now I am a little stuck with hui-elements, lot of things depend on it in my setup.
yes, its a bit frustrating not knowing what/whyā€¦ in my case, the coloring worked just fine before, and I havent changed custom-ui at all, and neither has card-mod as far as I know. So why??
just as odd as not being able to hide the 3 dots in the header menu any longer, or replace it with some replacement
for referenceā€™s sake:
Nov-19-2021 09-17-06
edit
ive went back up to 3.0.9 to see if changed in Card-mod could have caused this, but unfortunately that isnt the caseā€¦ All I can conclude is that some HA change causes this, and which one has to be answered yet ;-(
btw, on the latest download of 3.0.13, the inspector says its .14
Schermafbeelding 2021-11-19 om 11.16.13
Thank you @Ildar_Gabdullin , that fixed the column width problem.
But I have two (hopefully now small) issues remaining:
  1. The column width is defined manually and it seems that this value is mandatory.
layout:
  width: 220
But this results in the columns being pushed below each other depending on the amount of cards in the dashboard despite being shown correctly in editor mode.
ā†’
  1. Is there a way to use % instead of px e.g. for heights?
The latter may also solve the first issue. Essentially I do not want to define the total width of the horizontal-stack, just the ratios inside it.
Current code for reference and sharing :)
layout:
  width: 200
cards:
    cards:
        min: 4.5
        max: 23
        step: 0.5
        hide_state: false
        icon: mdi:fire
        graph_span: 24h
        experimental:
        now:
          show: false
          color: red
          label: Now
        yaxis:
          - show: false
        apex_config:
          grid:
            show: false
          chart:
            height: 100px
        series:
            stroke_width: 2
            group_by:
              func: last
            fill_raw: zero
            color_threshold:
              - value: 4.5
                color: blue
              - value: 16
                color: yellow
              - value: 18
                color: orange
              - value: 20
                color: red
    cards:
        show_name: true
        show_icon: false
        show_state: false
        styles:
          card:
            - height: 50px
        state:
        tap_action:
          service_data:
            temperature: 4.5
        show_name: true
        show_icon: false
        show_state: false
        styles:
          card:
            - height: 50px
        state:
        tap_action:
          service_data:
            temperature: 18
        show_name: true
        show_icon: false
        show_state: false
        styles:
          card:
            - height: 50px
        state:
        tap_action:
          service_data:
            temperature: 20
new challenge: add a bit of vertical spacing to entities in an embedded fold-entity-row card:
this doesnt happen on all embedded f-e-r cards oddly enough, maybe its because of the entity_pictures. and the lack of a secondary row.
  - type: entities
    title: Family tracked
    card_mod: *header_no_margin
    entities:
      - type: custom:fold-entity-row
        head:
          type: section
          label: Marijn
        padding: 0
        entities:
          - device_tracker.unifi_me
          - device_tracker.ping_iphone_me
          - device_tracker.life360_me
          - device_tracker.me_app
          - device_tracker.me
          - device_tracker.owntracks_me
          - device_tracker.calltheboss_me_bt
Still Id like to add spacing, like:
which btw is an auto-entities card expanding a group.
or, a regular entities with the exact same list:
can that be done?
wait, the secondary doesnt help:
now I definitely need a card_mod changeā€¦
btw, ofc I tried to do without the padding: 0 but thats doesnt help.
Sorry about all the confusion here.
Hui-element is supposed to be transparent to card-mod. I.e. styling hui-element should be as if styling the element inside it.
I think Iā€™ve managed to fix that for 1.1.2, but there are lots of edge casesā€¦
- type: entities
  entities:
    - type: section
      label: Default internal styling
      card_mod:
        style: .divider { background-color: red; }
    - type: custom:hui-element
      row_type: section
      label: Hui-element internal styling
      card_mod:
        style: .divider { background-color: green; }
- type: entities
  entities:
    - type: section
      label: Default styled from card
      row_type: section
      label: Hui-element styled from card
  card_mod:
    style:
      hui-section-row $: .divider { background-color: blue; }
      hui-element $: .divider { background-color: orange;}
Seems that you applied a style to a wrong element - rotation is not centered, there is a shift.
Cannot react on this, know nothing about card-mod-themesā€¦
Same on my setup, strange.
yes, ofc I noticed that, thought it might be the icon not being perfectly centered. Its the same in Chrome. And the code is the exact code you useā€¦
Yesterday was the 2nd time I experimented with layout-card - it is better to discuss these issues in a corresponding thread.
That is why I wrote that this is not the best solutionā€¦
I do not know how to align controls automatically.
