🔹 Card-mod - Add css styles to any lovelace card
Wanting to apply the performance fix, but in doubt of the exact path to add.
My card_mod lives in:
/www//community/lovelace-card-mod/card-mod.js
I assume the path to add would be /community/lovelace-card-mod/card-mod.js?
Just copy the path from settings-lovelace-ressources.
Hi, running card mod version:
But i’m having background issues? Seems style isnt applied?
  extra_module_url:
    - /local/community/lovelace-card-mod/card-mod.js
the code above fixes the card background issues for Chrome and webbrowsers, but the background is still visible on the companion app? is this a bug in card mod or companion app?
Did you get this answered? I removed mine from the resources as the directions say instead. Just trying to verify that I read them correctly.
Not (yet?). I removed it as well. But I’m not sure if there are disadvantages or gaps. I read the instead as well, but saw the warnings and the re-adding after updating. Because of that my (currently unanswered) double check question to Thomas.
I loaded it in both places as well. Error message if not loaded in resources.
I’m having a couple of issues with my badges:
The first two aren’t supposed to show until they get activated but for some reason they’ve started showing when I load the page. If I edit the config and save they disappear again until I refresh again.
      - entity: binary_sensor.bath_water_leak
        icon: mdi:alert
        style: |
          @keyframes blinker { 50% { opacity: 0; } }
          :host {
            --label-badge-background-color: red;
            animation: blinker 1s linear infinite;
            display:
              {% if is_state('binary_sensor.bath_water_leak', 'off')  %}
                none;
              {% endif %}
      - entity: binary_sensor.alarm_landing_smoke_detector_smoke
        icon: mdi:alert
        style: |
          :host {
            display:
              {% if is_state('binary_sensor.alarm_landing_smoke_detector_smoke', 'off')  %}
                none;
              {% endif %}
The second issue is one I’m just trying to figure out. In the third badge, for some reason when I add an icon to an input_boolean badge it tries to show the state as well. This probably isn’t card-mod related but I was wondering if there was some magic to get rid of the text? This one has been bugging me for a while!
Add card_mod keyword.
I’m trying a slightly different spin on this, to show if the fan is running in our relevant zones or not. the state of the icon changes, but I’m not getting a rotating icon. Not sure where I’m going wrong, I’ve read through the doco…
My cards looks like this…
title: Sewing Room
mode: vertical
cards:
  - type: custom:simple-thermostat
    entity: climate.sewing_room_air_conditioner
    step_layout: row
    show_header: false
    control: false
  - type: custom:stack-in-card
    mode: horizontal
    cards:
      - type: glance
        entities:
          - entity: switch.sewing_room_zone
            icon: mdi:fan
            tap_action:
              action: toggle
        show_name: false
        show_state: false
        card_mod:
          style:
            div#wrapper: |
              state-badge {
                animation: rotation 0.5s linear infinite
              @keyframes rotation {
                0% {
                  transform: rotate(0deg);
                100% {
                  transform: rotate(360deg);
      - type: custom:mini-graph-card
        entities:
          - entity: sensor.sewing_room
            smoothing: true
            show_fill: true
          - entity: sensor.sewing_target_temp
            smoothing: true
            y_axis: secondary
            color: orange
            show_line: false
            show_points: false
            show_legend: false
            aggregate:func: max
            smoothing: false
        hours_to_show: 24
        points_per_hour: 4
        line_width: 2
        font_size: 90
        animate: true
        show:
          icon: false
          state: false
Where did you take this example?
Probably from template-entity-row.
You cannot apply styles from one card (history-graph card, for instance) to absolutely different card (glance).
Examples for glance are provided in the corr. post (see the 1st post).
If no animations are provided in the post - do it by yourself like styling an icon.
I got the example from the one you were helping Marius with… I’ll go back and have a look again - thanks
Thanks but this doesn’t seem to make a difference. I think I’m doing it right?
   badges:
        icon: mdi:alert
        card_mod:
          style: |
            :host {
              display:
                  none;
                {% endif %}
I also tried as per the example and I had to reverse the condition but it still did the same showing after a refesh despite the condition being negative.
        icon: mdi:alert
        card_mod:
          style: |
            :host {
              {% if is_state('binary_sensor.bath_water_leak', 'on')  %}
              display: inline-block;
              {% else %}
              display: none;
              {% endif %}
I do not see this “refresh” issue when using as a badge on the view’s top:
title: test-2
path: test-test-2
panel: false
badges:
  - entity: input_boolean.test_boolean
    card_mod:
      style: |
        :host {
          {% if is_state('input_boolean.test_boolean', 'off')  %}
          display: none;
          {% endif %}
cards: []
I registered this issue:
Would be very grateful if someone simulates the same condition and gives a feedback.
The problem started with 3.1.x.
Do not observe it with 3.0.13.
this is the bit where I’m struggling with the syntax… it’s a bit beyond me, I can happily change the colour of an icon for a switch, but I can’t manage to get them changing colour or animated via styling… CSS has never been my strong point, and it’s shining through now :frowning:
I can use button-card to achieve a similar outcome, but it loses haptic feedback on Android for the switch toggle, which is a shame
new challenge, trying to make the fold cards fill 100 with the image and background.
the stack I cards show perfectly when used standalone (as I had them up to now) but I want to declutter my frontend and fold these cards in an entities like below. Seems obvious enough, set the margin for the stack to 0px -16px -16px -16px. that does move the entities though, and not the color or the background image…:
  - type: entities
    title: Met de trein
    card_mod: *header_no_margin
    entities:
      - type: custom:fold-entity-row
        head:
          type: section
          label: Ns
        padding: 0
        entities:
            keep:
              background: true
            cards:
              - type: picture
                image: /local/images/ns.jpg
                hold_action:
                  action: url
                  url_path: https://www.ns.nl
              - type: entities
                card_mod:
                  style: |
                    ha-card {
                      --ha-card-background: rgb(255,203,0);
                      color: rgb(15,34,132);
                title: Ns reizen
                show_header_toggle: false
                entities:
                  - sensor.rotterdam_roosendaal
                  - sensor.roosendaal_rotterdam
                  - sensor.tilburg_roosendaal
                  - sensor.roosendaal_tilburg
        an identical card for another railway ;-)
btw, I also tested stack-in-card for the top card, but that is really ugly:
Does anyone know how to change the border radius of the map card?
What did you try before? I think, something basic like this should work
type: map
card_mod:
  style: |
    ha-card { border-radius: 200px; }
for reference: this is the magic setting:
entities:
    head:
      type: section
      label: Ns
    padding: 0
    card_mod: &fold
      style: |
        div#items {
          margin: 16px -16px -16px -16px;
    entities:
and also applies to map in a fold:
pretty cool, and freely adapted from earlier discussion with @Ildar_Gabdullin :slight_smile: thanks mate
Nice looking))
