🔹 Card-mod - Add css styles to any lovelace card
I propose you to use a bar-card instead)))
Vertical, no icon, indicator, state and name.
Even you may animate the process of filling the tank - see my example (1st post → link at the bottom → styles for bar-card).
I am trying to hide the icon and entity name of my entity card, but it doesn’t do anything.
the ha-card part is working.
type: entities
style: |
  ha-card {
    background-color: transparent !important;
    box-shadow: none !important;
  .info {
    display: none;
entities:
  - entity: sensor.calculation
title: "test"
i have a question. Can i remove a margin at an element? I removed the icon from an entity in an entities card, but now there is a margin on the left of 16px. I tried this but it doesn´t change anything:
        card_mod:
          style:
            hui-generic-entity-row:
                .info {
                 margin-left: 0px;
                state-badge {
                  display: none;
Thanks for the help.
Thanks Ildar. I have tried combinations of the bar-card and button-card and it is very, very messy. You also do not have much freedom if all the tanks are not the same size and in the same plane.
If I can get the image elements in picture-elements to stretch, then I can put any size of tank anywhere. I made up this example just to explain what I am trying to do. My actual card is much more complex.
I am sure the problem is I am not using the correct CSS element or it is hidden under that shadow-root blanket of CSS magic. I have read everything I could find on this and I am 100% convinced it is my lack of CSS skills that is holding me back here.
If it is due to the element being in a shadowroot (sorry I really don’t know what I am talking about), how do I need to address it? Do I still use :host, or something else?
Sorry - I hope I do not sound rude.
@thomasloven can you confirm how card-mod can access the height inside the image element?
What margin are you talking about?
Check again the example from the post.
My edit did work, when i opened it in another browser.
The top one (End) has the edit, but the bottom one (Remaining) doesn´t. You can see it has a margin on left and right.
Thanks for the response.
Try this instead
type: entities
entities:
  - type: buttons
    card_mod:
      style:
        hui-buttons-base$:
          ha-chip$: |
            .mdc-chip__text::before {
              content: "{{states('sensor.elektra_kosten_totaal')}}";
    entities:
      - entity: sensor.elektra_kosten_totaal
        icon: mdi:lightning-bolt
        show_name: false
        show_icon: true
Any Card-mod gurus able to help me on this? I’m trying to target this state-switch <div> to set overflow: visible so that the background colour/image can ‘escape’.
This is what it currently looks like:
This is the desired look:
This is the <div> I can target with overflow: visible to make it work under styles #root {}:
I’ve attempted to wrap the state-switch-card within a custom:mod-card but I’m not sure if this is the correct approach?
thanks!
YAML
      - type: custom:stack-in-card
        view_layout:
          grid-area: main1
          justify-self: middle
          show:
            mediaquery: '(min-width: 600px)'
        card_mod:
          style: |
            #root {
              overflow: visible !important;
            :host {
              margin-top: -300px !important;
              padding-top: 300px !important;
              margin-left: -4px !important;
            ha-card {
              background-color: rgba(0,0,0,0) !important;
              backdrop-filter: blur(0px) !important;
              border-radius: 30px 30px 30px 30px !important;
        cards:
          - type: custom:mod-card
            card:
              type: custom:state-switch
              entity: hash
              transition: slide-left
              transition_time: 500
              view_layout:
                grid-area: main1
              states:
                kitchen:
                  type: custom:layout-card
                  layout_type: grid
                  view_layout:
                    grid-area: main1
                  layout:
                    grid-template-columns: auto 300px 300px auto
                    grid-template-rows: 1fr
                  cards:
                    - type: custom:mini-media-player
Is it possible to center all of these entities?
Im using multiple-entity-row
type: entities
entities:
  - entity: sensor.nordpool_kwh_se3_sek_3_095_0
    type: custom:multiple-entity-row
    icon: none
    state_header: Spotpris
    entities:
      - entity: sensor.pool_heater_power
        format: precision0
        unit: watt
      - entity: sensor.daily_energy_peak
        format: precision2
      - entity: sensor.monthly_energy_peak
        format: precision2
I just can’t cope with the scrollbar.
I try to remove it by making it wider. I change the width in the inspector and it works. But I can’t figure out where my mistake is.
Inspector path:
/html/body/home-assistant//home-assistant-main//app-drawer-layout/partial-panel-resolver/ha-panel-lovelace//hui-root//ha-app-layout/div/hui-view/hui-masonry-view//div/div[2]/hui-vertical-stack-card//div/hui-entities-card//ha-card/div/div[3]/hui-element//hui-horizontal-stack-card//div/mod-card[2]//ha-card/hui-entities-card//ha-card/div/div/hui-buttons-row//hui-buttons-base//div
Screenshot
My code:
YAML
                  - type: 'custom:hui-element'
                    card_type: horizontal-stack
                    cards:
                        card:
                          type: entities
                          entities:
                            - entity: input_select.nachalo_stirki
                              card_mod:
                                style:
                                  hui-generic-entity-row $: |
                                    state-badge {
                                      display: none;
                          card_mod:
                            style: |
                              ha-card {
                                box-shadow: none;
                        card:
                          type: entities
                          entities:
                          - type: buttons
                            entities:
                              - entity: automation.wm_start_auto
                                state_color: true
                                icon: 'mdi:washing-machine-alert'
                                name: Запустить по расписанию
                                tap_action:
                                  action: call-service
                                  service: automation.toggle
                                  service_data:
                                    entity_id: automation.wm_start_auto
                                card_mod:
                                  style:
                                    hui-buttons-row $ hui-buttons-base $: |
                                      .ha-scrollbar {
                                        width: 130% !important;
                          card_mod:
                            style: |
                              ha-card {
                                box-shadow: none;
What is now:
What I want to get:
I would be grateful for any help and / or any recommendations for improving the code.
Perhaps it would be more correct to change the width of the column of a horizontal stack, for example, in a ratio of 40/60%?
Also I want to resize all the icon size separate, but I cant get it to work. Any tips how and where to put the card-mod is appreciated!
My code:
entity: sensor.nibe_bt50_room_temp_s1
icon: none
state_header: Inne
format: precision1
entities:
  - entity: alarm_control_panel.verisure_alarm
    style:
          state-badge {
            --mdc-icon-size: 50px;
    format: precision1
    icon: true
    state_color: true
  - entity: binary_sensor.all_doors
    icon: true
    state_color: true
    hide_if: 'on'
  - entity: binary_sensor.garageport_status_door
    icon: true
    state_color: true
    hide_if: 'on'
  - entity: sensor.nibe_bt1_outdoor_temperature
    format: precision1
Create a small code snippet describing your case and post here.
Currently it is hard to understand the problem w/o seeing the code.
The first thought:
As I already told you:
Why using hui-element?
The only case is “use horizontal stack inside Entities card”.
But in this case the left card will be not aligned with respect to other entity rows:
type: entities
entities:
  - sun.sun
  - type: custom:hui-element
Wrong style.
Styles for buttons described here.
Should be:
          - type: buttons
            entities:
              - entity: automation.test
            card_mod:
              style:
                  .ha-scrollbar {
And the total code is (assuming that the stack is placed inside Entities card):
type: entities
entities:
  - sun.sun
    cards:
      - type: entities
        entities:
          - entity: input_select.test_value
            card_mod:
              style:
                  state-badge {
                    display: none;
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
      - type: entities
        entities:
          - type: buttons
            entities:
                state_color: true
                icon: mdi:washing-machine-alert
                tap_action:
                  service_data:
                    entity_id: automation.test
            card_mod:
              style:
                  .ha-scrollbar {
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
This variant looks more aligned:
type: entities
entities:
  - sun.sun
    mode: horizontal
    card_mod:
      style:
        hui-horizontal-stack-card $: |
          div#root :first-child {
            width: 45%;
            flex: unset;
          ha-card {
            box-shadow: none;
    cards:
      - type: entities
        entities:
            card_mod:
              style:
                  state-badge {
                    display: none;
                  ha-paper-dropdown-menu {
                    margin-left: 8px !important;
        card_mod:
          style: |
            .card-content {
              padding: 0px;
      - type: entities
        entities:
          - type: buttons
            entities:
                state_color: true
                tap_action:
                  service_data:
            card_mod:
              style:
                  .ha-scrollbar {
                    justify-content: flex-end;
                    padding-right: 0px !important;
                  .ha-scrollbar ha-chip {
                    padding-right: 0px ;
        card_mod:
          style: |
            .card-content {
              padding: 0px;
              padding-top: 4px;
@Pelican
Check this:
type: vertical-stack
cards:
  - type: entities
    entities:
      - entity: input_number.test_number
  - type: picture-elements
    style: |
      ha-card {
        --image-height: {{states('input_number.test_number')|int}};
    elements:
      - type: image
        image: /local/images/blue.jpg
        style:
          transform-origin: left bottom
          left: 110px
          top: 439px
          width: 82px
          height: 1px
          transform: translate(-50%,-50%) scale(1,var(--image-height))
    image: /local/images/tank.png
Untitled Projectdddd
BUT - I gonna disappoint you - the image elements do not keep the same position with respect to the main image because the main image is scaled automatically dependingly on the card size! That means that the water will be in the tank only if the card’s size is constant.
Here is a case when the card’s size is changed:
And specifying positions & sizes in “%” does not help.
@Ildar_Gabdullin you are a genius! Thank you very much.
It works perfectly. The masks are made with the same width as the main image and I position them at full width, so they scale perfectly. My final solution ended up making the main image “full” and the masks look “empty”. I position the masks at some % from top of the main image and scale them down according to the depth sensor. It also works on my phone.
The sensor values have to be made to be a percentage either in the sensor integration (ESPHome in this case) or in the card.
I believe this is the best solution for showing tank levels and I can’t thank you enough for your help.
So to be complete, here is the yaml:
      image: /local/background_image.png
      card_mod:
        style: |
          ha-card {
            --mask1-height: {{states('sensor.level1')|int}};
            --mask2-height: {{states('sensor.level2')|int}};
      elements:
        - type: image
          image: /local/mask1.png
          style:
            top: 0%
            width: 100%
            height: 1px
            transform: translate(0%,0%) scale(1,var(--mask1-height))
        - type: image
          style:
            top: 0%
            width: 100%
            height: 1px
            transform: translate(0%,0%) scale(1,var(--mask2-height))
But in your example the top = 0.
IMHO the most tricky part is to calculate top position of the image…
The images must keep relative positions after resizing of the window.
Hi @Ildar_Gabdullin
You are right. I am applying it in a few different scenarios and the top may not always be at 0. Here is what the first application looks like:
The aerator and (animated) bubbles are simple SVGs elements. Mask1 overlays the bubbles, so the bubble level is always right. I have some other applications where the top levels will not be the same.
You are 100% correct in that the top position is the hardest, but if all your masks have the same width it becomes a lot easier.
Do you specify “top” in px or % ?
I used % for the tops. Only px I used was for the mask height.
Please post a sample code for calculating “top”.
