šŸ”¹ Card-mod - Add css styles to any lovelace card
icons are also sag images, so you can add:
            style:
              hui-generic-entity-row:
                  .info.pointer.text-content:before {
                    background: url("/local/weather/laptop-mac.svg");
                    content: "----";
                    color: transparent;
                    background-size: cover;
they have to be in /local though. I tried to add it from custom_icons in the config root, and that would work, though inspector showed the correct path, it claimed it couldnā€™t find itā€¦
You may make the 1st divider transparent.
Kind of:
type: entities
title: Header
entities:
  - &ref_0
    type: custom:fold-entity-row
    head:
      type: section
      label: Label
    padding: 0
    entities:
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
  - *ref_0
  - *ref_0
  - *ref_0
  - *ref_0
  - *ref_0
  - *ref_0
  - *ref_0
card_mod:
  style:
    .card-content div:
      fold-entity-row $ hui-section-row $: |
        .divider {
          margin-top: 0px !important;
      fold-entity-row $: |
        ha-icon {
          margin-top: 8px !important;
    .card-content:
        .divider {
          background-color: transparent !important;
      .card-header {
         background-color: var(--divider-color);
         padding-top: 0px;
         padding-bottom: 0px;
       .card-content {
         overflow: hidden scroll;
         max-height: 366px;
         margin-top: 0px;
         margin-bottom: 16px;
azxsw
Iā€™ll try to check it.
I do not see any try with card_mod, the topic you have put your question. Where is it?
Anyway: First you should always read šŸ”¹ Card-mod - Add css styles to any lovelace card - #1396 by Ildar_Gabdullin. As most of the times, there are examples for the cards, here picture-elements.
Above, I pointed to the CSS-values, you should try to adjust. And as expected, it seems, that it is directly working.
  - type: state-icon
    card_mod:
      style:
        state-badge:
            ha-state-icon {
              color: red !important;
              filter: initial !important;
Of course, you have to jinja around this to distinguish beteween on and of and replace red with other color or css-variable.
Thx, it works and this is exactly what I wanted. I nearly gave up because while searching, I never came across the post you linked.
I wish something so simple like choosing an icon for the state and its colour was possible via UI in HA, it would save a ton of time for the CSS noobs like me. Anyway, thanks again.
Alright. So I need to apply it to the whole card, applying it to a row is not possible, right?
So I need to rework my whole section. Because this is what I currently use (for maaaaany sensors) and I only want the type: weblink row to move to the right a bit.
        - type: conditional
          conditions:
            - entity: sensor.haos_update
              state: 'on'
          card:
            type: entities
            entities:
              - type: custom:multiple-entity-row
                toggle: false
                state_color: false
                show_state: false
                secondary_info: ''
                entities:
                    attribute: current_version
                    attribute: newest_version
                state_header: Update?
                column: false
              - type: weblink
                name: Gehe zu Config-Dashboard
                url: /config/dashboard
                icon: mdi:arrow-right
            card_mod:
              style:
                  ha-card {
                    margin-left: 1px;
                    margin-right: 1px;
                    #margin-top: -10px;
                    margin-bottom: -25px;
                    #box-shadow: none;
Is it possible to combine the hui-generic-entity-row: with the padding-left: xxpx;?
This did NOT work for me. Possibly because I nested the entities card within a conditional card, right?
        - type: conditional
          conditions:
              state: 'on'
          card:
            type: entities
            entities:
                toggle: false
                state_color: false
                show_state: false
                secondary_info: ''
                entities:
                column: false
              - type: weblink
                card_mod:
                  style: |
                    hui-generic-entity-row {
                      padding-left: 44px;
            card_mod:
              style:
                  ha-card {
                    margin-left: 1px;
                    margin-right: 1px;
                    #margin-top: -10px;
                    #box-shadow: none;
UI hacking is soooooo complicated. Learned a lot but still feeling like first hour in first classā€¦ :joy:
The 3rd card in my example contains different styles for each row.
Using ā€œ#ā€ to comment does not work here.
The header will not be displayed since " show_state: false".
This kind of styles should be defined as:
            card_mod:
              style: |
                ha-card {
This row is not "hui-generic-entity-row".
Always use Code Inspector for styling:
ŠøŠ·Š¾Š±Ń€Š°Š¶ŠµŠ½ŠøŠµ
Your element is ā€œaā€.
Why is this better or needed?
Hey Ildar, getting back to this. It was one of the last cards I had still to perfectionizeā€¦
even with your exact config, the text of my template would still run through the images, because it crosses the half of the card, as you can see below.
Even after having cut the word Media in each attribute. (see the template in the config)
So I decided to give it a try an have them vertically stacked, first the markdown, below the image, and found only 2 ways to do so really.
1- a core entities card and set a background on that (and an empty entities list). We need to set the height of the background manually, and that is a bit of a trial and error, but, the end result is really nice
2- a custom:button-card, set to 1/1, no action (can change of course) and nothing fancy
for both cards I needed to find a way to fill the full width. 16px allround. this is what I did:
1- entities card
type: vertical-stack
cards:
  - type: custom:auto-entities
    show_empty: false
    card:
      type: entities
      title: Plex Playing
      card_mod:
        style: |
          .card-header {
            background-color: var(--background-color-off);
            color: var(--text-color-off);
            padding-top: 0px;
            margin: 0px 0px 16px 0px;
    filter:
      include:
        - entity_id: 'media_player.plex*'
          state: /playing|paused|'on'/
          options:
            type: custom:hui-element
            card_type: markdown
            card_mod:
              style: |
                ha-card.type-markdown {
                  box-shadow: none;
                  margin: -8px -16px;
            content: >
              {% set player = config.entity %}
              {% if states(player) not in ['unknown','unavailable'] %}
              {%- for attr in states[player].attributes %}
                {%- if not attr in ['media_content_id','icon','entity_picture', 'hide_attributes',
                                    'media_position_updated_at', 'media_duration','media_position',
                                    'player_source', 'media_content_rating',
                                    'is_volume_muted','username','friendly_name', 'volume_level',
                                    'supported_features'] %}
                {{attr.split('media_')[1]|replace('_',' ')|title}}: {{states[player].attributes[attr]|title}} {%- endif %}
              {% endfor %} User: {{state_attr(player,'username')}}
              {% else %} Nothing playing
              {% endif %}
          sort:
            method: name
    show_empty: false
    card:
      type: entities
      card_mod:
        style: |
          ha-card {
            margin: -8px 0px 0px 0px;
            box-shadow: none;
    filter:
      include:
          options:
            card_type: entities
            card_mod:
              style: |
                ha-card {
                  background: url({{state_attr(config.entity,'entity_picture')}});
                  box-shadow: none;
                  margin: -16px;
                  height: 500px;
            entities: []
and the button-card:
replace with
    show_empty: false
    card:
      type: entities
      card_mod:
        style: |
          ha-card {
            box-shadow: none; /* not really necessary because of button card mode below */
          .card-content {
            margin: -16px;
    filter:
      include:
          options:
            type: custom:button-card
            aspect_ratio: 1/1
            show_name: false
            show_icon: false
            tap_action: none
            card_mod:
              style: |
                ha-card {
                  box-shadow: none;
result:
note the button really is square, the entities card seems a longer image.
On the iPhone this fits the full screen perfectly.
I also tried it with core picture card, but ofc it complains it needs an imageā€¦ didnt really try hard yet, and maybe I can overcome that with config-template-card. That would require yet another custom-card, and Iā€™d like to keep it as simple as can be.
didnt test a stack-in-cardā€¦
but for you I just did, and it works the same, can simply replace vertical-stack with custom:stack-in-card, and still need several of the mods, so no real advantage I guess
I think this construction is ā€œmore traditionalā€, more clear.
The ā€œ.:ā€ means ā€œselect the current elementā€ - but what is a meaning of using this for the 1st selector?
Ok, it is not a mistake to use the ā€œ.:ā€ first - but it is less clear.
O.k. Thanks. Thought there is more in regard to performance or something else. Compare to my questions somewhere above in the thread.
Read this, I find it very useful.
Note that 99.99 % of my examples are WITHOUT optimization but could be a bit MORE CLEAR for new people since they show DOM navigation:
without optimization:
element:
    element:
        element {
with optimization:
element $ element $: |
  element {
Yes. It is. Funny that this was one day before my question above. Didnā€™t see this before and we had the same questions more or less in parallel.
Only donā€™t get the leading $ till now
element-a:
  $ element-b $:
But most probably have to read and re-think the post several times again.
He explains:
will create one card-mod element in each element-a , and one in the shadowRoot of the first element-b in the each element-a .
But refering to this
E.g. the following will apply styles to the #shadow-root of the first action button in an alarm-panel card:
"#armActions mwc-button$": |
This already takes only the first. Or is there something missing in the explanation around ā€œin the eachā€, e.g. ā€œ[only] in the [first shadow root of] each element-aā€?
had another go at the Plex card:
cards:
    show_empty: false
    card:
      type: entities
      title: Plex Playing
      card_mod:
        style: |
          .card-header {
            background-color: black;
            color: orange;
            padding-top: 0px;
    filter:
      include:
          options:
            card_type: markdown
            theme: plex # <-- set background for the markdown and still use a background-image
            card_mod:
              style: |
                  background-image: url('/local/various/plex.png');
                  background-position: right;
                  background-size: contain;
                  background-repeat: no-repeat;
                  box-shadow: none;
                  color: silver;
                  margin: 8px -16px -16px -16px;
            content: >
              <font color='orange'>**User:**</font> {{state_attr(player,'username')}}
              {% for attr in states[player].attributes %}
                {%- if not attr in ['media_content_id','icon','entity_picture','hide_attributes',
                                    'media_position_updated_at','media_duration','media_position',
                                    'player_source','media_content_rating',
                                    'is_volume_muted','username','friendly_name','volume_level',
               <font color=orange> **- {{attr.split('media_')[1]|replace('_',' ')|title}}:**</font> {{states[player].attributes[attr]|title}} {% endif %}
              {%- endfor %}
              {% endif %}
          sort:
            method: name
note:
I wanted to see if I could use the Plex icon as background-image, and that worked well, but, ofc, that removes the option for the background: black which I had set, as background for the Plex colors: orange for bold, silver for regular text.
I almost conceded, but then I suddenly remembered we can set a theme on Markdown cardsā€¦
created this huge theme:
plex:
  card-background-color: black
and set it in the markdown config. So now I can benefit from a background image And a background color!
One more improvement would be to use the User in the card title, must have a look how to do that most efficiently
this helps:
    show_empty: false
    card:
      type: entities
      card_mod:
        style: |
          .card-content {
            margin: -16px;
    filter:
      include:
          options:
            template: button_default_title
              [[[ return 'Plex playing: ' + states['this.entity_id'].attributes.username; ]]]
            show_icon: false
            styles:
              card:
                - color: orange
                - background-color: black
but now I have 3 times the same auto-entities filterā€¦huh? it does work but seems awfully inefficient,
or, for the fun of it, mimicking the iPhone frontscreen:
              [[[ var caption = 'Plex playing:&nbsp';
                  var title = states['this.entity_id'].attributes.media_title;
                  var artist = states['this.entity_id'].attributes.media_artist;
                  var album  = states['this.entity_id'].attributes.media_album_name;
                  return `<div style='display: flex; padding: 0px 16px 0px 0px;'>
                      <div>${caption}</div>
                      <marquee>
                      <span style='color:silver;align-items:center;'>${artist} - ${album} - ${title}</span>
                      </marquee>`;]]]
Feb-02-2022 15-57-33
could be smoother, but hey, whoā€™s complaining
Hello Guys,
I have recently start using Dwainā€™s Dashboard. It look pretty awesome but I am struggling a bit with some CSS changes.
I have this CCS:
I want to apply extra width to the hui-vertical-stack-card , but I have tried serveral things. Nothing seems to work.
    - type: vertical-stack
      style:
         hui-vertical-stack-card:
             .item {
               width: 850px;
Can someone please assist me on this?
You need to wrap your vertical-stack inside a mod-card. Check for it on the card-mod docs.
Thx you for your answer.
I have already managed to fix it with te following
      cards:
        - type: entities
          style: |
            ha-card {
              width: 950px !important;
              max-width: max-content;
            :host {
              width: 950px;
well, I do believe I am lost for options. I did test all (I think) of the examples in this post to style (color) to simple icons:
      - type: conditional
        conditions:
          - entity: binary_sensor.selected_hue_group_active_scene
            state: 'off'
        row:
          entity: script.activate_hue_dynamic_scene
          icon: mdi:play
          action_name: play
          card_mod:
            style:
                  state-badge:
                      ha-state-icon {
                        color: green;
      - type: conditional
        conditions:
            state: 'on'
        row:
          entity: script.deactivate_hue_dynamic_scene
          icon: mdi:stop
          action_name: stop
          card_mod:
            style:
                  state-badge {
                    color: red;
and have no succes at all. Neither of my scripts get a colored icon, do I need a step extra in the path maybe?
hui-conditional-row > hui-script-entity-row").shadowRoot.querySelector("hui-generic-entity-row").shadowRoot.querySelector("state-badge").shadowRoot.querySelector("ha-state-icon").shadowRoot.querySelector("ha-icon").shadowRoot.querySelector("ha-svg-icon")
grrr.
back to custom-uiā€¦
  customize:
    script.deactivate_hue_dynamic_scene:
      icon_color: red
    script.activate_hue_dynamic_scene:
      icon_color: green
Was described here.
      - type: conditional
        conditions:
          - entity: input_boolean.test_boolean
            state: 'off'
        row:
          entity: script.test_script
          icon: mdi:play
          action_name: play
        card_mod:
          style:
            hui-script-entity-row $ hui-generic-entity-row $: |
                state-badge {
                  color: magenta;
I am having a problem changing colour based on state for my alarm system.
I would like sensors to be green if not activated and red if activated.
I am using the following code, but I am still getting yellow if activated and blue if not activated.
Could anyone please offer advice.
Thank you.
type: entities
entities:
  - entity: binary_sensor.downstairs_back
    icon: mdi:window-closed-variant
  - entity: binary_sensor.kitchen_pir
  - entity: binary_sensor.downstairs_front
    icon: mdi:window-open-variant
  - entity: binary_sensor.font_room_pir
  - entity: binary_sensor.pir_util_landing
    card_mod:
      style: |
        ha-card .header .icon {
        {% if is_state(config.entity,'on') %}
          color: green;
          % else %}
          color: red;
        {% endif %}
  - entity: binary_sensor.front_door
    icon: mdi:door-closed
  - entity: binary_sensor.tv_room_pir
  - entity: binary_sensor.upstairs_back
  - entity: binary_sensor.upstairs_front
  - entity: binary_sensor.utility_room
  - entity: binary_sensor.garage_sensor
  - entity: binary_sensor.pir_front_hall
    icon: mdi:motion-sensor-off
state_color: true
using a plain fold:
  - type: custom:fold-entity-row
    head:
      type: section
      label: Alerts settings/selectors
      card_mod: &label
        style: |
          .label {
            margin-left: 0px;
    padding: 0
    no_animation: true
    entities:
      - type: custom:slider-entity-row
        entity: input_number.quakes_near
      - input_select.quakes_near
thereā€™s a cutoff of the balloon on the number slider:
Schermafbeelding 2022-02-05 om 10.51.54
would there be a preferred way of presenting that? Setting a margin on the #items maybe, or on the input_number itself?
btw, if I exchange the top 2 entities you can see the balloon CAN overflow the entity above:
    entities:
might be the best solution, though Id still love to understand whatā€™s happening. Is it the fold preventing the balloon showing, or is it something in the core slider.
