It may not look like much, but Iām kinda proud I was able to get this state text to word wrap! Starting to get the hang of this card mod stuff a little bitā¦
First entity is working great but I cannot make input_select to do same change of color. In fact I cannot change it at all. I think tht i am missing something obvious but after reading posts here and some others I am not sure where to look for mistaktes. I was tying to reuse #1674 but with no luck.
Since 2022.03, the frontend uses Material Web Components for input fields (including input selects) so the whole CSS path has changed - your code may have once worked, but is likely out of date now.
Can you explain in more detail what you want to achieve?
I am running HA core-2022.4.4.
It has never worked since I am working on this since 2 days.
Full card should be something like this concerning āold wayā:
Aim is to use template entity āsensor.danfossmodecheckā (which checks if āinput_select.pctrybā desired mode is equal to another entity that represents current setting on heat pump) to change color of āinput_select.pctrybā so that i will know if sending āmode commandā got to heat pump or not.
Just as on this image posted above (red part):
Thing is I was trying to figure out how do get to this new input fields but using "Chrom DevTools " just showed me that I know to little about CSS and trying to figure out anything by values names in theme file did not work either.
As Chris wrote, that post is OUTDATED - some styles do not work due to āpaper elements ā material web componentsā change.
Currently have no time to fix it.
A bit later I hope.
Even using the browserās code inspector, and knowing the CSS selector path, I couldnāt get anything to work.
In fact, I got some very strange results indeed where the input select would just display the card_mod raw code.
Itās odd, because I have managed to get input date times to work properly with card_mod, but Iām afraid the new MWC input selects appear way beyond my (very limited) CSS knowledge.
After these 4 hours I will just step back from diving into lake of āmore questions then answearsā.
I guess I cannot just proces DOM navigation right.
If it comes handy for someone: For some reason (blurry to me) placing just
card_mod:
style: |
:host {
color: yellow;
under input_select entity causes that all elements:
When I swap the commenting on these two style blocks, I can get the icon colors to change as intended. But, when I introduce the templating, I get an āUnknown errorā with a RELOAD UI button. Any recommendations?
That wonāt work because I have 6 possibilities of conditional cards for total amountā¦ I only shared 2 butā¦ What would be a good thing is a conditional card āif then elseā, at the moment we have only the āif thenā version !
Can anyone help me understand why my markdown card is making line breaks in places that shouldnāt have a line break?! Below is a screenshot of the card, and for some odd reason itās putting a break after āfrostā, āNorthā, and āSouthā?
Yet when I put the same statement in the template editor it outputs fine:
@reste_narquois Thank you. Good catch. In total, I needed to add those āāā and a ā-ā to connect the multi-line jinja2 template entries. Lastly, since it requires lovelace_gen, I had to restart HA.
I feel like this is pretty basic, but Iām still a css fledgling and havenāt been able to get it to workā¦
Iāve got a bunch of children under a hui-conditional-element in a picture-elements card, each formatted āhui-state-label-element $ divā that Iād like to apply the same style to, but everything Iāve tried (various combinations of ., >, #) only applies to the first child . What am I missing?
hui-conditional-element hui-state-label-element $: |
div {
white-space: normal !important;
line-height: 100%;
padding: 5% !important;
width: 90%;
text-align: center;
Im trying my best to find some kind of documentation on how to change the background color of the calendar card, and I have tried my best to figure it out myself. I am trying to change the background of the grid itsself, the card I did manage to change. How can I achieve this?
Update: I figured it out, again thanks to the knowledge shared in this forum;
