šŸ”¹ Card-mod - Add css styles to any lovelace card
yes, and thanks for that, TIL :wink:
where is this transition used in regular Dashboard/Frontend? Must confess I never realized that we have it, and on un-modded cards, I never see that?
btw, the glance-card mod above might not even be functional, given the fact thereā€™s no transition in it in the first place :wink: frontend/src/panels/lovelace/cards at dev Ā· home-assistant/frontend Ā· GitHub
e.g. state icon, bulb colors, opening of dialogs, dropdowns, etc.? But I didnā€™t not check if all this is related to the mentioned single :host entry above. Most probably no, but a lot of transitioning is there, wherever defined everywhere.
right, ofcā€¦ Ill see whether any of this is frustrated/affected at all.
Nobody talked about grid, entities.
We talked about vertical-stack only (w/o decluttering card etc).
cards:
  - &ref_entities_card
    type: entities
    entities:
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
      - sun.sun
  # - type: custom:mod-card
  #   card_mod:
  #     style:
  #       hui-vertical-stack-card$: |
  #         .card-header {
  #           font-size: 10px !important;
  #           color: red !important;
  #   card:
  #     type: vertical-stack
  #     title: Some title
  #     cards:
  #       - *ref_entities_card
  - type: vertical-stack
    title: Some title
    cards:
And ā€œstickingā€ is probably not happening always. In this simple case it sticks.
How is this related to the issue?
Cmon man, whatā€™s up? Why the attitude?
I was talking about a preference for using mod-card in combination with those cards. Opposed to some of the other way more complicated suggestions above.
And because of that I also showed the option for modding both stack gap as well as grid card gap in 1 style.
Because that hasnā€™t been posted in this community before, that seems quite interesting if you ask me.
Feel free to ignore ofc
Cheers!
What are you talking about? I just described facts & corrected some points regarding sticking.
Nobody is blaming you)
cool, sorry if I misinterpreted your tone.
nvm, lets keep up the good work here!
Would someone be able to help me achieve a blinking entity image based on the entity state please? Iā€™ve looked through this thread searaching for entity card examples, but canā€™t find one that is state based. I have gone a bit card-mod blind after scanning through the thread so may have missed what Iā€™m looking for!
I have a basic entities card with the following config:
type: entities
title: Oil Tank
state_color: false
show_header_toggle: true
entities:
  - entity: sensor.oil_status
  - entity: sensor.distance_to_oil
  - entity: sensor.oil_level
    icon: mdi:car-coolant-level
  - entity: sensor.oil_remaining
  - entity: sensor.wifi_signal
My entity ā€˜sensor.oil_statusā€™ instead of an icon, displays my template sensor state picture in my current entities card.
 - name: "Oil Status"
        state: >
          {% if states.sensor.oil_level.state | float(0) > 100 %}
            FULL
          {% elif states.sensor.oil_level.state | float(0) > 75 %}
            GOOD
          {% elif states.sensor.oil_level.state | float(0) > 50 %}
            OK
          {% elif states.sensor.oil_level.state | float(0) > 25 %}
            LOW
          {% elif states.sensor.oil_level.state | float(0) > 0 %}
            WARNING
          {% else %}
            ERROR
          {% endif %}
        picture: >
          {% if is_state('sensor.oil_status', 'FULL') %}
            /local/images/green.png
          {% elif is_state('sensor.oil_status', 'GOOD') %}
          {% elif is_state('sensor.oil_status', 'OK') %}
            /local/images/yellow.png
          {% elif is_state('sensor.oil_status', 'LOW') %}
            /local/images/amber.png
          {% elif is_state('sensor.oil_status', 'WARNING') %}
            /local/images/red.png
          {% else %}
            /local/images/error.png
          {% endif %}
If I want this entity state picture to ONLY blink when the entity card is displaying the picture for the ERROR or WARNING states, how do I configure the card with card-mod?
I believe I need to include some card-mod style such as
 animation: blink 2s ease infinite
if
is_state('sensor.oil_status', 'WARNING' or 'ERROR')
but Iā€™m stuck on the syntax so it only applies to this one entity within the entity card, and still shows the static pictures for this entity when itā€™s not in either of these 2 states.
This must be incorrect, as it isnā€™t having any effect on the standard entity card, however hopefully Iā€™m on the right lines?
type: entities
title: Oil Tank
state_color: false
entities:
    card_mod:
      style:
        hui-generic-entity-row:
            state-badge {
              animation: {% if is_state('sensor.oil_status', 'ERROR') %} blinking 2s ease infinite;
                         {% else %} none
                         {% endif %}
limiting it to just one state for now until I get it working correctlyā€¦
1st post ā†’ link at the bottom ā†’ styles for animation for Entities card
In short - you have not specified your ā€œblinkingā€ function.
Thank you for your help, working correctly now after specifying
@keyframes blinking {
              0% {opacity: 0;}
              100% {opacity: 1;}
Could somebody help a bloody Beginner to alter an Element inside a Shadow Root?
I managed to find and alter ā€˜normalā€™ Elements, but just donā€™t get it with the Shadow-Root Thing :frowning:
I want to remove both Value and Title Elements from a Gauge Card. In Inspector setting Text Size to 0px works quite well.
How can i adress the
"svg class="text" or
"text class="value-text" ?
Iā€™m at the very limits of my CSS knowledge here, and donā€™t actually use the Gauge card myself, but in theory this is how you would access these elements, combined with elements before the shadow-root level (here the font-size of the entity name):
- type: gauge
  card_mod:
    style:
      ha-gauge:
          svg.text: |
            text.value-text {
              fill: red;
        ha-card div.name {
          font-size: 10px;
  entity: <your-entity>
However, it depends what aspect of these elements you want to modify. Itā€™s complicated by the fact that these elements are contained within a flexible viewbox, which means that changing things like font-size directly on these elements probably wonā€™t work, as they just get scaled up again by the viewbox properties.
Instead, you would have to change the dimensions of the viewbox itself. Hereā€™s code that works (Firefox browser on Windows desktop) to change both size and color of the gauge value for example, but I have no idea if this would work desirably and consistently across different views, browsers and devices:
- type: gauge
  card_mod:
    style:
      ha-gauge:
          svg.text: |
            text.value-text {
              fill: red;
            svg.text {
              max-height: 26%;
        ha-card div.name {
          font-size: 10px;
EDIT: just re-read your post more carefully, and saw you want to remove name and value entirely. This should do that:
- type: gauge
  card_mod:
    style:
      ha-gauge:
          svg.text {
            display: none;
        ha-card div.name {
          display: none;
  entity: <your_entity>
Whoooa amazing!!! You are a true Hero! It works perfectly :star_struck:
Now, as i want to learn it, im gonna go through all Lines and check all of them for their functionā€¦ Thank you so much again, highly appreciate your help! :slight_smile:
I donā€™t fancy the date and time picker changes from a few releases ago: Theyā€™re too high for my taste, so Iā€™m trying to change it. I donā€™t know if there are theme variables for this (I failed to find any), so Iā€™ve been experimenting with card mod.
I canā€™t figure out the CSS selector chain to achieve this. I even forced some changes by using the * selector for all elements and setting some property values with !important just to get some kind of effect for testing purposes. I went through the CSS selector docs and combinator docs to see if thereā€™s anything I could use.
I donā€™t think what I want to do is possible, but perhaps someone here knows (could find anything on the large card mod threads either) how to achieve this.
Here is a screenshot with the styles applied manually. The hour and minute elements must be styled separately from the AM/PM picker: I couldnā€™t get a parent element styled to do both in one go.
My card config, with one of many variations that Iā€™ve tried:
      - type: entities
        title: Schedule
        show_header_toggle: false
        entities:
          - entity: input_datetime.wake_up_time
            card_mod:
              style:
                hui-input-datetime-entity-row:
                      ha-time-input:
                          ha-base-time-input:
                              .value {
                                height: 3em
          - entity: input_datetime.vacation_start
          - entity: input_datetime.vacation_end
          - entity: binary_sensor.workday
          - entity: binary_sensor.workday_tomorrow
Hi guys,
I am using dwains dashboard v3 and the cyberpunk 2077 theme.
It looks great together but dwains area cards are not labeled as ha-card.
They only have a div class and I canā€™t find out how to apply this to other ā€œcardsā€.
This is html
Card mod should be added at <div class=ā€œflex justify-between h-44 p-3 area-buttonā€ ā€¦ >
An this is the yaml code which is added right now. ha-card should be changed to .area-button.
But just this isnā€™t doing it. I think I am missing something. maybe a class before the area button.
  card-mod-card: |
    ha-card {
      border-radius: 1px;
      clip-path: polygon(
        0% 0%,
        40px 0%,
        45px 4px,
        100% 4px,
        100% calc(100% - 20px),
        calc(100% - 20px) 100%,
        0% 100%
I am thankful for any help!
Iā€™m pretty sure this isnā€™t correct for starters, or at least it doesnā€™t look like anything Iā€™ve done with card-mod. But I donā€™t use Dwainā€™s Dashboard, so I might be completely off the mark here. Or maybe you are using a very old version of the card?
Check the card-mod documentation, but I would expect it to start like this:
card_mod:
  style: |
    ...<etc>
EDIT: on second thoughts, you might be trying to follow the guidance on styling cards without an <ha-card> element. But even that would look something like this (shamelessly copied from the documentation):
card:
  type: vertical-stack # for example
card_mod:
  style: |
    ...<etc>
@reste_narquois This is about card-mod-themes.
That would explain it - suggests OP re-posts here then.
Do not think itā€™s required.
The OP should find out how to style these Area cards first, then he could add the code into themeā€™s file - if he really needs it.
