šŸ”¹ Card-mod - Add css styles to any lovelace card
For about 1 month Iā€™m struggling with this error. When navigating to a tab from another the front-end ā€œrandomly freezesā€ for a second with a blank screen and ā€œReload lovelaceā€ message then after a couple of seconds it reloads itself with this error in developer tools. The problem is that after reload the page doesnā€™t load correctly. This happens approx. every hour. Iā€™m using Hass.io (0.104.3) and card-mod v.12. Please anybody has any idea why this is happening?
Have you tried it without using mod-card? Something like this:
- type: thermostat
  entity: climate.dining_room_thermostat
  style: |
    ha-card {
      --heat-color:  #ffffff;
    round-slider {
      --round-slider-bar-color:  #ffffff;
New feature!
There is a pre-release for version 13 of card-mod which allows for setting styles in your theme, so that they are applied to all cards at once.
Hereā€™s a recording from during development, to show how this can be used to do things which are not normally possible with themes.
See card-mod-themes.md for more info.
To get this in HACS, you need to enable ā€œShow Betaā€ in the card-mod page.
That looks really useful. It would have been a lot more useful, if youā€™d released it before I spent my weekend adding almost identical styles to lots of cards :laughing:.
If I understand it right, I can add settings to a theme which will then affect all relevant elements e.g. cards or other. Unless, the element has itā€™s own dedicated style: section.
So, if I want to tweak a particular card, Iā€™d have to duplicate all of the theme settings to that cardā€™s style: and then modify what I wanted to change?
Iā€™m probably missing something, but would it be better to always apply the theme settings and then any style: settings, which would act as an override, for individual element tweaks?
Combining styles isnā€™t entirely straight forward, and Iā€™m still conflicted about whether thatā€™s a good of bad idea. Thatā€™s part of why I call it beta.
Yes, I do get some odd results even just using card-mod now. But at the end of the day all these tweaks are just merging CSS from a variety of locations arenā€™t they? Anyhow, Iā€™m no expert and I certainly donā€™t have your knowledge of how it works.
Hereā€™s an example:
# themes/airy.yaml
airy:
  rgb-card-mod-card: |
    ha-card.type-entities, ha-card.type-glance {
      background: rgba(0,0,0,0);
      box-shadow: none;
    ha-card.type-picture-entity > .footer{
      bottom: unset;
      top: 0;
  rgb-card-mod-row: |
    :host(:not(.type-section)) {
      display: block;
      background: var(--ha-card-background);
      box-shadow: var(
        --ha-card-box-shadow,
        0 2px 2px 0 rgba(0, 0, 0, 0.14),
        0 1px 5px 0 rgba(0, 0, 0, 0.12),
        0 3px 1px -2px rgba(0, 0, 0, 0.2)
      border-radius: 10px;
      padding: 4px;
    :host(.type-custom-slider-entity-row) {
      padding-right: 16px;
    .divider {
      display: none;
    .label {
      color: var(--primary-text-color);
      font-variant: small-caps;
  rgb-card-mod-glance: |
    :host {
      display: block;
      box-shadow: var(
      padding: 4px !important;
      margin: 0 4px 12px;
      width: calc(var(--glance-column-width, 20%) - 8px) !important;
    .name {
      overflow: unset;
      white-space: unset;
  rgb-card-mod-badge-json: |
        :host {
          --label-badge-red: {% if is_state(config.entity, 'home') %}green{%else%}red{%endif%};
      "ha-state-label-badge": {
          "ha-label-badge": {
            "$": ".label-badge {
                border: 0px;
                box-shadow: var(
                --label-badge-text-color: var(--label-badge-red);
#ui-lovelace.yaml
  - title: Showcase
    badges:
      - device_tracker.demo_anne_therese
      - device_tracker.demo_home_boy
      - device_tracker.demo_paulus
    cards:
      - type: custom:auto-entities
        card:
          type: entities
          title: Lights
          show_header_toggle: false
        filter:
          include:
            - type: section
              label: Dimmable
            - domain: light
              attributes:
                supported_features: ">0"
              options:
                type: custom:slider-entity-row
            - type: section
              label: On/Off
            - domain: light
              attributes:
                supported_features: 0
        card:
          type: glance
          title: Current state
          columns: 3
        filter:
          include:
            - domain: binary_sensor
            - domain: sensor
          exclude:
            - attributes:
                type: browser_mod
        sort:
          method: name
      - type: picture-entity
        entity: camera.demo_camera
Nobody had this error before me? :frowning: Please! Anybody can guide me to resolve this error. :worried: Thank you.
Have you deactivated card-mod to make sure thatā€™s the problem?
Yes. After deactivating card-mod the problem disappears. Tested for about 6 hours without card-mod.
this sounds very promising indeed! thank you for keeping up in developing this great tool.
would this also allow us to set eg state_color: true and use it as a global ā€˜customizingā€™ tool, a bit like custom-ui allowed us to do in states-ui?
If not, would be willing to consider thinking about that please? We really could use a global customizing tool for Lovelace.
Since updating to 0.105.x (currently 0.105.2), some entity types in glance cards no longer accept my styles for the ā€œactiveā€ color. Examples are input_boolean & automation, and both worked fine under 0.104.x. Hereā€™s a snippet from a glance card:
              - entity: input_boolean.heat_water
                tap_action:
                  action: toggle
                hold_action:
                  action: more-info
                icon: 'mdi:fire'
                style: |
                  :host {
                    --paper-item-icon-color:
                      {% if states(config.entity) == 'on' %} red;
                      {% else %} green;
                      {% endif %}
            type: glance
When the input_boolean is off, the icon is green as expected. When itā€™s on, I get the default color (yellow) instead of red. If I open the inspector, I still see the card-mod element in what looks like the correct place with the correct color based on the state, but the icon itself gets the default active color (yellow).
Adding state_color: true to the glance card doesnā€™t help, but I donā€™t think itā€™s supposed to be used there anyway. Same happens for automation entities in a glance card.
Please help me disable the sticky button. My Hass.io ver:0.105.2 (yaml configuration method). In the previous version (card-modder.js) everything worked great! Now - button staying selected after a click. How to apply a style to a pressed button (when pressed and removed the pointer)? Or how to turn off sticking?
  • type: entity-button
    icon: hide
    entity: input_select.remote
    hold_action: none
    tap_action:
    action: call-service
    service: input_select.set_options
    service_data:
    entity_id: input_select.remote
    options: ā€œVSXā€
    style: |
    :host {
    ā€“ha-card-background: linear-gradient(rgba(235,145,70,1), rgba(70,35,0,1) 65%);
or this:
style: |
ha-card {
1
I have created (inspired by @BrianHanifin) what I think is quite a nice UI of for my new garden irrigation system. Except for some empty space Iā€™d like to remove between each ā€˜lineā€™.
In the following pictures I have left a border around each horizontal-stack just to aid seeing what is going on. Each horizontal-stack is made up of one entity and one custom-button but Iā€™d like them to not have so much space around them. The config is at the end of this post.
Is this possible? Is there anyone who can help? Thanks in advanceā€¦
image image
Lovelace View - Each Zone line is an include
      #=== Zone 1
      - !include
        - includes/irrigation/zone_duration_line.yaml
        - cycle: 1
          zone: 1
zone_duration_line.yaml (which has another include for the button)
# lovelace_gen
type: custom:mod-card
style: |
  ha-card {
    border: 1px solid green;
card:
  type: custom:hui-horizontal-stack-card
  cards:
    - type: custom:hui-entities-card
      entities:
        - entity: input_number.irrigation_cycle{{ cycle }}_zone{{ zone }}_duration
          name: Zone {{ zone }}
    #=== Skip Zone
    - !include
      - ../button_boolean_check_box.yaml
      - entity: input_boolean.irrigation_cycle{{ cycle }}_skip_zone{{ zone }}
        layout: name_over_icon
        on_icon: mdi:close-box-outline
        card_width: 50px
        card_margin_top: 1.4em
        card_height: 40px
        card_font_size: 12px
        grid_template_areas: >
          "l" "n" "i" "s"
        grid_template_columns: 1fr
        grid_template_rows: min-content min-content 1fr min-content
        name_justify_self: auto
# lovelace_gen
#=== Boolean Check Box
type: custom:button-card
entity: {{ entity }}
show_name: {{ show_name | default('true') }}
name: {{ name }}
icon: {{ on_icon | default('mdi:check-box-outline') }}
size: {{ size | default('80%') }}
lock:
  enabled: {{ lock_enabled | default('false') }}
styles:
  lock:
    - color: {{ lock_color | default('red') }}
  grid:
    - grid-template-areas: >
        {{ grid_template_areas | default('"n i"') }}
    - grid-template-columns: {{ grid_template_columns | default('1fr 15%') }}
    - grid-template-rows: {{ grid_template_rows | default('1fr') }}
  card:
    - width: {{ card_width | default('') }}
    - height: {{ card_height | default('40px') }}
    - margin-top: {{ card_margin_top | default('-0.3em') }}
    - font-size: {{ card_font_size | default('14px') }}
    - border-radius: {{ card_border_radius | default('10px') }}
  name:
    - justify-self: {{ name_justify_self | default('right') }}
state:
  - value: 'off'
    icon: {{ off_icon | default('mdi:checkbox-blank-outline') }}
    styles:
      card:
        - color: {{ card_off_color | default('var(--secondary-text-color)') }}
      icon:
        - color: {{ icon_off_color | default('var(--secondary-text-color)') }}
Dear community,
I am using a custom:vertical-stack-in-card to compile data from different sensors.
Part of the cards of this main card are conditional cards combined with entity card. How can I remove space between each card when they appear?
  - card:
      entities:
        - sensor.paris_rain_chance
      type: entities
    conditions:
      - entity: sensor.paris_rain_chance
        state_not: '0'
    type: conditional
I will take a look at this. I havenā€™t used lovelace_gen before (Iā€™ve been using decluttering-card) so I have to get it setup. I have been meaning to explore it anyway.
Damn, I love your UI BTW! I love your super compact checkbox with label.
UPDATE: @klogg in zone_duration_line.yaml add the 4 style lines to shrink the top and bottom padding from 16 pixels to 0 pixels.
      style: |-
        #states {
          padding: 0px 16px;
      entities:
        - entity: input_number.irrigation_zone{{ zone }}_duration
I had trouble tracking down why the checkbox stayed lower than the entity on the left, but I found an inelegant, but workingā€¦ work-around. In button_boolean_check_box.yaml add the style lines.
style: |-
  ha-card#card.button-card-main {
    position: relative;
    top: -8px;
Thanks, Like I said, entirely inspired by your post elsewhere!
And even bigger thanks for the white space removal!
I must admit that I play around blindly with those style entries as I donā€™t entirely understand how to identify the elements. But I never would have stumbled upon this solution. Thanks againā€¦
Just for completeness I included a default so that the Weather Adjust check box stays in the right place :slight_smile:
style: |
    position: relative;
    top: {{ vertical_shift | default('auto') }};
Use an entities card instead, and the new conditional row.
Indeed, that is great! I didnā€™t see this coming. Thank you!
