šŸ”¹ Card-mod - Add css styles to any lovelace card
Unfortunately donā€™t work for me :frowning:
Then you are not using, what I have posted. Because of your feedback I have tested it now and as assumed, it is working.
I am sorry! Youā€™re right, I put it in the wrong place!
In card style and not in card_mod->style!
- type: tile
  entity: person.marco
  icon: mdi:account
  show_entity_picture: true
 # This is correct
  card_mod:
      ha-tile-info$: |
        .primary { font-size: 20px!Important; }
  style: |
# This is wrong
#    ha-tile-info$: |
#      .primary { font-size: 20px!Important; }
    ha-card {
      background-color: #383838;
      border: 1px solid;
      border-color: #000000;
      border-radius: 5px;
Thank you!!
TBH, where is the style coming from? And why did you again not use, what I have posted? There should be (better compability) a style below card_mod. See my example.
And of course, you can combine both styles, the one for root and the one for shadow root. See example in this thread. One questions regarding this is only some posts above yours.
This way:
card_mod:
  style:
      ha-card {
        border: 1px solid;
        border-radius: 5px;
    ha-tile-info$: |
      .primary { font-size: 20px !important; }
I usually hardly use card_mod if I donā€™t need it.
Non-standard cards almost all have a ā€œstyleā€ section that works well.
In this case, yes, I agree, it is better to ā€œmergeā€ everything
Iā€™m trying to set the row height of a particular entities card row, but I think donā€™t use the right selector.
- type: entities
          entities:
            - type: custom:template-entity-row
              name: "De temperaturen van de laatste 24 uur:"
              card_mod:
                style: |
                  :wrapper {
                    min-height: 25px;
                  state-badge {
                    display: none;
If I set the min-heigt property in chroom dev tools the height changes.
the state-bage style is working.
Go to this post, scroll down a bit and you see a section on managing entity card row height.
:small_blue_diamond: Card-mod - Add css styles to any lovelace card - Share your Projects! / Dashboards & Frontend - Home Assistant Community (home-assistant.io)
Anyone? Surely this is possible to do somehow?
Possible with card_mod-theme-styling. There is another thread for this, where you can find examples. And you can read this here
e.g.
  card-mod-theme: noctis-grey
  card-mod-more-info-yaml: |
      ha-dialog {
        --mdc-dialog-min-width: 1000px !important;
But as said, somehow ot in this thread. So if you have problems with this, try to move to the other thread with further questions.
Trying to get this to work for my ā€œcustom:template-entity-rowā€
  state: " {{ state_attr ('sensor.average_temperature_entree', 'max_value')}} ĀŗC"
  card_mod:
    style: |
       state-badge {
         display: none;
       hui-generic-entity-row {
         height: 25px;
The state-bage part is working, canā€™t get the hight set. What iā€™m missing?
Try this
        card_mod:
          style: |
            state-badge {
              display: none;
            div#wrapper {
              height: 25px;
              min-height: 25px;
You are trying to apply a style from card X to card Y.
Thanks, that worked.
Sorry, originally posted this in the middle of all the repliesā€¦
I would like to completely remove the app header for a tablet display. I see the example provided in the cookbook for setting app-header display to ā€˜noneā€™, but that just makes the header disappear, but doesnā€™t move the rest of the content ā€œupā€ the page. There is a padding-top of 56px in the example below that needs to be zero.
Iā€™m not very good with CSS, so Iā€™m not sure how this would be accomplished with card-mod (or if it even can)?
How would I specify a change to the padding for that particular div as the id ā€œcontentContainerā€ is not unique. Do I somehow specify the hierarchy of elements? What would that look like in my theme?
Thanks for any pointers,
Paul
Nevermind, I figured it out.
I was using card-mod-root-yaml in my theme, but someone said I should use just card-mod-root and that worked. I was using card-mod-root-yaml based on this example on the github page.
So adding the following to the bottom of my theme (actually Cauleā€™s theme), works
  card-mod-theme: "Caule Light Blue (noheader)"
  # Header
  card-mod-root: |
    app-toolbar {
      display: none;
Sorry for the confusionā€¦
Paul
Hi can anyone help me sizing this image?
it is a picture elements and I wanted to make if smaller in ā€œheightā€
it is not working at all :confused:
tried to debug on CSS and the height is working when applying on img, but how can I do it on card-mod?
ha-card { height: 100px !important }
loool what is the point of the ā€œimportantā€???
hahaha
I would never figure it outā€¦
thanks bro!
The !important rule in CSS overrides previous styling rules.
So your style will be used even if it was defined before, otherwise, it is ignored.
anybody know how I can style the text and margin of an input_button as the head of a fold-entity-row?
I want to change ā€˜PRESSā€™ to ā€˜Startā€™ and move it to the left. Using :host will only effect everything else in the head (icon, label, arrow)
  - type: custom:fold-entity-row
    head: input_button.saugen
    entities:
      - input_select.rooms
      - input_select.robo_fan
      - entity: input_select.robo_mop
        style: |
          :host {
            --mdc-select-ink-color: {{ 'white' if is_state('binary_sensor.roborock_vacuum_a15_mop_attached', 'on') else 'grey' }};
            pointer-events: {{ 'x' if is_state('binary_sensor.roborock_vacuum_a15_mop_attached', 'on') else 'none' }};
