nice.
I am a bit worried about the āopenā else here though.
Weāve discussed this with Thomas before, and as far as I can remember, the outcome was we only need the if.
.header .icon {
{% if is_state('input_boolean.style','on') %} animation: rotation 1.5s linear infinite;
{% endif %}
and the card-mod resource takes care of that in the else caseā¦
please test that if you would, I think it will work without error in the inspector
Weāve discussed this with Thomas before, and as far as I can remember, the outcome was we only need the if .
Thatās just a remnant, before I created a bool for this, I just used a random sensor (like weather), with random states and compared it to ātestā or whatever. I donāt know why. Iāll correct this.
I wouldnāt know how. Iām just guessing things.
i am struggeling with the same thing⦠i just wanted to change the width of the time-input-entity.
finally i went the direct way and changed the values in the time-picker-card.js
i thought about changing the custom cards nesting-sceme to make it card-mod-compatible
best regards
Marin
(Marin)
December 11, 2022, 9:18pm
3997
Hi Ildar,
I just saw this post and found it interesting. Could you help me implementing it to my card as I really donāt have any experience in css. Tried but didnāt work.
I have 2 switches which need to be interlocked. So if one of the two is ON other needs to be disabled until the first one returns to OFF.
How to add your code to this:
type: entities
title: Roletne
show_header_toggle: false
entities:
- entity: switch.dnevni_roletna_mala_zatvaranje
- entity: switch.dnevni_roletna_mala_otvaranje
Cheers!
Please write a code for this logic here, then I will show how to add this logic for CSS attributes.
For me, this is not about CSS, this is about a "input_boolean" or a "switch" state first.
Marin
(Marin)
December 11, 2022, 10:13pm
3999
Well this is what I have now. Other switch is removed when first one is ON but I would like to have it greyed out and disabled.
type: entities
title: Tende i roletne
entities:
- type: conditional
conditions:
state: 'off'
row:
name: Mala roletna - zatvaranje
icon: mdi:window-shutter
- type: conditional
conditions:
state: 'off'
row:
name: Mala roletna - otvaranje
Any conditional styles for ANY case may be coded as:
xxxx {
{% if SOME_CONDITION %}
some_property: some_value;
{% endif %}
Open any example (like you used for disabling a toggle) and place styles (which are in ā{ ⦠}ā) into jinjia āifā¦elseā¦endifā statement.
Marin
(Marin)
December 11, 2022, 11:04pm
4001
So I have this now but I can still press the greyed out toggle switch and I would like to have it disabled.
I donāt know how to do that part.
type: entities
title: testic
entities:
card_mod:
style: |
:host {
{% if is_state('switch.dnevni_roletna_mala_zatvaranje','on') %}
color: var(--disabled-text-color);
--paper-item-icon-color: var(--disabled-text-color);
pointer-events: none;
{% endif %}
card_mod:
style: |
:host {
{% if is_state('switch.dnevni_roletna_mala_otvaranje','on') %}
{% endif %}
You should take a RIGHT styling (not just using ā:hostā) and then insert conditions inside.
Means - that styling which you said ājust saw itā.
tom_l
December 12, 2022, 2:34am
4003
Iām trying to get the same title padding and font for the inline red card as the parent card. This was broken in a recent release:
It works for top level cards:
This is what used to work (card mod theme):
card-mod-theme: day
card-mod-card: |
h1.card-header {
font-size: 20px;
font-weight: 300;
letter-spacing: 0px;
ha-card.inline-card-red {
border: solid 1px #FF6262;
--ha-card-background: linear-gradient(rgba(250,98,98), rgba(255, 255, 255, 0.6) 56px, rgba(255, 255, 255, 0.6) 100%);
ha-card.inline-card-red h1.card-header {
padding-top: 0px;
padding-bottom: 28px;
Top level card:
Inline Card:
It seems there is an extra shadow root placed in the inline card now.
Is that what you expect - same styles for all cards, including internal?
type: vertical-stack
cards:
- type: entities
title: title
card_mod: &ref_card_mod
style: |
.card-header {
font-size: 30px;
font-weight: 800;
letter-spacing: 10px;
padding-top: 40px;
padding-bottom: 40px;
ha-card {
border: solid 1px #00ff00;
entities:
- type: custom:hui-element
card_type: entities
entities:
- entity: sun.sun
title: title
card_mod: *ref_card_mod
- type: entities
entities:
- entity: sun.sun
title: title
Do not bother about colors etc, I changed them to make more vivid (to see if it works).
If yes - then I will try to make a theme.
tom_l
December 12, 2022, 3:10am
4005
Yes, exactly that. It used to work.
Also I have just noticed that the front end devs have added the extra shadow root to one of the energy cards but not another:
10 points for inconsistency.
Hopefully Iāll be able to work that out from your example theme fro the red card.
I finished a theme for your case.
Now busy with adding a āinline-card-redā class, coming soonā¦
My aim was to define a theme which will work for:
entities
glance
other cards with a header like history-graph.
Check this theme:
test_tom_i:
card-mod-theme: test_tom_i
card-mod-card-yaml: |
.card-header {
/* for history-graph & glance */
font-size: 30px !important;
font-weight: 800 !important;
letter-spacing: 10px !important;
.card-header {
/* for entities */
font-size: 30px;
font-weight: 800;
ha-card.inline-card-red .card-header {
/* for some class */
padding-top: 40px;
color: magenta;
ha-card:not(inline-card-red) {
/* for all other classes - need to override parental styles */
border-color: var(--ha-card-border-color,var(--divider-color, #e0e0e0));
border-width: var(--ha-card-border-width, 1px);
border-style: solid;
--ha-card-background: var(--ha-card-background, var(--card-background-color, white));
Test view:
- theme: Backend-selected
title: nine
path: nine
badges: []
cards:
- type: history-graph
entities:
- sun.sun
title: title.inline-card-red
card_mod:
class: inline-card-red
- type: vertical-stack
cards:
- type: entities
entities:
- entity: sun.sun
card_mod:
- type: entities
entities:
- entity: sun.sun
title: title
- type: entity
entity: sun.sun
card_mod:
- show_name: true
show_icon: true
show_state: true
type: glance
entities:
- entity: sun.sun
card_mod:
- type: entities
entities:
- entity: sun.sun
title: title
cards:
- type: entities
card_mod:
entities:
card_type: entities
entities:
- entity: sun.sun
title: title
card_type: entities
entities:
- entity: sun.sun
card_mod:
- type: entities
entities:
- entity: sun.sun
title: title
What we can see here:
The theme works fine for Entities.
For Glance, History-graph: since ā.card-headerā is in shadowRoot - I cannot define a āclassyā-style for the header. Have no idea how to select a shadowrooted ā.card-headerā for some special class.
Cannot check it, have no power sensors unfortunately, here is Middle Ages stillā¦
tom_l
December 12, 2022, 4:04am
4009
Yeah that is the issue Iām trying to fix.
Thanks for trying though.
I guess Iāll just add the style directly to the recalcitrant cards.
The whole problem with ā.card-headerā inside shadowRoot seems strange.
I wonder is there any chance of asking Devs to fix itā¦
tom_l
December 12, 2022, 4:18am
4011
Thereās always a chance. Even if it is a snowballās chance in hell.
This does not seem to access the shadow root. What am I doing wrong:
card_mod:
class: top-level-card
style: |
h1.card-header {
font-size: 30px;
font-weight: 800;
padding-top: 40px;
I tried with and without h1 in the path. No luck.
No need to use āh1ā.
To win shadowRoot you must think like a shadowRoot.
Check my theme again:
.card-header {
.card-header {
But check this also:
Can you guess how I did it? )))
Hint: managed to define classy shadowRoot style.
OK, here it is:
test_tom_i:
.card-header {
color: var(--my-classy-color) !important;
padding-top: var(--my-classy-padding-top) !important;
padding-bottom: var(--my-classy-padding-bottom) !important;
.card-header {
font-size: 30px;
font-weight: 800;
padding-top: 40px;
color: magenta;
--my-classy-color: magenta;
--my-classy-padding-top: 40px;
--my-classy-padding-bottom: 40px;
To specify a classy-shadowRoot-element style - use variables which are defined for the classy-parent.
