šŸ”¹ Card-mod - Add css styles to any lovelace card
if you need an identical mod over several pages, or includes, you can easily safe them in secrets.yaml, and import from there.
# Card mod stylings frequently used
wind_direction:
  style: |
    :host {
      --card-mod-icon:
        {% set dir = states(config.entity)|int(default=0) %}
        {% set icons = ['down','bottom-left','left','top-left','up','top-right',
                       'right','bottom-right'] %}
        {% set quadrant = (state/45)|round %}
        {% if quadrant < icons|count %} mdi:arrow-{{icons[quadrant]}}
        {% else %} mdi:arrow-down
        {% endif %};
wind_kracht:
  style: |
    :host {
        --paper-item-icon-color:
          {% set state = states(config.entity)|int(-5) %}
          {% set bft = ['lightblue','paleturquoise','aquamarine',
                       'greenyellow','lime','mediumspringgreen',
                       'yellowgreen','navy','gold','orange',
                       'tomato','orangered'] %}
          {{bft[state]}};
wind_snelheid:
  style: |
    :host {
            {% set state = (states(config.entity)|int(-5)) %}
            {% if state == 'unknown'%} gray
            {% elif state < 0.5 %} lightblue
            {% elif state < 1.5 %} paleturquoise
            {% elif state < 3.3 %} aquamarine
            {% elif state < 5.5 %} greenyellow
            {% elif state < 7.9 %} lime
            {% elif state < 10.7 %} mediumspringgreen
            {% elif state < 13.8 %} yellowgreen
            {% elif state < 17.1 %} navy
            {% elif state < 20.1 %} gold
            {% elif state < 24.4 %} orange
            {% elif state < 28.4 %} tomato
            {% elif state < 32.6 %} orangered
            {% else %} crimson
            {% endif %};
temp_color:
  style: |
    :host {
            {% elif state < -20 %} black
            {% elif state < -15 %} navy
            {% elif state < -10 %} darkblue
            {% elif state < -5 %} mediumblue
            {% elif state < 0 %} blue
            {% elif state < 5 %} dodgerblue
            {% elif state < 10 %} lightblue
            {% elif state < 15 %} turquoise
            {% elif state < 20 %} green
            {% elif state < 25 %} darkgreen
            {% elif state < 30 %} orange
            {% elif state < 35 %} crimson
            {% else %} firebrick
            {% endif %};
and the past in an actual card with:
entity: sensor.your_sensor_entity
card_mod !secret temp_color
Well, I’ve been working on this and have made progress but only by applying the card_mod code to each entitiy in the card.
When trying to use !include it fails. Looks like it could be a card-mod-row issue.
But then I got to thinking that there really should be a better way than having to include code from another file (secrets.yaml).
There’s got to be a way to define a dynamic style (i.e., card_mod) to apply to all entities in a card. Yes?
Don’t use !include but use !secret if you import from secrets.yaml
Or, use auto-entities and set it in options
      - type: custom:auto-entities
        card:
          type: entities
          card_mod: *mod
        filter:
          include:
            - entity_id: sensor.*_actueel
              options: {card_mod: !secret power_color}
Or, use fold-entity-row and set it in group_config options of the fold
type: custom:fold-entity-row
head:
  type: section
  label: Mobile app
group_config:
  secondary_info: last-changed
  card_mod: !secret not_home_picture
padding: 0
entities:
Options galore
Hello Community,
I try for one week now to style the custom sonos card with card-mod.
Styling ha-card for example changing background works fine, but changing the width, max-width and height of the container is pretty hard for me.
I tried the card-mod helper, but don’t know how to use it. I got the following string:
"body>home-assistant$home-assistant-main$ha-drawer>partial-panel-resolver>ha-panel-lovelace$hui-root$#view>hui-view>hui-sidebar-view$#main>hui-card-options>swipe-card$#swiper-wrapper-85c7cd6b306919d6>sonos-card.swiper-slide.swiper-slide-active$ha-card"
Below an Image of the Chrome inspector. Changing the ā€œ40remā€ to 100% will show the desired result. But i can’t get it to run in home assistant with card mod.
The following didn’t work:
card_mod:
  style: |
    ha-card  {
      max-width: 100%;
      width: 100%;
I hope anybody can help me and much thanks in advance.
Ugh – I’m feeling quite slow. Still doesn’t work.
Here’s the dashboard:
temp_color:
  style: |
    :host {
            {% endif %};
And here is secret.yaml
temp_color:
  style: |
    :host {
            {% endif %};
those are identical snippets…
see some explanation and more examples on my icon-color repo
Ok, I got it. The style-Element in the code was before the ha-card-Element. Adding !important behind the max-width parameter solved the problem.
How to set a height for ā€œhistory-graphā€
code
type: vertical-stack
cards:
  - type: history-graph
    entities:
      - entity: sensor.processor_use
    hours_to_show: 6
    entities:
    hours_to_show: 6
    card_mod:
      style:
        state-history-charts $:
          state-history-chart-line $:
            ha-chart-base $: |
              .chart-container {
                height: 100px !important;
    entities:
    hours_to_show: 6
    card_mod:
      style:
            ha-chart-base $: |
              .chart-container {
                height: 300px !important;
Tested in HA 2023.11.2, Chrome 119.0.6045.160 (Win10x64), FF 119 (Win10x64).
Does not work in iOS Companion App (iOS 15.x).
Pity, didn’t work for me (nothing changes) :sleepy: HA 2023.4.0, same Chrome version. Probably the issue could be further debugged?
Relative YAML snippet:
- type: vertical-stack
  cards:
      entities:
        - entity: sensor.current_uv_index
      hours_to_show: 48
      card_mod:
        style: |
              ha-chart-base $: |
                .chartContainer {
                  height: 10em !important;
    - type: markdown
      content: >-
        Maximum exposure time for skin.
Really?
And your card_mod version?
Then, ask yourself))
Hi, trying to learn how to work with code inspector to access and modify some objects with card_mod. Made some progress and learned some of the basics but I’m stuck with this one (trying to remove the 16px padding), could you assist so I can improve my skills:
using a screenshot as it should help pinpoint the issue:
I’ve tried a few things but not sure if I should go up the tree structure or stay below ā€œha-cardā€ as I have assumed.
Let me know what I’m doing wrong and/or my syntax issues
Thank you!
  card_mod:
    style:
        .card-content {
          padding: 0px !important;
  card_mod:
    style: |
      card-content {
ā€œcard-contentā€ is a CLASS.
And it is not in shadowRoot.
Try
  card_mod:
    style: |
      .card-content {
Damn. I was sure I tried this syntax…
It works.
At least I was not too far off :smile:
Thx for the prompt response
sorry about the wrong paste above.
I really can’t believe this is so difficult.
I have been trying so many different syntaxes, and copying exactly what is above and what is linked above.
Here is a brand new Entities card:
type: entity
entity: sensor.pirateweather_temperature
card_mod: !secret temp_color
Here is a secrets.yaml:
temp_color:
  style: |
    :host {
            {% endif %};
I am unable to save the card because of this:
Configuration errors detected:
unknown tag !<!secret> (3:29)
 1 | type: entity
 2 | entity: sensor.pirateweather_temperature
 3 | card_mod: !secret temp_color
I also tried putting a colon ( : ) after:
entity: sensor.pirateweather_temperature:
Still doesn’t work.
What am I doing wrong?
tbh, I dont know. are you using yaml mode?
because I dont get syntax error at all.
I can confirm this to happen in UI mode…
and adding a quote kills the mod. hmm not sure how t proceed here, apparently the UI editor cant handle the !
seems the only way would be a ā€˜hybrid’ approach, as I just learned that UI mode doesnt support !includes either.
wow, that would seriously kill my dashboard :wink:
it does however support yaml anchors
type: entities
entities:
  - <<: &entity
      entity: sensor.buienradar_temperature
  - <<: *entity
so, you can at least c&p those card_mod mods per view inside an anchor.
Hey!
I just experienced that some of my temperature sensors went down, without me knowing about it - since they got stuck at the last value read.
So, to fix this - i wan’t a ā€œpanelā€ where u can see when they last updated and the battery state. Said and done, as the picture shows.
But here’s the problem - since it’s easy to miss if it says ā€œ1 day agoā€ or ā€œ1 hour agoā€ i wan’t the secoundary text to be red if it’s been over 12h since last update.
I have tried multiple codes getting this to work, but i can’t seem to get it working.
The last code i have tried is this one;
type: entities
entities:
  - entity: sensor.badrum_temperature
    type: custom:multiple-entity-row
    show_state: false
    entities:
      - entity: sensor.tempgivare_hall_batteri
    style:
      '--secondary-text-color': >
        {% set last_updated = state_attr('sensor.badrum_temperature', 'last_updated') %}
        {% set time_difference = (now() - last_updated).total_seconds() / 60 %}
        {% if time_difference > 2 %}
          red
        {% else %}
          inherit
        {% endif %}
But it won’t work, i also tried just
   style:
      '--secondary-text-color': red
But it still won’t change the colour to red.
Thankful for all the help i can get!
sensors
Can someone get me started with how to target HA-textfield for CSS stuff?
Mini media player TTS died with latest HA update, because paper-input was deprecated, so the quick fix was to swap out paper-input for Ha-Textfield in the JS file
Works great, but now the text box looks ugly lol
Any help would be appreciate.
'ha-textfield
{ font: code stuff goes here
Am I close? lol
As it was already proposed to you in another topic:
1st post → link at the bottom → styles for m-e-r
This could BE helpful:
1st post → link at the bottom → styling input_text
Hi, guys!
Can someone help me to change the color of the drop-down arrow? I use custom:expander-card. But this card does not have an arrow color setting. Is it possible to change it using Дard-mod?
Днимок ŃŠŗŃ€Š°Š½Š° 2023-11-27 155850
I found a fill parameter that controls the color, but I couldn’t use it.
Code
type: custom:stack-in-card
card_mod:
  style: |
    ha-card {
      transition-property: none; !important;
      box-shadow: none;
      padding: 7px !important;
      background: rgba(var(--rgb-card-background-color), 0.5) !important;
cards:
  - type: custom:mod-card
    card:
      type: custom:mushroom-title-card
      title: Š–ŃƒŃ€Š½Š°Š»
      subtitle: null
      alignment: center
    card_mod:
      style:
          ha-card {
            margin: -30px 0px 0px 0px !important;
            padding: 0px 0px 0px 0px !important;
            top: 45px;
        mushroom-title-card$: |
          h1 {
            --primary-text-color: rgb(var(--rgb-grey));
            --title-font-size: 16px;
            top: 100px;
            left: 132px;
          h2 {
            --secondary-text-color: rgb(var(--rgb-grey));
            --subtitle-font-size: 14px;
            text-align: end;
          .header {
            --title-padding: 0px 0px 0px 0px;
            margin: 0px 0px -10px 0px !important;
  - type: custom:expander-card
    padding: 0px
    clear: true
    title: []
    child-padding: 0px
    button-background: transparent
    card_mod:
      style:
        ha-icon: |
          :host {
            fill: green !important;
    cards:
      - type: custom:stack-in-card
        card_mod: null
        style:
            ha-card {
              margin: 0px !important;
