šŸ”¹ Card-mod - Add css styles to any lovelace card
Hi everyone,
trying to use some of Ildar’s great glance code to modify my card but I cannot get it to work with my card.
type: custom:auto-entities
card:
  type: grid
  columns: 4
  square: false
  title: Xiaomi Battery
card_param: cards
sort:
  method: friendly_name
filter:
  template: |-
    {% set ns = namespace(list=[]) %}
        {% for item in states.sensor | selectattr('entity_id', 'search', 'xiaomi.*battery', ignorecase=True) %}
          {% set ns.list = ns.list + [ item ] %}
        {% endfor %}
      {% for item in ns.list -%}
          "type": "glance",
          "card_mod": [
            "style":
                  .card-header {
                    color: red  !important;
          "entities": [
            "entity": item.entity_id,
            "name": (area_name(item.entity_id).split()[0][:2] + (area_name(item.entity_id).split()[1][:2]) if area_name(item.entity_id).split()|length > 1 else area_name(item.entity_id)[:4]),
          "show_icon": false,
      {%- endfor %}
Would it need to go into the for loop?
How is that related to card-mod? )
I modified my post to show the card mode attempt, sorry for that.
I think it belongs in the for loop but I am not sure if the placement is wrong or syntax.
Cannot test it now, but this is obviously wrong.
ā€œcard_modā€ is not a list.
Also, you cannot use ā€œ|ā€ here.
This should be presented as json.
Go here: link - > a link about ā€œhow to quickly create templatesā€
I will search for more info in your link, thank you! Looks interesting once again :slight_smile:
EDIT:
Okay, found your info
                  'style': ':host { {%- if states(config.entity) == "unknown" -%}
                                    --paper-item-icon-color: brown;
                                    {%- elif states(config.entity) | float <= states("input_number.battery_level_critical") | float -%}
                                    --paper-item-icon-color: red;
                                    {%- elif states(config.entity) | float <= states("input_number.battery_level_warning") | float -%}
                                    --paper-item-icon-color: rgb(250,218,67);
                                    {%- else -%}
                                    --paper-item-icon-color: green;
                                    {%- endif %} }'
Will try to apply it
Wrong)
Try this:
"card_mod": {
  "style": "ha-card {color: red}"
Ah, that works.
But I was trying to do it for the title and I think that should be .card-header and there it was not working for me
"card_mod": {
  "style": ".card-header {color: red}"
1st create a working card-mod style w/o auto-entities.
Then make it json for auto-entites.
That I already tried:
type: glance
title: Colored title
card_mod:
  style:
      .card-header {
entities:
  - entity: sensor.xiaomi_dining_room_battery
Same as
card_mod:
  style:
    '$': 'card-header { color: red  !important; }'
and as experienced user you now create a json)
If the $ is important, then it should be
          "card_mod": {
            "style": {
              "$": "card-header { color: red !important; }"
which does nothing.
But ha-card worked without the $, yet card-header will not. So still stuck :frowning:
Also tried
          "card_mod": {
            "style": {
              "'$'": ".card-header { color: red !important; }"
just in case…
EDIT2:
Since I also wanted to add your line breaking, I tried a different property of the card but that also failed.
          "card_mod": {
            "style": {
              ".entities": {
                ".entity": ".name { text-overflow: unset !important; white-space: unset !important; }"
I think the json ison itself is formatted correctly. So I am assuming my mistake is elsewhere, more general :frowning:
Check this:
filter:
  template: |-
    {% for item in states.sun -%}
        "type": "glance",
        "title": "xxx",
        "card_mod": {
          "style": {
            "$": ".card-header { color: red  !important;}",
            ".": "ha-card {color: cyan}"
        "entities": [
          {"entity": item.entity_id}
        "show_icon": false,
    {%- endfor %}
Fascinating. I adopted one of your other glance examples (the multirow names) and took me 10 min to get it right.
Now I will try to figure out how to mod a grid card (well, auto-entites with template and grid). Just want to modifiy the grid card’s title :slight_smile:
card:
  type: grid
  columns: 4
card_param: cards
filter:
  template: |-
I have started down the rabbit hole, but before I get stuck:
is the card type custom:card-mod needed for grid cards or was that just an example of yours?
I thought that card-mod was kind of available without making it a card-mod card.
From one of your excellent example posts
type: custom:mod-card
card:
  type: grid
  title: some title
  cards:
EDIT:
Baby steps. Glance card is being modded but the title of the grid itself is not being changed yet.
But at least no error message.
Or does the type: custom:mod-card have to be directly above the grid card rather than turning it all into a card-mod?
card:
  card:
    type: grid
    columns: 4
    square: false
    card_mod:
      style:
        ':first-child $': |
          .card-header {
  card_param: cards
  filter:
    template: |-
...#and then the rest of the template I posted previously
Is there a way of removing the rectangles from the mushroom-person-card so I only get the circles?
This is what I have:
type: horizontal-stack
cards:
  - type: custom:stack-in-card
    cards:
      - type: custom:mushroom-person-card
        entity: person.ignacio_martinez
        icon_type: entity-picture
        primary_info: none
        secondary_info: none
        fill_container: true
        tap_action:
          action: navigate
          navigation_path: '#ignacio'
        hold_action:
          action: call-service
          service: script.unmute_ignacios_pixel_5
          data: {}
          target: {}
        card_mod:
          style:
            mushroom-shape-avatar$: |
              .picture {
                display: flex;
                border-radius: 50%;
                {% if states('switch.ignacio') == 'on' %}
                  animation: pinggreen 2s infinite;
                {% else %}
                  animation: pingred 2s infinite;
                {% endif %}
              @keyframes pinggreen {
                0% {box-shadow: 0 0 5px 3px rgba(var(--rgb-green), 0.9);}
                100% {box-shadow: 0 0 5px 5px transparent;}
              @keyframes pingred {
                0% {box-shadow: 0 0 5px 3px rgba(var(--rgb-red), 0.9);}
              .container {
                --icon-size: 80px !important;
              ha-card {
                background-color: transparent;
                box-shadow: none;
    cards:
        primary_info: none
        tap_action:
          action: navigate
        hold_action:
          data: {}
          target: {}
        card_mod:
          style:
              .picture {
                display: flex;
                border-radius: 50%;
                {% else %}
                {% endif %}
              .container {
              ha-card {
                box-shadow: none;
Thanks for the help!
I’ll like to chnage vertical slider style in more-info light dialog.
Can i do that with card-mod ?
Tried this, but not working:
hold_action:
	action: more-info
card_mod:
	style:
	   body>home-assistant$ha-more-info-dialog$ha-dialog>div>ha-more-info-info$div>div>more-info-content$more-info-light$div.controls>ha-state-control-light-brightness$ha-control-slider: |
                max-height: 200px; /*
Dont fully understand why you are using any stack-in-card in the first place. There is only 1 card in each stack-in-card.
But this should do it:
cards:
    primary_info: none
    tap_action:
      action: navigate
    hold_action:
      data: {}
      target: {}
    card_mod:
      style:
          .picture {
            display: flex;
            border-radius: 50%;
            {% else %}
            {% endif %}
          .container {
          ha-card {
            box-shadow: none;
            width: fit-content !important;
    primary_info: none
    tap_action:
      action: navigate
    hold_action:
      data: {}
      target: {}
    card_mod:
      style:
          .picture {
            display: flex;
            border-radius: 50%;
            {% else %}
            {% endif %}
          .container {
          ha-card {
            box-shadow: none;
Thanks! That was pure ignorance + copy and paste. I’m a slow learner :slight_smile:
One more @dimitri.landerloos . The background is transparent but I can see the border of the box as light gray. How do I make that transparent too?
          ha-card {
            box-shadow: none;
            border: none !important;
@dimitri.landerloos I’m trying to apply this logic to custom:popup-card but is not working.
title: Ignacio
type: custom:popup-card
style: |
  ha-card {
    box-shadow: none;
cards:
  - type: custom:bubble-card
    card_type: separator
    icon: mdi:map-marker-account
dismissable: true
What am I missing?
Still trying to make a card work and now need to change some elements.
So, I got .name working but nothing else :smile: .
So line wrappibg is working.
But how do I change .entites.no-header and .entities itself?
I tried
"card_mod": {
  "style": {
    ".entities": {
      "$": ".no-header { padding: 0px 0px 0px }",
      ".entity": {
        "$": ".name { text-overflow: unset !important; white-space: unset !important; margin-bottom: 0px; padding: 0px; display: flex }",
and also
"card_mod": {
  "style": {
    ".entities.no-header": {
      "$": "{padding-top: 0px}",
    ".entities": {
      "$": "{padding: 0px 0px 0px}",
      ".entity": {
Or could all this hierarchy be avoided by always doing
"card_mod": {
  "style": {
    ".": "entities {}",
    ".": "entities.no-header{}",
    ".": "entities.entity.name{}",
So basically just starting each div with ".": ?
