andypnz
(Andrew Palmer)
February 3, 2024, 8:49pm
5976
Trying to remove units label from entities⦠The right hand cell here I would like no āWā or āWhā⦠I have removed the icon (badge) and description (info), but could not find any documentation / examples as to how to remove the units, so tried a few random things with no error but no successā¦
type: horizontal-stack
cards:
- show_name: true
show_icon: true
type: button
tap_action:
action: none
entity: binary_sensor.phase_3_grid_1800
icon_height: 30px
hold_action:
action: none
- show_name: true
show_icon: true
type: button
tap_action:
action: none
entity: binary_sensor.phase_3_this_hour
icon_height: 30px
- show_name: true
show_icon: true
type: button
tap_action:
action: none
entity: binary_sensor.phase_3_next_hour
icon_height: 30px
- type: entities
entities:
- sensor.phase_3
- sensor.solcast_pv_forecast_forecast_this_hour
- sensor.solcast_pv_forecast_forecast_next_hour
show_header_toggle: false
state_color: false
card_mod:
style:
'#states div':
hui-sensor-entity-row $:
hui-generic-entity-row $: |
state-badge {
display: none;
.info {
margin-left:0 !important;
display: none;
.state {
justify-content: right;
label: none;
.state-label {
display: none;
Just use multiple-entity-row with āunit: falseā or template-entity-row.
andypnz
(Andrew Palmer)
February 4, 2024, 12:02am
5978
Thanks⦠I donāt suppose you could show me how to use - type: custom: multiple-entity-row in my YAML? I have been searching, but donāt really see where to add this and what else needs changingā¦
- type: entities
entities:
- type: custom:multiple-entity-row
entity: sensor.phase_3
unit: false
andypnz
(Andrew Palmer)
February 4, 2024, 1:14am
5980
That worked great thank you⦠but it made the icons (badges) visible⦠I had thought this may work, but it does notā¦
- type: entities
entities:
unit: false
style:
hui-generic-entity-row:
state-badge { display: none !important; }
Because you are taking a code which was made for card_X and then trying to apply to card_Y.
Actually, you are missing a syntax for card-mod 3.4.0.
andypnz
(Andrew Palmer)
February 4, 2024, 1:56am
5982
Thank you! Is there code for card_x to hide the icon / badge?
andypnz
(Andrew Palmer)
February 4, 2024, 2:53am
5983
Thank you for your help⦠and for anyone looking for similar, this removes the units, icon and info:
- type: entities
entities:
unit: false
card_mod:
style:
state-badge {
display: none;
.info {
display: none;
If you need to show only states w/o names & icons - use markdown.
Otherwise itās just a waste of resourcesā¦
kosmaluk
(Kosmaluk)
February 5, 2024, 7:32am
5985
Hi. I need help with the custom:logbook-card.
I have a card in which I use the state_map option to arrange icons based on the entity state and it works.
But I use this card for entities whose states are different, but the entity has a constant attribute.
I want to change the color of the icon in this tab when the attribute state changes.
Iāve been trying to do this for several days via card-mod, but it doesnāt work. I only managed to change the color using the state-badge value, but the color changes for all units.
How to set it so that the color of the icon changes depending on the attribute value.
Thanks for all your help
this is a code:
and this is ma trying works state-badge
card_mod:
style: |
h1 {
font-size: 18px;
color: #1E90FF;
.state {
font-weight: normal;
font-size: 14px;
color: orange;
.date {
color: #1E90FF !important;
font-size:12px !important;
font-style: italic !important;
.duration {
.card-content.card-content-scroll {
max-height: 455px;
state-badge {
color:
{% set apps_attribute = state_attr('sensor.redmi_12_asia_last_notification',
'package') %}
{% if apps_attribute == 'com.spotify.music' %} green
{% elif apps_attribute == 'com.whatsapp' %}#3ddc59
{% elif apps_attribute == 'com.facebook.orca' %}#c743d4
{% elif apps_attribute == 'com.facebook.katana' %}#207af2
{% elif apps_attribute == 'com.mi.globalbrowser' %}#3329f2
{% elif apps_attribute == 'com.google.android.dialer' %} teal
{% elif apps_attribute == 'com.android.deskclock' %} purple
{% elif apps_attribute == 'com.instagram.android' %}#fd0186
{% elif apps_attribute == 'com.google.android.youtube' %} red
{% elif apps_attribute == 'com.zhiliaoapp.musically' %} white
{% elif apps_attribute == 'com.google.android.apps.messaging' %} teal
{% elif apps_attribute == 'pl.pkobp.iko' %}#094689
{% else %}red {% endif %}
Please post your code by following #11 in this post. Folks aren't going to transpose the code from an image.
Before we beginā¦
This forum is not a helpdesk
The people here donāt work for Home Assistant, thatās an open source project. We are volunteering our free time to help others. Not all topics may get an answer, never mind one that helps you solve your problem.
[image]
This also isnāt a general home automation forum, this is a forum for Home Assistant and things related to it. Any question about Home Assistant, and about using things with Home Assistant, is welcome here. We canāt help you with eveā¦
this +1, pure core, and very elegant.
if must be button, use custom:button-card and state_display .
I want to change the background color of the tooltip with card-mod. Unfortunately I canāt figure out how to do thatā¦
Can anyone help me? And I would also like to know how I can find out for myself in the future.
This probably not the correct topic for you question because this one focuses on the standard lovelace cards. I did take a look at the JS and the card is using the paper-item-icon color for each entity.
I just did some simple tests and found some interesting about the how it logs the color state. Iāll dm you.
type: custom:logbook-card
entity: fan.bedroom_fan
custom_logs: true
max_items: 4
history: 1
card_mod:
style: |
ha-card {
{% if states('fan.bedroom_fan', 'off') %}
--paper-item-icon-color: yellow !important;
{% else %}
--paper-item-icon-color: red !important;
{% endif %}
digitl
February 6, 2024, 11:49am
5990
I have a card thatās doing everything I want it to do except change the colour of the text. Can anyone say where Iām going wrong and/or what is missing please?
type: custom:mushroom-chips-card
chips:
- type: template
content: '{{ states(''sensor.wiser_lts_temperature_dining_room'') }} °C Dining room'
icon: >-
{% if is_state('climate.wiser_dining_room', 'hvac_action') == 'heating' %}
mdi:fire {% else %} mdi:fire-off {% endif %}
icon_color: >-
red {% else %} green {% endif %}
card_mod:
style: |
ha-card {
color: red;
Migs
February 6, 2024, 1:49pm
5991
I would like to apply a zoom level to an entire layout. Iāve tried something like that:
- title: Home
type: custom:horizontal-layout
layout_type: custom:horizontal-layout
badges: []
cards: ...
card_mod:
style: |
ha-card {
zoom: 1.5
But it doesnāt workā¦
Iāve tried using custom:mod-card which only seems to work with standard layouts such as horizontal-stack, the zoom level is applied in this configuration (if I use custom:horizontal-layout the content of the layout is not displayed).
I donāt like this solution because:
the documentation says you shouldnāt use custom:mod-card if possible
the visual editor is not supported by custom:mod-card
I can only use standard layouts in combination with custom:mod-card (it seemsā¦)
Would you know of any way I could achieve this goal without using custom:mod-card while being able to use custom:horizontal-layout, custom:vertical-layout or custom:grid-layout AND apply the custom zoom level ?
Also if possible without having to create a custom theme (I want to keep it as simple as possible).
Thanks a lot,
lollo78
(Lollo78)
February 6, 2024, 8:13pm
5992
Hi guys, I need help about template syntax:
I applied this to customize my badges and seems tò works fine:
- badges:
- entity: sensor.broadlink_temperature
card_mod:
style: |
:host {
--label-badge-red: {% set t = states('sensor.broadlink_temperature') |int %} {% if t < 15 %} #44739e {% elif 15 <= t < 28 %} #43a047 {% elif t > 28 %} #db4437 {% else %} #6f6f6f {% endif %};
But in HA logs I see this error:
Logger: homeassistant.helpers.event
Source: helpers/template.py:569
First occurred: 21:03:14 (2 occurrences)
Last logged: 21:03:19
Error while processing template: Template<template=(:host { --label-badge-red: {% if is_state('sensor.presa_tv_soggiorno_energy_power',)|int != 0 %} #44739e {% else %} #db4437 {% endif %}; }) renders=2>
Error while processing template: Template<template=(:host { --label-badge-red: {% if is_state('sensor.presa_tv_stanzetta_energy_power',)|int != 0 %} #44739e {% else %} #db4437 {% endif %}; }) renders=2>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 567, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2305, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.11/site-packages/jinja2/environment.py", line 1301, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.11/site-packages/jinja2/environment.py", line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 2, in top-level template code
File "/usr/local/lib/python3.11/site-packages/jinja2/sandbox.py", line 393, in call
return __context.call(__obj, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2547, in wrapper
return func(hass, *args, **kwargs)
TypeError: is_state() missing 1 required positional argument: 'state'
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 693, in async_render_to_info
render_info._result = self.async_render(
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 569, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: TypeError: is_state() missing 1 required positional argument: 'state'
What Iām wrong?
Thanks a lot
arganto
February 6, 2024, 8:21pm
5993
lollo78:
What Iām wrong?
In comparing the wrong template with another template in the error log. Search for the right one and add in is_state the vale, you want to check against. But his is already in the error message as well.
kosmaluk
(Kosmaluk)
February 7, 2024, 7:23am
5994
Hello, thanks for your interest and help.
I tried your code and unfortunately it works the same as my discovery with state-badge. The color of all entities is the same based on the current state of the entity. Does not map historical colors according to a template.
Iām not fluent in card-mod and css code and I canāt find the place where this color is saved.
I will be grateful for your help.
This is ma triing code:
card_mod:
style: |
ha-card {
{% if states('sensor.ostatni_aktywny_czujnik_ruchu', 'biuro') %}
{% elif states('sensor.ostatni_aktywny_czujnik_ruchu', 'kuchnia') %}
--paper-item-icon-color: green !important;
{% elif states('sensor.ostatni_aktywny_czujnik_ruchu', 'toaleta') %}
--paper-item-icon-color: orange !important;
{% else %}
{% endif %}
and result
What is your main entity? It will map it if its a light.
It will map what ever HA records, but sensors are a not going to work.
This is one light and you can see the color changes were recorded, but by HA not the card.
