šŸ”¹ Card-mod - Add css styles to any lovelace card
No problem, happy to assist!
Hi there, i try to get a orange border around my conditional multiple-entity-row.
type: entities
entities:
  - entity: sensor.error_code
    card_mod:
      style: |
        ha-card.type-entities {
            border-color: orange;
        :host {
          --card-mod-icon-color: orange;
    type: custom:multiple-entity-row
    secondary_info: last-changed
    state_header: Code
    state_color: true
    entities:
      - entity: sensor.error_time
i got the orange icon working but not the borderā€¦ Any advivce how to find out the right selector for that?
What i got:
2024-03-18_17h36_31
what i want:
2024-03-18_17h39_18
Thanks for your help!
Another issue I canā€™t solve for - how do I increase the font size of mushroom-chips-card type:template
In the below code (which doesnā€™t work) I am trying to get the Rooms to show up a little bigger than it is by default.
type: custom:stack-in-card
mode: horizontal
cards:
  - type: custom:mushroom-chips-card
    chips:
      - type: template
        content: Rooms
        card_mod:
          style: |
            ha-card {
            --card-primary-font-size: 25px !important;
            background-color: transparent !important;
            box-shadow: none;
            border: none !important;
        alignment: start
I have also tried --card-secondary-font-size and no luck.
--chip-font-size: 20px; will adjust it.
mode: horizontal
cards:
    chips:
      - type: template
        content: Rooms
        card_mod:
          style: |
            ha-card {
            box-shadow: none;
        alignment: start
Try changing the last line in your code - expanding your card total height.
card_mod:
  style: |
    ha-card {
      height: 120px;
Just a heads up, he was looking to reduce the overall height of the card. This was cross posted on another thread and a top: -15px solved his issue.
Thanks for making this tool. Can anyone see what I am doing wrong? I am trying to basically just hide the header (and background to make it look like a long chip.
type: custom:hourly-weather
entity: weather.pirateweather
icons: true
show_precipitation_amounts: false
show_precipitation_probability: false
card_mod:
  style:
      ha-card {
        background: none;
        border: 0px;
      .card-header{
        display: none;
card_mod:
  style:
      ha-card {
        background: none;
        border: 0px;
      .card-header{
        display: none;
card_mod:
  style:
      ha-card {
        background: none;
        border: 0px;
    "ha-card $": |
      .card-header{
        display: none;
I have already suggested you a proper syntax for a header in your github issue.
Also, since you can use Code Inspector - check if your attributes are applied.
Wrong value, try ā€œborder: noneā€.
Youā€™ll see the second version I gave included
      .card-header{
        display: none;
which is what you suggested on the github issue. It didnā€™t work. Although, moved the conversation here as it wasnā€™t a ā€œbugā€, rather a support request.
Thanks for the border point, 0px worked, but Iā€™ve switched it to none.
Edit: The attributes are not applied / not a css specificity issue.
Because you have not checked if your style was applied or DECLINED.
Find your declined line in Code Inspector (and google about ā€œimportantā€).
Besides, why donā€™t you try ā€œNOT SHOWING a headerā€ instead of hiding it?
Any idea how i can change the border color of my multiple-entity-row card?
i already searched the community but didnā€™t find a solution for this :frowning:
its a ha-card of class type-entities. When i change the color in the browser directly it works, but i dont get it working in HASS using card-mod
I mentioned that it wasnā€™t a css specificity issue. !important isnā€™t going to do anything. Itā€™s not that the style is being overwritten by a more-specific style, it is that it is not being applied in the first place.
I am assuming that by declined you are referring to the promise?
If so, it is being rejected, although Iā€™m not clear why or how to debug that further:
>> $0.card_mod_children
Object { "$": Promise { "rejected" } }
ā€‹
"$": Promise { <state>: "rejected", <reason>: DOMException }
ā€‹
<prototype>: Object { ā€¦ }
I am not getting, sorry.
Just try ā€œdisplay: none !importantā€.
And think again about my advice for ā€œnot showingā€ in the prev post.
How do you suggest I do that?
I have just tried that, although it did not work. The style isnā€™t being applied. Itā€™s not that itā€™s being overwritten.
Thanks for your help on this by the way. :slight_smile:
Set null for a title or how it is called.
it IS applied (just not like as expected).
icons: true
show_precipitation_amounts: true
show_precipitation_probability: true
That does work. Thank you. I didnā€™t realise I could do that. Although I am still curious as to why the browser-mod method didnā€™t work
what method again?
Typo, I meant card-mod
hey good news - i got it on my own :slight_smile: The card-mod style needs to be outside the entity, on the same level as ā€œtype: entitiesā€ then it does the trick!
type: conditional
conditions:
    state_not: no request
card:
  type: entities
  card_mod:
    style: |
      ha-card {
        --ha-card-border-color: orange;
  entities:
      card_mod:
        style: |
          :host {
      state_header: Code
      state_color: true
      entities:
