@image969 Assuming youāre talking about displaying a card via browser_mod.popup⦠thereās no special card-mod configuration. The easiest way Iāve found is to create the card you want to āpop upā in a test dashboard via normal means. Get your card-mod setup and whatever else exactly how you want it, and then copy the yaml into your browser_mod.popup service call under your firedom event. If you copy/paste correctly, the popup will look exactly like the card in your test dashboard.
Hi, thanks for the reply. I have the card working fine in the pop-up. Itās just a drop-down menu when you click on it. The pop-up dimensions arenāt big enough so it crops it. I want to know if the overflow in card mod can be used so it extends past the pop-up.
Canāt help much if you donāt post your current code, but you can definitely increase the height of the popup card which could solve your issue.
Hereās a screenshot of the code I was referring to. I would rather not change the height of the pop-up card, because then there would be a ton of blank space showing when Iām not using the drop-down menu. I have no problem with this overflow line anywhere else it just doesnāt seem to work Inside the pop-up card
I donāt think you can do that. The popup card has a defined size. You can change the size via card-mod etc, but itās a defined size nonetheless. You canāt declare anything outside the size of the popup card as there just isnāt any space there. Itās possible to add scrollbars, but thatās going to let you scroll the whole card. I suppose itās possible to add scrollbars to only the dropdown, but you would have to experiment with card-mod and it will depend on the specific card your trying to use and how itās constructed. I could very easily be wrong, but Iād be surprised if you can accomplish this with card-mod alone, at least as long as youāre talking about it being a popup card. In any case, if you donāt post your code properly formatted, then no one can help, as no one can copy and paste your code from a screenshot to try things and give you direction.
I was kind of thinking the same about not being able to escape outside of the pop up size. Here the code, if anyone is feeling bored lol
Please note, not everything will work correct, as this is one of 6 cards inside of a conditional setup⦠My only concern is when you click on the card, and see the pop up and drop down for the Pandora section
type: custom:mini-media-player
entity: media_player.living_room_2
background: /local/echo2.jpg
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
content:
type: custom:stack-in-card
cards:
- type: entities
entities:
- entity: input_select.content
card_mod:
style:
hui-generic-entity-row $: |
state-badge {
display: none;
- type: conditional
conditions:
- condition: state
state: Pandora
card:
type: entities
entities:
- entity: input_select.pandora_stations
card_mod:
style:
state-badge {
display: none;
- type: call-service
name: 'Pandora Radio '
icon: mdi:pandora
action_name: Play Music...
service: script.alexa_pandora_living
- Pandora
state_color: false
show_header_toggle: true
- type: conditional
conditions:
- condition: state
state: Amazon
card:
type: entities
entities:
- entity: input_text.text
type: custom:text-input-row
name: 'Amazon Music '
icon: mdi:music
service: script.alexa_amazon_living
- AMAZON_MUSIC
state_color: false
- type: conditional
conditions:
- condition: state
state: Apple
card:
type: entities
entities:
icon: mdi:apple
service: script.alexa_apple_living
- Apple
state_color: false
- type: custom:mini-media-player
group: false
source: true
info: true
hide:
icon: true
volume: false
power: true
play: true
source: true
progress: true
stop: true
volume_stateless: false
toggle_power: true
replace_mute: stop
card_mod:
style: |
:host {
--mini-media-player-accent-color: #bfb6bd;
ha-card {
overflow
card_mod:
style: |
ha-card {
overflow: visible !important;
ha-card > div {
overflow-x: clip;
group: true
source: null
info: null
hide:
icon: true
volume: true
power: true
controls: true
source: true
progress: true
shortcuts:
columns: 6
buttons:
- icon: mdi:sofa
type: script
- icon: mdi:pot-steam
type: script
- icon: mdi:toilet
type: script
- icon: mdi:movie-check
type: script
- icon: mdi:desk
type: script
- icon: mdi:bed-king
type: script
card_mod:
style:
mmp-shortcuts $: |
mmp-button:nth-of-type(0) ha-icon {
color: cyan;
mmp-button:nth-of-type(1) {
background-color: rgb(50,50,50,.6);
style: |
ha-card {
height: 250px;
tts:
platform: alexa
(for ppl finding replied post via search, like I did):
For limiting āhistory-graphā height, at least in HA 2024-3 the card supports variable āchart-max-heightā, it can be set on the root ha-card
ha-card {
--chart-max-height: 80px !important;
Hi, you have helped me with code more than anyone on a year ago in the mushroom forum so I hope you can help me again, cause Iāve been struggling for a week lol
For a browser-mod pop-up card. I have a drop down menu inside. When I click on the drop down it gets cropped due to the height of the card. I have to scroll the entire card down. Is it possible using card_mod to do the overflow: visible to have the drop down extend past the pop-up? i cannot for the life of me get this to work
As a worse case scenerio, is it possible to have the height of the card adjust dynamically. Kind of like a todo list when you add to the list, the card will in create in height
Does anyone know how to hide the āAttributesā from the more-info-card? Iāve tried lots of things but canāt figure it out unfortunately!
keep:
outer_padding: true
border-radius: true
box_shadow: false
background: false
margin: false
cards:
- type: custom:more-info-card
entity: light.living_room
title: ' '
card_mod:
style: |
state-card-content { display: none }
more-info-light:
ha-attributes {
display: { display: none }
ha-select { display: none }
hr { display: none }
- type: custom:rgb-light-card
justify: around
label_size: 12
colors:
service: scene.turn_on
service_data:
entity_id: scene.living_room_1_white
icon_color: '#ffffff'
label: White
service_data:
entity_id: scene.living_room_2_white_dimmed
icon_color: '#f1ebdf'
label: Dimmed
service_data:
entity_id: scene.living_room_3_pink
icon_color: '#f290f4'
label: Pink
service_data:
entity_id: scene.living_room_4_orange
icon_color: '#fcb92e'
label: Orange
justify: around
label_size: 12
colors:
service_data:
entity_id: scene.living_room_5_ireland
icon_color: '#20f32f'
label: Ireland
service: script.living_room_dynamic_pinkky
data: null
icon_color: '#FFB6C1'
label: Dyn-Pink
service: script.living_room_dynamic_retro_80s
data: null
icon_color: '#FAA0A0'
label: Dyn-Retro
service: script.living_room_dynamic_xbox
data: null
icon_color: '#107C10'
label: Dyn-Xbox
use the custom-more-info card ![]()
Fantastic, thank you!
Is there any way to hide the āEffectā button also?
donāt think we added that yet, but open a FR and we can have a look ![]()
I have a problem with my current setup. Sometimes the colour is shown and sometimes not. Itās very sporadic and can be fixed by reloading the page in the browser. But on the Android app itās not that easy to reload the pageā¦
Perhaps itās related to my code and something is wrong with it.
type: entities
title: Temperatur
entities:
- entity: sensor.temperatur_aussen_2
type: custom:multiple-entity-row
icon: mdi:temperature-celsius
format: precision1
state_header: Aktuell
styles:
font-weight: bold
entities:
- entity: sensor.temperatur_tagesminimum
format: precision1
- entity: sensor.temperatur_tagesmaximum
format: precision1
- entity: sensor.temperatur_eg_wohnen_taster
format: precision1
state_header: Temperatur
entities:
- entity: sensor.voc_eg_wohnen
format: precision0
- entity: sensor.co2_eg_wohnen
format: precision0
- entity: sensor.luftfeuchtigkeit_eg_wohnen
format: precision1
card_mod:
style: |
.entities-row div.entity:nth-child(1) {
{% set state = states('sensor.voc_eg_wohnen') %}
{% if state | int < 400 %}
color: green;
{% elif (state | int >= 400) and (state | int < 1300) %}
color: orange ;
{% elif state | int >= 1300 %}
color: red ;
{% endif %}
.entities-row div.entity:nth-child(2) {
{% set state = states('sensor.co2_eg_wohnen') %}
{% if state | int < 1000 %}
color: green;
{% elif (state | int >= 1000) and (state | int < 1400) %}
color: orange;
{% elif state | int >= 1400 %}
color: red;
{% endif %}
.entities-row div.entity:nth-child(3) {
{% set state = states('sensor.luftfeuchtigkeit_eg_wohnen') %}
{% if state | int < 40 %}
color: orange;
{% elif (state | int >= 40) and (state | int <= 60) %}
color: green;
{% elif state | int > 60 %}
color: orange;
{% endif %}
.entities-row div.entity:nth-child(4) {
font-weight: bold;
- entity: sensor.stromzaehler_aktuellerverbrauch_volkszaehler
Iām trying to customize the clock-weather card, but how do I target the clock-weather-card-toray-right-wrap-top field?
I tried doing it this way, but that doesnāt work:
card_mod:
style:
clock-weather-card $ ha-card $ div:
clock-weather-card-today-right-wrap-top {
display: none;
View of the DOM:
Iām trying to add simple drop-shadow effect globally to all my Home Assistant cards via my custom theme file. For some reason, when I append ha-card { box-shadow: 0px 5px 15px rgba(255,255,255,0.3) !important; } to my card-mode code below, it has no visible effect. However, the other card-mod modifications work just fine.
card-mod-root: |
.edit-mode, app-header, app-toolbar {
background: var(--app-header-background-color) !important;
color: var(--primary-text-color) !important;
ha-tabs {
--paper-tabs-selection-bar-color: var(--primary-color) !important;
paper-tab[aria-selected=true] {
ha-card {
Without testing: This element is not in a shadow root inside ha-card of your card. So you should directly use:
card_mod:
style: |
display: none !important;
You should address it in the theme-thread.
Youāre right, your example worked. But how is it that you can ignore the shadow root thatās under the clock-weather-card element? Iām new to using the card mod and this part is rather confusing.
He answered that questionā¦
Is the below link the theme-thread you suggested? Iām not sure. If not, could you please point me to the right thread? Thanks.
