does this work for you?
card_mod:
style: |
.icon-name {
color: grey;
.title-controls .media-info {
color: grey;
.more-info {
color: grey;
.title-controls .controls {
color: grey;
.background.no-image > * {
background-color: rgba(0, 0, 0, 1);
ha-card {
--ha-card-background: #;
border-radius: 15px;
box-shadow: rgba(140, 20, 252,1) 0px 1px 50px;
ha-card {
--card-mod-icon: phu:sky-alt;
ha-state-icon {
color: red;
--mdc-icon-size: 100px;
Indeed that did the job.
Thank you very much, will note ha-state-icon for future references.
its not always going to be ha-state-icon
btw, you have to ensure you check the DOM.
try the first element you can find under ha-card that relates to an icon, and then try on that
if that doesnt work only then try and drill deeper.
you can set a color on the
element
card_mod:
style:
ha-markdown:
ha-markdown-element: |
hr {
color: red;
or, use the compound method to set a border, like
card_mod:
style:
ha-markdown:
hr {
border: 1px dashed red;
and even use the theme colors in that:
card_mod:
style:
ha-markdown:
hr {
border: 1px groove var(--divider-color);
note this is applied to all
elements in the markdown card. If you want to target a single
you need to invent other tricks
haha, the tag is interpreted in this post too… should have used <hr>
, sorry
TheStigh
(TheStigh)
August 15, 2024, 2:55pm
6933
Hi guys, have some issues after the update from 2024.8.0 to 2024.8.1 and the thermostat card.
Earlier I controlled the height of buttons and icons like this:
card_mod:
style:
hui-card-features $ hui-climate-hvac-modes-card-feature $ ha-control-select $: |
:host {
--control-select-thickness: 100px !important;
--mdc-icon-size: 30px !important;
…but after the update, this didn’t work anymore. I figured out the button height, now like this:
card_mod:
style:
hui-card-features$: |
:host {
--feature-height: 100px !important;
:host {
So far, so good.
Now the icons… I still see them as far as I remember at the same location when using inspect, but my style doesn’t apply anymore.
Also, I would like to change the background of the non-active buttons to transparent (opacity: 0) and see the --control-select-background-opacity
also under :host
and when changing both --control-select-background-opacity
and --mdc-icon-size
from the console, it works. But from my code it doesn’t change.
:host {
--control-select-background-opacity: 0 !important;
Anybody with some good tip what I’m missing ??
prudy
(Prudy)
August 15, 2024, 5:43pm
6934
Any way to embed an inline svg code? For example, using default picture card:
type: picture-elements
elements:
- type: icon
icon: >-
url('data:image/svg+xml;charset=UTF-8,<svg
xmlns="http://www.w3.org/2000/svg" viewBox="-5 -5 10 10"><circle r="4"
fill="rgb(128,0,255)"/></svg>');
style:
left: 40%
top: 30%
width: 20%
height: 20%
background: blue
image: https://demo.home-assistant.io/stub_config/floorplan.png
In any valid form, utf, bas64, etc., as some suggested in inline-svg-in-css .
Hey Guys, is it possible to make the right side like the left side with 3 lines?
type: custom:stack-in-card
title: ''
mode: vertical
cards:
- type: custom:simple-weather-card
entity: sensor.weather_penthouse_tag_0
primary_info:
- extrema
secondary_info:
- precipitation
- wind_speed
card_mod:
style: |
ha-card {
padding-left: 8px !important;
padding-right: 8px !important;
padding-top: 0px !important;
padding-bottom: 0px !important;
height: 70px;
.weather__info__state {
max-width: 90px;
white-space: normal !important;
iorifly
(Renato Barbosa)
August 16, 2024, 2:33pm
6936
Hello, does anyone know how to change the color of this card? When I turn it on in the cold, the bar is turning red. I would like to make it blue.
type: custom:better-thermostat-ui-card
Ricks88
August 16, 2024, 4:43pm
6937
Thanks a lot!!
I will experiment with this to learn and understand better
louski
August 16, 2024, 5:21pm
6938
Hello dear community,
can someone help me to add a margin to a virtual stack? I can’t seem to get it right with card_mod. See picture
Thank you very much
Ricks88
August 16, 2024, 9:02pm
6939
I made the design how I liked it
But the code is chaos
Did I do it the right way or did I got lucky haha
It is not very future proof I think:
cards:
- type: horizontal-stack
cards:
- type: vertical-stack
cards:
- type: entities
entities:
- type: divider
- entity: sensor.panasonic_vloermodel_bijkamer_inside_temperature
name: Kamer temperatuur
icon: mdi:thermometer
- entity: climate.panasonic_vloermodel_bijkamer
name: Panasonic Airco/Heater
icon: mdi:air-conditioner
- type: divider
title: Bijkamer
icon: hue:room-office
state_color: true
card_mod:
class: content-entities
style: |
ha-icon {
--mdc-icon-size: 29px;
- type: thermostat
name: Panasonic Airco/Heater (Vloermodel)
features:
- type: climate-hvac-modes
hvac_modes:
- heat_cool
- heat
- cool
- dry
- fan_only
- 'off'
- type: climate-fan-modes
style: dropdown
- type: climate-swing-modes
style: dropdown
card_mod:
class: content
style:
hui-card-feature:nth-child(1) {
width: 600px !important;
margin: 0px auto 0px auto;
hui-card-feature:nth-child(2) {
width: 225px !important;
position: relative;
margin: 25px auto 0px 90px;
hui-card-feature:nth-child(3) {
position: relative;
margin: -54px 90px 0px auto;
ha-card {
cards:
- type: tile
entity: switch.panasonic_vloermodel_bijkamer_eco
color: light-green
tap_action:
action: toggle
hold_action:
action: toggle
icon_tap_action:
action: toggle
vertical: true
hide_state: true
show_entity_picture: false
card_mod:
class: content-tile
style: |
ha-card {
width: 100px;
float: left;
margin: -240px 0px 0px 80px;
ha-tile-info {
margin: -15px 0px 0px 0px;
font-size: 16px;
- type: tile
entity: switch.panasonic_vloermodel_bijkamer_nanoe
color: orange
tap_action:
action: toggle
hold_action:
action: toggle
icon_tap_action:
action: toggle
vertical: true
hide_state: true
card_mod:
class: content-tile
style: |
ha-card {
width: 100px;
float: right;
margin: -240px 80px 0px 0px;
ha-tile-info {
font-size: 16px;
cards:
- type: tile
entity: input_select.climate_panasonic_wandmodel_woonkamer_select_fanmode
color: blue-grey
vertical: false
hide_state: true
tap_action:
action: none
hold_action:
action: none
icon_tap_action:
action: none
card_mod:
class: content-tile
style: |
ha-card {
width: 50px;
float: left;
margin: -55px 0px 0px 40px;
ha-tile-info {
display: none !important;
.icon-container {
position: absolute !important;
margin: -8px 0px 0px -5px !important;
- type: tile
entity: input_select.climate_panasonic_wandmodel_woonkamer_select_swingmode
color: blue-grey
vertical: false
hide_state: true
tap_action:
action: none
hold_action:
action: none
icon_tap_action:
action: none
card_mod:
class: content-tile
style: |
ha-card {
width: 50px;
float: right;
margin: -55px 40px 0px 0px;
ha-tile-info {
.icon-container {
margin: -8px 0px 0px -1px !important;
cards:
- type: custom:bar-card
entities:
- entity: sensor.panasonic_vloermodel_bijkamer_current_power
icon: mdi:flash
columns: '1'
direction: right
height: 40px
decimal: '0'
min: '0'
max: '3000'
unit_of_measurement: W
positions:
icon: outside
value: inside
indicator: outside
minmax: 'off'
severity:
to: '100'
color: green
to: '750'
color: yellow
to: '1500'
color: orange
to: '3500'
color: red
to: '15000'
color: '#820914'
entity_row: true
card_mod:
style: |
ha-card {
margin: 30px 55px 0px 5px;
box-shadow: none;
border: 0px;
--ha-card-border-width: 0px;
.card-content {
padding: 10px 13px 5px 10px !important;
box-shadow: none;
entities:
- entity: sensor.panasonic_vloermodel_bijkamer_daily_energy_w
icon: mdi:meter-electric
columns: '1'
direction: right
height: 40px
decimal: '0'
min: '0'
max: '15000'
positions:
icon: outside
value: inside
indicator: outside
minmax: 'off'
severity:
to: '2000'
color: green
to: '4000'
color: yellow
to: '7000'
color: orange
to: '12000'
color: red
to: '25000'
color: '#820914'
entity_row: true
card_mod:
style: |
ha-card {
margin: 0px 55px 0px 5px;
box-shadow: none;
border: 0px;
.card-content {
box-shadow: none;
- type: custom:gap-card
height: 15
card_mod:
style: |
ha-card {
width: 100% !important;
margin: 0px 0px 0px 0px
what cards do you have there, with the temp/humid/battery?
those are actually very nice
The card mod code is all fine (i dont like the word correct, because as long as it works and doesnt seem to slow down your phone/pc, then its “correct”)
Except this bit which i suspect that you know is superfluous:
Ricks88:
ha-card {
With how many different stacks you have i would probably look into the layout card (from HACS) instead so you dont have to have so many different ones going on.
….and “#” should not be used inside card-mod code
Ricks88
August 17, 2024, 12:30pm
6944
Edit
It could be done with just 1 stack card
mode: vertical
cards:
- type: entities
entities:
- type: divider
- type: divider
title: Bijkamer
state_color: true
card_mod:
style: |
ha-icon {
- type: thermostat
features:
hvac_modes:
- heat_cool
- heat
- cool
- dry
- fan_only
- 'off'
style: dropdown
style: dropdown
card_mod:
class: content
style:
position: relative;
position: relative;
ha-card {
- type: tile
color: light-green
tap_action:
action: toggle
hold_action:
action: toggle
icon_tap_action:
action: toggle
vertical: true
hide_state: true
card_mod:
class: content-tile
style: |
ha-card {
width: 100px;
float: left;
ha-tile-info {
font-size: 16px;
- type: tile
color: orange
tap_action:
action: toggle
hold_action:
action: toggle
icon_tap_action:
action: toggle
vertical: true
hide_state: true
card_mod:
class: content-tile
style: |
ha-card {
width: 100px;
float: right;
ha-tile-info {
font-size: 16px;
- type: tile
color: blue-grey
vertical: false
hide_state: true
tap_action:
action: none
hold_action:
action: none
icon_tap_action:
action: none
card_mod:
class: content-tile
style: |
ha-card {
width: 50px;
float: left;
margin: -65px 0px 0px 40px;
ha-tile-info {
.icon-container {
margin: -4px 0px 0px -5px !important;
- type: tile
color: blue-grey
vertical: false
hide_state: true
tap_action:
action: none
hold_action:
action: none
icon_tap_action:
action: none
card_mod:
class: content-tile
style: |
ha-card {
width: 50px;
float: right;
margin: -65px 40px 0px 0px;
ha-tile-info {
.icon-container {
margin: -20px 0px 0px -1px !important;
entities:
icon: mdi:flash
columns: '1'
direction: right
height: 40px
decimal: '0'
min: '0'
max: '3000'
positions:
icon: outside
value: inside
indicator: outside
minmax: 'off'
severity:
to: '100'
color: green
to: '750'
color: yellow
to: '1500'
color: orange
to: '3500'
color: red
to: '15000'
color: '#820914'
entity_row: true
card_mod:
style: |
ha-card {
margin: 10px 55px 0px 5px;
box-shadow: none;
border: 0px;
.card-content {
box-shadow: none;
entities:
columns: '1'
direction: right
height: 40px
decimal: '0'
min: '0'
max: '15000'
positions:
icon: outside
value: inside
indicator: outside
minmax: 'off'
severity:
to: '2000'
color: green
to: '4000'
color: yellow
to: '7000'
color: orange
to: '12000'
color: red
to: '25000'
color: '#820914'
entity_row: true
card_mod:
style: |
ha-card {
box-shadow: none;
border: 0px;
.card-content {
box-shadow: none;
height: 15
card_mod:
style: |
ha-card {
margin: 0px 0px 0px 5px
It’s still from the beginning that i used to think like tables “start with a vertical stack and put horizontal rows in it” haha.
Emiel86
(Emiel)
August 18, 2024, 3:20pm
6945
I really hope that they will add the “ha-card” css style element to the new badges, so that we can change how the badges look.
Well you can just change the color like this:
card_mod:
style: |
bt-ha-control-circular-slider {
--control-circular-slider-color: var(--label-badge-blue) !important;
but it seems more like a bug with the card. the reason i say this is because the bar is colored based on a variable called --mode-color
and mode color is being set to --label-badge-red
when the cool symbol is selected? it should probably be set to --label-badge-blue
. i would raise an issue on the github of better thermostat if i were you.
so you can fix it for real like this, and thats probably how it should be set from the card creator anyway:
card_mod:
style: |
.cool {
--mode-color: var(--state-climate-cool-color) !important;
iorifly
(Renato Barbosa)
August 18, 2024, 4:21pm
6948
You were perfect!! Thank you so much!!
loocd
August 19, 2024, 2:57pm
6949
Hi all,
I’m working on a card using auto-entities templating.
Simplifying it a bit, my card looks like this:
type: custom:auto-entities
card:
type: custom:layout-card
filter:
template: |
{% set groups = defining the variable)
{% set members = groups | expand
| some more processing
{% for group in groups %}
"type": "custom:stack-in-card",
"cards":
"type": "custom:mushroom-light-card",
"entity": "{{ group }}",
"use_light_color": "true",
"show_brightness_control": "true",
"show_color_temp_control": "true",
"show_color_control": "true",
"collapsible_controls": "true",
"fill_container": "false",
"type": "custom:collapsable-cards",
"title": "Einzelne Lampen",
"card_mod":
"cards": [ my cards ]
}{% if not loop.last %},{% endif %}
{% endfor %}
include: []
exclude: []
with all the brackets and quotes I’m honestly a bit confused how to add my card_mod styles. In my initial, non-automatic card it looked like this:
style: |
ha-card button {
font-family: "Kollektif", sans-serif !important;
ha-card button:focus {
background: none !important;
Could you tell me how to format the card_mod styling in this application?
or would it be better to take card_mod out of the template, put it at the very beginning under type: custom:auto-entities
and navigate the DOM from there?
If so, would also be open for pointers
