svkoch
September 4, 2024, 12:19am
7031
I have a similar problem to:
I have type: entities
, type: conditional
, type: 'custom:template-entity-row'
I want to recolor the State (âOpenâ) to purple.
type: entities
entities:
- type: conditional
conditions:
- entity: input_boolean.confirm_door_open
state: 'off'
row:
entity: lock.wohnungstur
icon: mdi:door-closed-lock
state: 'Open'
tap_action:
action: call-service
service: script.temporarily_confirm_door_opening_request
<ha-card class="type-entities">
<div id="states" class="card-content">
<div>
<hui-conditional-row class="type-conditional">
<template-entity-row>
<!--#shadow-root (Open)-->
<div id="wrapper" class="">
<state-badge class=" pointer " statecolor="" icon=""></state-badge>
<div class=" info pointer ">
WohnungstĂŒr
<div class="secondary">
</div>
</div>
<div class="state">
Open
</div>
</div>
<div id="staging">
<hui-generic-entity-row no-secondary="">
</hui-generic-entity-row>
</div>
</template-entity-row>
</hui-conditional-row>
</div>
</div>
</ha-card>
(hope I copied it correctly with the shadow root)
For the life of me I canât figure out the corect combination between the css levels, shadow roots etc.
This is one of the endless combinations I tried:
card_mod:
style:
hui-conditional-row:
template-entity-row$: |
.state {
color: purple;
font-weight: bold;
Iâd appreciate some help.
as a starting point:
type: entities
entities:
- input_boolean.test_boolean
- type: conditional
conditions:
- entity: input_boolean.test_boolean
state: 'off'
row:
type: custom:template-entity-row
entity: sun.sun
card_mod:
style:
template-entity-row $: |
div#wrapper {color: red}
Hello everybody,
Iâm not sure, if the following is an issue with card-mod or with bubble-card .
Generally bubble-card works as described, just one thing âŠ
Iâd like to replace the lower section part (Klima and the 2 following card) with a popup-card.
I added my standard style settings to the card
The card with the rounded border is the popup-button-card, with the following code:
type: custom:bubble-card
card_type: button
button_type: name
icon: mdi:temperature-celsius
button_action:
tap_action:
action: navigate
navigation_path: '#showtime'
card_layout: large
card_mod:
style: |
ha-tile-icon {
--mdc-icon-size: 30px;
ha-icon-button {
width: 90px !important;
height: 90px !important;
ha-card {
--ha-card-background: #;
font-size: 40px;
border-radius: 15px;
box-shadow: rgba(195, 255, 104, 1) 0px 1px 50px;
ha-card {
--primary-text-color: grey;
--text-align: center !important;
As you can see it accepts some card-mod styles (border-radius & primary-text-color), and ignores others (box-shadow, text-align and font-size)
I moved the card to the end, to show the box-shadow in the 1st picture is actually those of the adjactend cards.
For the sake of completeness, the actual popup with the working styles
I traced the element with inspector, but couldnt make it work with:
.bubble-name {âŠ
Thanks a lot for the detailed explanation, appreciate it!
Anyone got a clue about this?
loocd
September 6, 2024, 12:15pm
7036
Iâm not working with section, but I wouldnât know how youâd target this, as usually you go after the ha-card element.
If I wanted to achieve this Iâd look into the card_mod themes, which probably allow you to do this if you find the right dom navigation + selectors.
someone knows why this code does not set my background?
card_mod:
style: |
ha-card {
background: url('{{ state_attr("media_player.firetv_stick_4k_max", "entity_picture") }}') no-repeat center;
background-size: cover;
Works fine:
Check what is a value of that attribute.
And check with this simplest just in case:
card_mod:
style: |
ha-card {
background: red no-repeat center;
thanks for reply, this is the value
entity_picture: >-
/api/media_player_proxy/media_player.firetv_stick_4k_max?token=6b6af85b5118fb9a51fcdf870101fbe7b34f7172045da9cc16ecddce0e54be35&cache=8673bbbc1758d827
this works for example, in the browser but not via card_mod
https://homeassistant.local:8123/api/media_player_proxy/media_player.firetv_stick_4k_max?token=6b6af85b5118fb9a51fcdf870101fbe7b34f7172045da9cc16ecddce0e54be35&cache=314130e6a060465f
Could be an issue with your networking.
And check with âredâ as suggested.
can it be that the integration card does nto allow this?
im using âcustom:firemote-cardâ
The 1st rule of testing: check with the simplest setup. Means - with a stock card.
i have testing your âredâ background idea, this does not work, so it looks like the problem is there the Card
try adding â!importantâ
ah yeah thats it, thank you
Ok the issue with text alignment was solved, but I cannot get my regular
box-shadow working. Would be really grateful for help.
card_type: button
button_type: name
icon: mdi:weather-partly-cloudy
button_action:
tap_action:
action: navigate
navigation_path: '#wetter'
card_layout: large
layout-options:
grid_rows: 1
grid_columns: 2
layout_options:
grid_columns: full
styles: |2-
ha-card {
margin-top: 0;
background: none;
opacity: 1;
.is-unavailable {
opacity: 0.5;
.bubble-button-card-container {
position: relative;
width: 100%;
height: 50px;
background-color: var(--background-color-2,var(--secondary-background-color));
border-radius: 32px;
overflow: scroll;
touch-action: pan-y;
.bubble-button-card,
.bubble-range-slider,
.bubble-button-background {
display: flex;
position: absolute;
justify-content: space-between;
align-items: center;
height: 100%;
width: 100%;
transition: background-color 1.5s;
background-color: var(--bubble-button-background-color);
opacity: .5;
.bubble-range-fill {
position: absolute;
top: 0;
bottom: 0;
left: 0;
width: 100%;
left: -100%;
transition: all .3s;
.is-dragging .bubble-range-fill {
transition: none;
.is-light .bubble-range-fill {
opacity: 0.5;
.is-unavailable .bubble-button-card,
.is-unavailable .bubble-range-slider {
cursor: not-allowed;
cursor: ew-resize;
border-radius: 25px;
overflow: hidden;
.bubble-icon-container {
display: flex;
flex-wrap: wrap;
align-content: center;
justify-content: center;
min-width: 38px;
min-height: 38px;
margin: 150px;
border-radius: 50%;
background-color: var(--card-background-color, var(--ha-card-background));
overflow: hidden;
position: relative;
cursor: pointer;
.bubble-icon-container::after {
content: '';
background-color: currentColor;
position: absolute;
display: block;
width: 100%;
height: 100%;
transition: all 1s;
left: 0;
right: 0;
opacity: 0;
.is-light.is-on .bubble-icon-container::after {
opacity: 0.2;
.is-unavailable.is-light .bubble-icon-container::after {
opacity: 0;
.bubble-icon {
display: flex;
opacity: 0.6;
.is-on .bubble-icon {
filter: brightness(1.1);
opacity: 1;
.bubble-entity-picture {
background-position: center;
height: 100%;
width: 100%;
position: absolute;
.bubble-name,
.bubble-state {
display: flex;
position: relative;
white-space: nowrap;
.bubble-name-container {
display: flex;
line-height: 18px;
flex-direction: column;
flex-grow: 1;
margin: 0 160px 0 4px;
pointer-events: none;
position: relative;
overflow: hidden;
.bubble-name {
font-size: 25px;
font-weight: 600;
.bubble-state {
font-size: 12px;
font-weight: normal;
opacity: 0.7;
.bubble-feedback-element {
position: absolute;
top: 0;
left: 0;
opacity: 0;
width: 100%;
height: 100%;
background-color: rgb(0,0,0);
@keyframes tap-feedback {
0% {transform: translateX(-100%); opacity: 0;}
64% {transform: translateX(0); opacity: 0.1;}
100% {transform: translateX(100%); opacity: 0;}
.large .bubble-button-card-container {
height: 56px;
.large .bubble-icon-container {
--mdc-icon-size: 40px;
min-width: 42px !important;
min-height: 42px !important;
margin-left: 8px;
.rows-2 .bubble-sub-button-container {
gap: 4px !important;
display: grid !important;
grid-template-columns: repeat(2, min-content);
grid-template-rows: repeat(2, 1fr);
grid-auto-flow: column;
width: auto;
padding-right: 14px;
.rows-2 .bubble-sub-button {
height: 20px !important;
background: rgba(12,120,50,0.5) !important;
card_mod:
style: |
ha-card {
font-size: 100px;
hander
September 7, 2024, 6:44pm
7047
Hello masters!
There is any way to style the header text of a grid? I know about card mod, but i donât know how to use it in a grid card.
Thanks!
Stef42300
(Stef42300)
September 7, 2024, 8:05pm
7048
I want to delete the transparent background behind the words âPrĂ©visions 14 joursâ
- type: entities
entities:
- type: custom:text-divider-row
text: Prévisions 14 Jours
align: left
card_mod:
style: |
ha-card {
margin-top: -50px;
background: none;
--text-divider-line-size: 0px;
For example :
There is a âshadow-rootâ.
If I understood correctly, I must go to âtext-divider-rowâ just above the âshadow-rootâ and go to âtext-divider-left spanâ.
I copied the first selector (#states > div > text-divider-row) and copy the second (div > h2 > span). Iâve tried to mix JS and YAML but it doesnât work.
Can you help me?
Thanks!
style:
ha-card {
margin-top: -50px;
background: none;
'#states':
'div':
'text-divider-row':
div > h2 > span {
background: none;
1st post - link at the bottom - grid
Stef42300:
text-divider-row
1st post - link at the bottom - text-divider-row
