šŸ”¹ Card-mod - Add css styles to any lovelace card
Hmm, I do not think this is possible. Will try a bit later once again. Note that in a ā€œbuttons-rowā€ it was also not possible to style ā€œfrom the buttonā€™s levelā€ - here it seems to be a similar story.
right, that could be it yes.
I had hoped to use :host or some other high level elementā€¦
maybe youā€™ll find it, Ill keep trying too :wink:
Hello together,
does anybody know how I can change the color for the icon at the badge of the new heading card?
Many thanks!!
My YAML for the heading so far, but it has no effect
type: heading
icon: ""
heading: Batterien
heading_style: title
badges:
  - type: entity
    show_state: true
    show_icon: true
    entity: binary_sensor.hausbatterien
    tap_action:
      action: more-info
    card_mod:
      style:
          ha-state-icon {
            {% if is_state(binary_sensor.hausbatterien, 'off') %}
              color: var(--success-color) !important;
            {% else %}
              color: var(--error-color) !important;
              animation: blink 2s linear infinite;
            {% endif %}
              @keyframes blink {
              50% {opacity: 0;
1st post ā†’ link at the bottom ā†’ heading
At thomasloven/lovelace-card-mod I cannot find anything about the new header, not sure if I miss somethingā€¦
When I check at Heading card - Home Assistant (home-assistant.io) there is a section about color for the badges BUT this affects only the color in active condition. So when the battery is OK I would like to style that to green.
Can you help me to get the proper position for the solution? Many thanks in advance!
Many thanks, I took the wrong link.
For other if they also like to color / indicate a low battery with the new headingā€¦
type: heading
icon: ""
heading: Batterien
badges:
  - type: entity
    show_state: true
    show_icon: true
    tap_action:
      action: more-info
card_mod:
  style:
    .badges hui-heading-badge:nth-child(1) hui-entity-heading-badge $: |
      ha-heading-badge {
        {% if is_state('binary_sensor.hausbatterien', 'off') %}
          --icon-color: green;
        {% else %}
          --icon-color: red;
        {% endif %}
        @keyframes blink {50% {opacity: 0;}}
Yay I was right that passing events to button-card would do the trick. And it turned out to be very easy, just add this to ā€œbuttonizeā€ template:
buttonize:
  styles:
    custom_fields:
      inner_card:
        - pointer-events: none
This gives weather-forecast card all click-effects defined in ā€œbuttonizeā€ (apart from ā€œrippleā€ I also have ā€œbounceā€ effect when left-clicked)
20241004_013601-ezgif.com-video-to-gif-converter
Thanks! Very nice.
I was trying to change the font or color of all badges to the same, without specifying a specific child, so far with no success.
Any ideas what am I missing?
      - type: heading
        card_mod:
          style:
            .badges hui-heading-badge hui-entity-heading-badge $ ha-heading-badge $: |
              .heading-badge {
                font-family: inherit !important;
              .content p {
Wew lads what theme is that? 1998?
somehow, Ive always used custom:button-card to make the headers of my compound listing cards (entities, vertical-stack) when in need of some templated value in the header.
my regular headers are:
        ha-card.class-header-margin .card-header {
          background: var(--background-color-off);
          font-weight: 400;
          font-size: 20px;
          color: var(--text-color-off);
          padding: 0px 12px;
          margin: 0px 0px 16px 0px;
in card-mod theme, and they are matched by this button-card template:
button_default_title:
  show_state: false
  show_icon: false
  tap_action:
    action: none
  styles:
    card:
      - background: var(--background-color-off)
      - color: var(--text-color-off)
      - font-size: 20px
      - font-weight: 400
      - padding: 12px
    name:
      - justify-self: left
and make this possible:
  - type: custom:button-card
    template: button_default_title
      [[[ return 'Kies Activiteit: ' + states['input_select.activiteit'].state; ]]]
only now (ā€¦) it dawned on me, I could also use a markdown card for the templated content, so I copied the style, but it doesnā€™t exactly fit.
  - type: markdown
    content: >
      Kies Activiteit: {{states('input_select.activiteit')}}
    card_mod:
      style: |
        ha-card.type-markdown {
          font-size: 20px;
          font-weight: 400;
        .no-header {
           padding: 8px 12px 14px 12px;
itā€™s almost there, but the margins are a bit peculiar. Ive set them on the .no-header now, at forst I had set them on the card, but apparently the markdown has its own stylings that interfere
as it stands its very nice, but not exact, and need a second eye to see where I should change the padding to make it perfect.
The top card is the button-card, with a perfectly centered name. the bottom one is the markdown, which slightly changes:
I could probably customize those paddings more meticulously, as I had to do with the new section heading
        ha-card.class-section-heading .container {
          --ha-heading-card-title-color: var(--text-color-off) !important;
          --ha-heading-card-title-font-size: 20px !important;
          --ha-heading-card-title-font-weight: 400;
          height: 24px;
          padding: 12px 8px 12px 12px;
but maybe I am targeting the wrong element in the Markdown ?
btw Iā€™ve filed a FR for adding actions to Markdown please consider upvoting that
Can you please advise how exactly you put this class in the theme? Cam you maybe show the full structure. I was not able to reproduce.
    card-mod-card-yaml: |
          height: 24px;
is it possible to add the standard border and backgroud to a grid so it looks like a card?
I populated a grid with multiple heading and followed previous posts to add border and background to each of them but i prefer to have all in one.
Could anyone please help me move the Home icon left to align with the floorplan icon? Iā€™d also like to give it a background in the same mannerā€¦
Itā€™s
<state-badge class=" pointer " tabindex="0" icon=""></state-badge>
Code for the relevant part of the card at the moment is
type: entities
entities:
  - entity: input_text.alexa_announcement_string
    name: Alexa Announcement
    icon: mdi:home-sound-out-outline
    secondary_info: none
show_header_toggle: false
state_color: false
card_mod:
  style: |
    ha-card {
      border-radius: 100px!important;
I tried adding
    ha-state-badge {
      background: red;
but doesnā€™t seem to do anythingā€¦ I think iā€™m fundamentally misunderstanding how cardmod works somewhere because I copy code from elsewhere and try to rationally adjust but I have a 50% hit rate on it working or not!
Adapting custom:button-card for Sections (for anyone using Sections):
post
We have had custom dashboards using card-mod for awhile now. we have modified a few things but most importantly have been using it to change the grid card so that the contents can have specific column span and row span. this worked great until this spring (sorry not exactly sure what version of HS broke it ~ 2024-05?)
I have been trying various configurations of card-mod to get this to work again to no avail. i have some sample code that was working just fine - and would make a 3x3 grid, with the first card taking up 2x2. any idea how to get this to work properly now? thanks in advance.
  - title: Nurse
    path: nurse
    type: custom:mod-card
    card:
      square: false
      type: grid
      cards:
        - type: custom:webrtc-camera
          url: rtsp://10.0.0.34:7447/C0zwc7l50KmBqslb
          style: '.mode {display: none} video {aspect-ratio: 16/9; object-fit: cover;}'
          card_mod:
            style: |
              :host {
                grid-column: span 2;
                grid-row: span 2;
          url: rtsp://10.0.0.34:7447/ffituAXS8Efc6Ktw
          url: rtsp://10.0.0.34:7447/sinRmeL0hx9nnC8R
          url: rtsp://10.0.0.34:7447/FkVWg1EpbrdAuqzU
          url: rtsp://10.0.0.34:7447/YMjb6dcj34OBuHse
      columns: 3
    card_mod:
      style: |
        ha-card {
          background-color: #000;
        :host {
          --grid-card-gap: 0px;
          --ha-card-border-width: 0px;
          --ha-card-border-radius: 0px;
nvm - i ended up switching from grid to custom:layout-card grid and all is working well. only using card-mod for overriding borders etc. thx!
I think you can use the heading cards and the badges for this
The user asked about a possibility to INPUT values directly.
Otherwise a simple Glance card might be enough: a horizontal row with 4 static values, a more-info pop up with a possibility to input on a tap_action.
Heading may provide a similar look - but needs modding since all entities will be aligned on the right.
