šŸ”¹ Card-mod - Add css styles to any lovelace card
I tried adding !important:
card_mod:
  style: |
    .forecast-image-icon
      width: 64px !important;
      height: 64px !important;
Same issue as before, it just pushes down the footer values.
Try changing mdc-icon-size var.
It doesnā€™t do anything.
Then probably you are trying to set attributes to a wrong element. Check again code inspector.
It shows these attributes not to the element you are trying to use - but to its child.
In your screenshot, you are setting the width and height of a div that is inside the .forecast-image-icon element, but then in your card-mod you are trying to target the .forecast-image-icon element itself. Try to target the same element that you are modifying in the dev inspector:
card_mod:
  style: |
    ha-card div.forecast-image-icon > div
Edit: you can override the same class that is shown in your screenshot (it seems that the element inside the .forecast-image-icon could be also something different from a div)
card_mod:
  style: |
    ha-card div.forecast-image-icon > *
You are awesome! That worked, thank you.
Has anyone tried to style the whole ā€œsectionā€ in the new Sections layout? Iā€™m trying to figure out what point in the DOM tree can be tapped into. Hereā€™s a view of it:
The top-most element that I can find is the hui-section with div.container inside that (a few levels down) being the DOM primitive (which is the element with the dashed border when in edit mode).
Editing a Section does allow you to get to its root YAML which makes me think that you can use card-mod on it, but Iā€™m also only speculating.
I almost got this working:
type: custom:stack-in-card
cards:
  - type: tile
    entity: climate.zigbee_grzejnik_salon
    features:
      - type: climate-hvac-modes
    hvac_modes:
      - auto
      - heat
      - "off"
    card_mod:
      style: |
        ha-card {
          border: none;
  - type: tile
    entity: sensor.zigbee_grzejnik_salon_position
    state_content: state
    card_mod:
      style: |
        ha-card {
          position: absolute;
          top: -30px;
          right: 10px;
          width: 100px;
          height: 0px;
          border: none;
But the clickable area of the second card is too big, it overlaps with the hvac controls:
Przechwytywanie
How do I get this not to oveflow on the HVAC controls?
FWIW, I think I figured out my main problem. I am using:
type: custom:mod-card
card:
  type: grid
card_mod:
  style: |
    ha-card {
      border-radius: 10px;
on a grid card. Which does work when manually specifying the style like this. Oddly, the Readme says:
NOTE: card-mod only works on cards that contain a ha-card element. This includes almost every card which can be seen , but not e.g. conditional , entity_filter , vertical-stack , horizontal-stack , grid
but this DOES work. However, I cannot apply a template to it. Perhaps because the template canā€™t apply to it since itā€™s not ā€œseenā€? :person_shrugging: Iā€™m not a super CSS / Front end person so itā€™s not clear to me but thought I would share.
You are doing exactly same what Docs suggested - using mod-card for the Grid which does not have ha-card.
to what?
card:
  type: grid
card_mod:
  style: |
    ha-card {
^ This works
card:
  type: grid
card_mod:
  class: test_class
card-mod-theme: new-theme
  card-mod-card: |
    ha-card.test_class {
or
  card-mod-card: |
    .test_class {
^ Does not work
Class cannot be applied to mod-card.
Call it a bug or a designed feature)))
And what you tried to do is not a ā€œtemplateā€. Here people understand a jinja code as a ā€œtemplateā€.
Not sure what you mean, itā€™s in the readme / docs: lovelace-card-mod/README-themes.md at f59abc785eabb689ac42a9076197254421f96c60 Ā· thomasloven/lovelace-card-mod Ā· GitHub
ā€œThemeā€ was added in a previous release?
Yeah, I keep thinking theme/class == template and mixing them up.
You can use a class for a card containing ha-card.
You cannot use a class for mod-card.(there is an issue in GitHub about this limitation)
Means - this works
type: xxx
card_mod:
  class: xxx
This does not:
card:
  type: xxx
card_mod:
  class: xxx
Thanks! This actually helps explain my confusion a lot. Appreciate it.
@Ildar_Gabdullin is right, I have checked and mod_card only takes into account a styles config, it will not accept anything else.
Meanwhile try to use this patch, it should solve your issue. If I have some time Iā€™ll open a pull request with that change.
Thanks for a patch. Will be able to check in 8 days. Would be great to have a PR created))
Hi all, assist please - is it possible to style only the first .sensor-value.clickable with Current temperature? The problem is that sensors have the same class name, maybe is it possible to check .sensor-heading value?
cards:
  - type: custom:simple-thermostat
    header:
    entity: climate.hallway
    decimals: 0
    step_size: 1
    sensors:
      - entity: sensor.ble_temperature_e72e00f1001b
        decimals: 1
      - attribute: min_temp
        unit: '.0 Ā°C'
      - entity: sensor.plug_nobo_hallway_power
    hide:
      temperature: true
      state: true
    layout:
      mode:
        headings: false
    card_mod:
      style: |
        .sensor-value.clickable { color: #4285F4; }
    control:
      preset:
        away: true
        none:
Do the two .sensor-value.clickable belong to the same entity? If not, you can style each entity, so it should only apply to that entityā€™s .sensor-value.clickable.
Does anybody know if it is possible to define the width of the slider in a slider-entity-row?
