terminus
(Ter Minus)
November 29, 2020, 9:53am
1017
Hi Guys, i have two Questions in formatting Icons on a Lovelace Card.
First one: How can I simply change the colors of the icons. I loked for the name of the element in Webpageinspector, it’s “ha-svg-icon”?:
The YAMl of the card ist this:
type: glance
entities:
- entity: sensor.ics_10
- entity: sensor.ics_11
- entity: sensor.ics_12
and at the moment it looks like this:
The Plan is, that the icons has a specifig color (i.e. green) and if the number in Brackets is 1, the backround should blink orange. The color in Brackets is a status attribute (remaining):
Do you have hints for me?
KTibow
(Kendell R)
November 29, 2020, 3:11pm
1018
Blinking is more complicated. First try this:
entities:
style: |
state-badge::before {
color:
{% if is_state_attr(config.entity, "remaining", "1") %}
orange
{% else %}
green
{% endif %};
style: |
color:
orange
{% else %}
green
{% endif %};
style: |
color:
orange
{% else %}
green
{% endif %};
terminus
(Ter Minus)
November 29, 2020, 4:01pm
1019
Thank you very much, now my YAML of the Card looks like this:
type: glance
entities:
style: |
color:
orange
{% else %}
grey
{% endif %};
style: |
color:
orange
{% else %}
green
{% endif %};
style: |
color:
orange
{% else %}
brown
{% endif %};
Buuuut the icons are still standard blue. Do I Need the !important attribute? Read it somewhere?
Regards
KTibow
(Kendell R)
November 29, 2020, 5:53pm
1020
Remove the ::before
part, that was an accident
terminus
(Ter Minus)
November 29, 2020, 6:13pm
1021
Thank you! So kind from you, teaching me such things!
Hi everyone,
I have read as many posts as I can and tried a few things myself but cannot make this to work.
If someone could help me on how to access the “.value-text” in the image below would be much appreciated
- type: gauge
entity: sensor.kitchen_sensor_temperature_offset
style:
ha-card {
padding: 4px;
ha-gauge {
width: 118% !important;
max-width: 500% !important;
ha-gauge:
text.value-text {
font-size: 70px;
KTibow
(Kendell R)
November 30, 2020, 8:46pm
1023
De-indent the ha-gauge shadow root part.
terminus
(Ter Minus)
November 30, 2020, 8:52pm
1024
Thank you again. If the blinking would be complicated, can i additionaly mark the icon on count “one” by coloring the background yellow for example?
terminus
(Ter Minus)
November 30, 2020, 9:10pm
1026
i tried
background: {% if is_state_attr(config.entity, "remaining", "1") %} yellow {% endif %};
but that didn’t worked out. Is it the right way nevertheless?
style: |
state-badge {
color:
"#FF4500"
{% else %}
brown
{% endif %};
SiMPA
December 1, 2020, 6:42am
1028
i spend hours to make bigger alarm keypad, but i still can not figured how to do this. I want change #keypad > max-width: parameter. Thanks for the help.
De-ident didn’t work. I removed everything and I only added
style:
ha-gauge$: |
.text {
left: 70% !important;
Which works. Now time to start adding back the rest of the style.
Thanks for your help
One last question. I read somewhere at the beginning that vertical/horizontal card is not supported. Do you know if this is still the case.
Is there a way to access the following :
hui-horizontal-stack-card #root > * { margin: 0px; }
KTibow
(Kendell R)
December 1, 2020, 2:54pm
1030
You can use mod-card for that, and go into the shadow root of hui-horizontal-card
terminus
(Ter Minus)
December 1, 2020, 7:02pm
1031
KTibow:
!important
Tried this but no success :-/
type: glance
entities:
style: |
state-badge {
color:
OrangeRed
{% else %}
grey
{% endif %};
style: |
state-badge {
color:
OrangeRed
{% else %}
green
{% endif %};
style: |
state-badge {
color:
"#FF4500"
{% else %}
brown
{% endif %};
background: {% if is_state_attr(config.entity, "remaining", "1") %} yellow {% endif %} !important;
KTibow
(Kendell R)
December 2, 2020, 1:51am
1032
You don’t need quotes around your hex code.
terminus
(Ter Minus)
December 2, 2020, 9:25am
1033
No change anyways
tested it like this because the attribute today is “12” but the icon stays red, and the background white
style: |
state-badge {
color:
{% if is_state_attr("config.entity", "remaining", "12") %}
#FFFF00 !important
{% else %}
red
{% endif %};
background: {% if is_state_attr(config.entity, "remaining", "12") %} yellow !important {% endif %};
gibman
December 2, 2020, 2:41pm
1034
Could use some help here with transparency vs “dark / light” default themes.
Right, now I have this working fine.
- type: entities
title: Adrian
show_header_toggle: off
style: |
ha-card {
background: center / cover no-repeat url("/local/adrian.jpg");
#box-shadow: none;
.card-content {
background-color: rgba(100, 100, 100, 0.7);
box-shadow: none;
.card-header {
box-shadow: none;
This looks good in dark theme mode, but not in light theme mode.
I want to be able to set different rgba values depending on the current theme applied.
What is the best way to approach this ?
I have no custom themes. No theme file at all in fact.
Using a debugger I able to tell that the meta tag has the info regarding what theme is active.
eg.
KTibow
(Kendell R)
December 2, 2020, 2:43pm
1035
I don’t believe you can do that. You can try using a different user profile for light/dark so you can use {{ user }}
, or automating it so you know when the automation will trigger.
terminus
(Ter Minus)
December 3, 2020, 9:39am
1036
It looks like my YAML doesn’ adress the state attribute, because its always the %else% state that is displayed. I tried for the if value “01” and “1” but both didn’t work. The !important tag did’t changed a thing
type: glance
entities:
style: |
state-badge {
color:
{% if is_state_attr("config.entity", "remaining", "1") %}
#FFFF00 !important
{% else %}
grey
{% endif %};
background:
yellow !important
{% endif %};
The background style works too, but here is also only the %else% state active. An example:
: glance
entities:
style: |
state-badge {
color:
#FFFF00 !important
{% else %}
grey
{% endif %};
background:
yellow !important
{% else %}
blue
{% endif %};
Its blue :-(, but its supposed to be yellow :-/
