can increase the width of the slider?
can you write me the code for this works
What do you get in the template tab of HA devtools?
Clarification please? Which card? Can you make a mockup or describe how you want it to be increased in more detail?
example , i want large as can use better.
this is my card
entities:
- entity: cover.tapparella_sala
full_row: true
max: 100
min: 0
step: 1
type: ācustom:slider-entity-rowā
title: TAPPARELLA SALA
type: entities
This might be hard. In the meantime, could you send a GitHub issue over to slider-entity-row?
custom tell me no can do with slider-entity-row
so i ask you with css or other custom card mod can i do this ?
I think your translatorās mangling your words. Could you restate, because
doesnāt make any sense?
the creator this custom tell me no have large slider , so i want find other solution.
sorry for my english translator
I think I asked this in the wrong thread earlier.
Iāve got an entities card with an image in the header. Iām trying to figure out the selector for the img. I can get to the header itself. Below, the red border shows up.
type: entities
style: |
ha-card div.header-footer.header {
border: 1px solid red;
height: 150px;
object-fit: cover;
entities:
- switch.garage
header:
type: picture
image: /local/snapshots/camera.malin_garage.jpg
The next element below is the hui-picture-header-footer, then the img element.
I canāt seem to figure out how to select the img element.
None of these work.
ha-card div.header-footer.header hui-picture-header-footer img
ha-card div.header-footer.header > img
Any ideas on how to select the img in a header?
iām trying to center the title in a grid card. can someone please help a noob out?
This is what i have tried so far and it does not work.
Added style: to grid card.
type: grid
title: Belysning
style: |
ha-card {
text-align: center;
cards:
- type: light
tap_action:
action: toggle
entity: light.spottar_vardagsrum
name: Spotlights vardagsrum
icon: 'mdi:track-light'
icon_height: 100px
- type: light
tap_action:
action: toggle
entity: light.spottar_matsal
icon_height: 100px
- type: light
tap_action:
action: toggle
entity: light.spottar_kok
icon_height: 100px
And tried to use the custom:mod_custom card this way and it didnt work either.
You need to use shadow roots for mod-card styling into hui-grid-card
Is sensor.ics_10
's remaining
attribute 11
? If not then the template is working. You donāt need to quote hex colors BTW.
Yes the remaining Attribute today is 11. I set it to 11 to see if the template does the job. Later I would set it back to 1.
What if you donāt quote 11?
type: entities
style:
hui-picture-header-footer$: |
img {
/* Do whatever you want to do */
height: 150px;
object-fit: cover;
entities:
- switch.garage
header:
type: picture
