🔹 Card-mod - Add css styles to any lovelace card
I tried to combine :host & “Hierarchy”, no success ((
Lack of knowledge & experience…
In short non-expert way, “:host” & “ha-label-badge” are same.
What was the code that didn’t work?
since almost all options are covered in this combined style:
  - entity: sensor.calltheboss_battery_level
    style:
      ha-state-label-badge:
          ha-label-badge:
              .badge-container: |
                .title {
                  color: orange;
                .badge-container .label-badge: |
                  .value {
                    color: red
                  .badge-container .label-badge .label span {
                    color: white;
            ha-label-badge {
              --label-badge-red: green;
              --label-badge-background-color: yellow;
for me, the final question is how to style the circle (border) independently from the unit box
(now the --label-badge-red: green; for ha-label-badge)
also, given Ildars remark above, whether this is the optimal (read: shortest) yaml for the config or not :wink:
this seems to be identical in result:
    style:
          ha-label-badge:
              .badge-container: |
                .title {color: orange;}
                .value {color: red;}
                .label-badge .label span {color: white;}
            ha-label-badge {
This is really interesting.
I changed “white” to “blue” for the UNIT- and it does not work.
This works:
      - entity: sensor.cleargrass_1_co2
        style:
              ha-label-badge:
                  .badge-container: |
                    .badge-container .label-badge .label span {color: blue;}
                ha-label-badge {
or this:
                  .badge-container: |
or this:
                  .badge-container: |
                    .badge-container .label-badge .value {color: red;}
Here is a problem which I have not solved so far.
I can change a style for some cards.
But cannot do it for cards inside 'custom:config-template-card'.
Let’s make a simple Entities card with 2 rows:
  • a row inside 'custom:config-template-card';
  • a usual row.
type: entities
title: config-template problem
entities:
  - type: 'custom:config-template-card'
    entities:
      - sun.sun
    row:
      entity: sun.sun
      style:
        hui-text-entity-row:
            hui-generic-entity-row: |
              .text-content {
                color: red;
  - entity: sun.sun
    style: |
      :host .text-content {
        color: red;
Note that for the 'custom:config-template-card' there are no variables & templates, it is just a simple example.
So, I cannot change a style for the 1st row.
Any help will be appreciated.
That’s because card-mod doesn’t work for custom cards. You could shadow-root into the row instead.
But I used card-mod for multiple-entity-card (which is mainly a row, not a card).
Could you guide me how to do it?
In my example above I did “shadow-root”, I think…
Shadow-root from the card instead of the row.
yes, I now do believe you are right, must have been a 1 time glitch…
where are the times we could simply set a theme to a badge:
green_badge:
  label-badge-background-color: white
  label-badge-color: grey
  label-badge-text-color: green
Lovelace makes all of this so much more difficult
I need to combine:
    style:
          ha-label-badge:
              .badge-container: |
                .value {color: grey;}
                .badge-container .label-badge .label span {color: red;}
            ha-label-badge {
with the coloring and dashing of the example in the docs:
              .label-badge {
                border-style: dashed;
                border-color: red;
but cant find the correct order of things… please have another go at it?
thanks
update
this works, now maybe compress the .badge-containers?
    style:
          ha-label-badge:
              .badge-container: |
                .badge-container .label-badge {
                  border-color: blue;
                  border-style: dotted;
                  border-color: pink;
            ha-label-badge {
Schermafbeelding 2021-01-19 om 10.11.06
bit further compressed:
    style:
          ha-label-badge:
              .badge-container: |
                  border-color: blue;
                  border-color: pink;
                  color: red;
            ha-label-badge {
Styling a card inside ‘custom:config-template-card’:
1.Styling a row - there are 2 options:
Option 1 - styling must be done from the "config-template-card":
Stopped working - see the issue; was fixed later.
code
type: entities
title: config-template (row)
entities:
  - type: custom:config-template-card
    entities:
      - sun.sun
    row:
      entity: sun.sun
      name: from CTC level
    card_mod:
      style: |
        div#card {
          color: orange;
    entities:
      - sun.sun
    row:
      entity: sun.sun
      name: from CTC level (many shadowRoots)
    card_mod:
      style:
        div#card :first-child $:
          hui-generic-entity-row $: |
            state-badge {
              color: red;
    entities:
      - sun.sun
    row:
      entity: sun.sun
      name: from CTC level (:host)
    card_mod:
      style: |
        :host {
          color: orange !important;
Option 2 - styling must be done from the "Entities card":
code
type: entities
title: config-template (row) (outside)
entities:
    entities:
      - sun.sun
    row:
      entity: sun.sun
    entities:
      - sun.sun
    row:
      entity: sun.sun
card_mod:
  style:
    config-template-card $:
      div#card :first-child $ hui-generic-entity-row $: |
        .text-content:not(.info) {
          color: orange;
2.Styling a card - must be done from the card itself:
code
entities:
  - sun.sun
card:
  type: entities
  title: config-template (card inside)
  card_mod:
    style: |
      .card-header {
        color: green;
  entities:
    - entity: sun.sun
      card_mod:
        style: |
          :host {
            color: red;
One more example:
code
entities:
  - sun.sun
card:
  type: entities
  card_mod:
    style:
      hui-sensor-entity-row:
          state-badge {
            color: cyan;
  entities:
    - entity: sensor.xiaomi_cg_1_pm25
    - entity: sensor.xiaomi_cg_1_co2
More examples are described here.
Magical !!)))
Also there is one more way to shorten the style - we can use "--label-badge-text-color" for icon & state.
Something like this:
        name: combined short 4 (+ 2 colors)
        style:
              ha-label-badge:
                  .badge-container: |
                      color: blue;
                      border-color: cyan;
                      border-color: red;
                ha-label-badge {
                  --label-badge-text-color: magenta;
a yes, I had been trying that but couldnt find a valid spot for it… It’s a little less obvious, so we need to keep both these examples available somewhere.maybe set the color to grey, to have it stand out more from the border :wink:
You can put "--label-badge-text-color" inside “:host” if used alone without these “$:” and “.:” - at least I could not combine these two ways.
What were the two ways that worked on their own?
  1. Using “:host” - I can set these colors:
      - entity: sun.sun
        style: |
          :host {
            color: red;
            --label-badge-text-color: green;
            --label-badge-red: magenta;
  1. But for other colors I need to use the hierarchy described above. And I cannot combine these two ways.
Put the :host stuff and whatever underneath the .: | part.
Any example?
Or is it same as described above like here: 🔹 Card-mod - Add css styles to any lovelace card
First original:
style:
  xyz:
      bla123
Second original:
style: |
  foo456
Combined:
style:
  xyz:
      bla123
    foo456
OK, thank you)))
Then a new short version for Badge:
        name: combined short 5 (+ 2 colors)
        style:
              ha-label-badge:
                      color: blue;
                      border-color: cyan;
                    border-color: red;
            :host {
              color: orange;
Great :slight_smile: Thx!!
/L
